POV-Ray : Newsgroups : povray.advanced-users : Saving an object? Server Time
29 Jul 2024 04:26:09 EDT (-0400)
  Saving an object? (Message 1 to 10 of 15)
Subject: Saving an object?
Date: 7 Apr 2003 10:34:28
Message: <3e918c74@news.povray.org>
Is there any way to save an object (IE, a union of lots of other objects) to
disk and then read it back in?
THis could potentially save me tons of parsing time if there's a way to do
it.
Subject: Re: Saving an object?
Date: 7 Apr 2003 10:38:56
Message: <25339v4nfh9cf54is5t498luhelf2uoj5c@4ax.com>
On Mon, 07 Apr 2003 11:33:31 -0400, Tyler Eaves <tyl### [at] hotpopcom> wrote:
> it.
During first parsing you can parallel create file on drive with equivalent of
content you creating for parsing. This is common habit in case of creation of
meshes. For example look for HF_* macros in standard distribution. There is a
parameter for choosing output to file.
ABX
Date: 7 Apr 2003 10:42:23
Message: <3e918e4f@news.povray.org>
>> to disk and then read it back in?
>> do it.
> of content you creating for parsing. This is common habit in case of
> creation of meshes. For example look for HF_* macros in standard
> distribution. There is a parameter for choosing output to file.
> ABX
That makes sense.
Date: 7 Apr 2003 10:44:28
Message: <3e918ecb@news.povray.org>
>> do it.
> ABX
Ack, hit send too soon.
What I was really hoping for was some sort of binary save,
ala photons. But that'll help, since my code is VERY loop intensive.
Speaking of that, is there any real speed hit for unioning a number of
objcets together, as opposed to not unioning?
Date: 7 Apr 2003 10:49:31
Message: <1m339vs90olfojbaueda0sol14kc4quh0o@4ax.com>
On Mon, 07 Apr 2003 11:43:31 -0400, Tyler Eaves <tyl### [at] hotpopcom> wrote:
> ala photons.
AFAIK photons related files are not binary. They are probably fully portable
ascii files. Supported portable format for exchenging objects are ascii files
with scripts written in SDL.
As usually depends it depends on situation. Hard to say without knowing objects,
environment, complexity of scene.
ABX
Date: 7 Apr 2003 12:32:19
Message: <3e91a812@news.povray.org>
> objects, environment, complexity of scene.
One thing I've done, that helps quite a bit, is calculating the posistions
where the objects should be placed along the spline in my python code.
so instead of doing something akin to.
#while(pos < end)
#declare d = d + distance_from_the_last_point;
#if (d > somenumber)
#declare d = 0;
//Do something
#declare pos = pos + .0001
Now I loop over an array of the positions. Helps quite a bit.
Date: 7 Apr 2003 12:53:27
Message: <3E91AD06.89BA2DBF@gmx.de>
> > ala photons.
photons are not stored in ascii but in binary form.  This of ocurse also
means that photon data files are not as portable as POV-Ray itself.  This
does not matter that much since photon data is not really intended to be
moved between different platforms.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 7 Apr 2003 12:55:31
Message: <78b39vs5bju40d2eu1otajq7hksq0imic0@4ax.com>
On Mon, 07 Apr 2003 18:53:26 +0200, Christoph Hormann <chr### [at] gmxde>
So there is no way to use photons data for multiplatform distributed rendering ?
I'm surprised.
ABX
Date: 7 Apr 2003 13:39:38
Message: <3E91B7DA.D12CC40A@gmx.de>
> I'm surprised.
Not necessarily, the most common platforms are compatible in terms of the
photon data (there are no byte order problems, only non-IEEE floating
point numbers will be difficult).  But as i said this compatibility is
less than what is possible with POV-Ray itself.
Date: 7 Apr 2003 15:32:23
Message: <3e91d247$1@news.povray.org>
In article <78b39vs5bju40d2eu1otajq7hksq0imic0@4ax.com> , ABX
> I'm surprised.
Since when is "multiplatform distributed rendering" a feature of an official
version of POV-Ray?
    Thorsten
e-mail: tho### [at] trfde
