POV-Ray : Newsgroups : povray.advanced-users : Bounding Question #2 Server Time
4 May 2026 11:05:02 EDT (-0400)
  Bounding Question #2 (Message 1 to 7 of 7)
Subject: Bounding Question #2
Date: 12 Aug 1999 05:14:20
Message: <37B29014.E5722D1A@xs4all.nl>
I've never really used manual bounding (not in POV) but as I understand it it
can have advantages. I'm wondering if it can help me here:
I have a series of planes with a hole cut out lined up in front of each other so
the camera looks through the holes. This is quite slow to render. Is there a way
to speed it up with bounding?
I know part of the reason why it it slow is in the light_sources I use.
I need them to get a flat light. I didn't want the planes to cast shadows on
each other. Obviously this was before I knew of the no_shadow keyword 8-]
Here is the code:
global_settings{max_trace_level 32}
camera {location<0,0,-20> look_at<0,0,0> angle 30}
sky_sphere {pigment{gradient y
  color_map{[0 rgb<.7,.1,0>][.2 rgb<1,.9,.3>][1 rgb<.1,.15,.2>]}}}
light_source{<-20,20,-.9> color rgb .4}
light_source{<20,20,-.9> color rgb .3 shadowless}
light_source{<-20,-20,-.9> color rgb .2 shadowless}
light_source{<20,-20,-.9> color rgb .1 shadowless}
light_source{<-20,20,5> color rgb .2 shadowless}
light_source{<20,20,5> color rgb .15 shadowless}
light_source{<-20,-20,5> color rgb .1 shadowless}
light_source{<20,-20,5> color rgb .05 shadowless}
#declare diam=1.28;
#declare tt=0;
#while (tt<10)
  difference{
  box{<-100,-100,0><100,100,.01>}
  sphere{0,diam+tt/4}
  pigment{rgb<.4-tt*.045,.3-tt*.0275,.25-tt*.0225>}
  translate<0,0,-6.25-tt>}
  #declare tt=tt+1;
light_source{0*x color rgb 2.5
  area_light  <8, 0, 0> <0, 8,0>
  10, 10 jitter adaptive 3 translate <0,0,-20>}
Remco
Subject: Re: Bounding Question #2
Date: 12 Aug 1999 08:07:17
Message: <37b2b8f5@news.povray.org>
Remco de Korte <rem### [at] xs4allnl> wrote:
: I have a series of planes with a hole cut out lined up in front of each other so
: the camera looks through the holes. This is quite slow to render. Is there a way
: to speed it up with bounding?
  If you only see the first plane completely and only a little of the other
planes through the hole, you could bound those planes with one box which
covers the hole in the first plane.
Date: 12 Aug 1999 11:57:04
Message: <37B2EEE3.7B5EAF63@xs4all.nl>
I noticed my story wasn't quite accurate. I talked about planes, but in the code
you can see I used (thin) boxes for that. Would that make any difference?
Anyway, thanks for the suggestion, I'll give it a try.
Remco
Date: 13 Aug 1999 01:15:47
Message: <37b3aa03@news.povray.org>
Remco de Korte wrote in message <37B29014.E5722D1A@xs4all.nl>...
it
other so
a way
on
>Here is the code:
One significant speedup would be to reduce the number of light sources, as
each ray from the camera that hits a plane will get checked against each of
these lights to determine the color contribution from the lights.
This is another major slowdown, as it is the equivalent of up to 100 light
sources.
Mark
Date: 13 Aug 1999 02:53:44
Message: <37b3c0f8@news.povray.org>
: I noticed my story wasn't quite accurate. I talked about planes, but in the code
: you can see I used (thin) boxes for that. Would that make any difference?
  I think yes.
  My idea more exactly: Leave the first plane/box alone but make a union
from all the planes/boxes behind it and bound this union with a box (or
cylinder) which is located at the hole in the first plane/box and which
covers this hole.
  Now povray will test intersections with the first plane/box and the
bounding box everywhere but in the hole, where it tests intesections with
all the planes/boxes (instead of testing intersections with all the
planes/boxes everywhere).
Date: 13 Aug 1999 06:04:12
Message: <37B3E852.D2D94907@xs4all.nl>
> it
> other so
> a way
> on
> >Here is the code:
> sources.
> Mark
Thanks, but as I explained in my message I need the lightsources, unlikely as it
may seem. Even the area light, and even with this much lights and the settings.
I want a flat light, coming from the camera. I tried no_shadow but that doesn't
work the way I wanted. So, I actually need a shadow but it has to be the same
all over. Try rendering it if you want to know what I'm rambling about.
Remco
Date: 13 Aug 1999 06:04:13
Message: <37B3E87E.D9B0D018@xs4all.nl>
>   I think yes.
> covers this hole.
Thanks, I'll give it a try. I wonder how significant the speed difference will
be.
Remco
