POV-Ray : Newsgroups : povray.advanced-users : re HF heights Server Time
30 Jul 2026 13:46:40 EDT (-0400)
  re HF heights (Message 1 to 10 of 15)
Subject: re HF heights
Date: 1 Jul 2000 07:07:18
Message: <395dd0e6$1@news.povray.org>
Is there a way of finding the highest parts of a hf.  I don't just want
everything above a certain height but the top of every bump. Hope this is
clear.
Hope someone can help.
Mick
Subject: Re: re HF heights
Date: 1 Jul 2000 08:14:38
Message: <395DD2C3.D88FF82B@peak.edu.ee>
A basic method in MegaPOV would be to get a grid of height values (using trace)
and start comparing: if a point is higher than all 8 points around it (or 5
points at the edges, or 3 points in the corner) it is the top of a bump.
Of course it's a bit more complicated if you want more control, e.g. only
consider convexities above a certain scale as "bumps".
Margus Ramst
Date: 1 Jul 2000 08:59:02
Message: <395DEB13.33C4FB6F@schunter.etc.tu-bs.de>
That would produce quite a lot of points, because usual heightfields contain
quite a lot of local maxima.
HF-Lab contains a function for something quite similar, namely filling up local
minima, source code (in C) can be found at:
http://www.best.com/~beale/
Date: 1 Jul 2000 15:14:15
Message: <shgslso0akn9pcm58dlljbqg9sbgg5c03u@4ax.com>
On Sat, 1 Jul 2000 12:09:16 +0100, "Mick Hazelgrove"
>clear.
In MegaPOV, you can use the slope pattern and give it a suitable color
map so as to only point out the peaks. Then you can use eval_pigment
to check against it and the place objects or whatever you like on the
'bumps'. Hope I made this clear enough.
Peter Popov ICQ : 15002700
Date: 1 Jul 2000 20:00:08
Message: <395E8575.78A398EF@online.no>
> clear.
I believe this problem is a bit similar to a problem that is solved
by the source code I posted 13. May 2000 to the thread
"On Bezier splines" (by Peter Popov):
news://news.povray.org/391C9B3B.C63B6FC1%40online.no
I can explain how to use the code if you're interested.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 1 Jul 2000 20:43:21
Message: <chrishuff-8F5AEE.19432801072000@news.povray.org>
In article <shgslso0akn9pcm58dlljbqg9sbgg5c03u@4ax.com>, Peter Popov
The eval_pigment function won't work with the slope pattern, because
slope requires intersection information which isn't available(POV
doesn't know you want to check it at that point on the surface of the
object).
However, you could do an overhead view of the height field, and use
eval_pigment on the resulting image_map...or emulate the slope pattern
using the trace function.
Date: 2 Jul 2000 00:11:08
Message: <30gtlsk8a4sijojb3m8s72v91kqao23h67@4ax.com>
On Sat, 01 Jul 2000 19:43:28 -0500, Chris Huff <chr### [at] maccom>
>object).
That's a limitation I didn't think about. Thanks for putting me back
on track.
Date: 2 Jul 2000 05:38:19
Message: <395f0d8b@news.povray.org>
Wouldn't a gradient y pattern be even better to determine the highest part
of the Hf? Just give it a colour-map from black to white and check for the
brightest part (with eval_pattern)?
Marc-Hendrik
Date: 2 Jul 2000 06:40:16
Message: <8F6588BDCseed7@204.213.191.228>
>(using trace) and start comparing: if a point is higher than all 8
>points around it (or 5 points at the edges, or 3 points in the corner)
If the base of your HF is an image you can use ImagInc by Remco de Korte
to get a grid of values: http://www.xs4all.nl/~remcodek/pov.html . It
turns an image into an INC file so you can use the RGB-data.
Ingo
Date: 2 Jul 2000 12:37:53
Message: <amrulsg5autt8s7q0ecldevitfrtt31cng@4ax.com>
On Sun, 2 Jul 2000 11:36:53 +0200, "Marc-Hendrik Bremer"
This would only determine the global maximum and not all the local
maxima.
