POV-Ray : Newsgroups : povray.advanced-users : Alternative to CSG Server Time
29 Jul 2026 00:01:27 EDT (-0400)
  Alternative to CSG (Message 1 to 4 of 4)
Subject: Alternative to CSG
Date: 8 Dec 2001 20:47:19
Message: <1103_1007820242@jkior>
Hello (should this be posted on the newusers group?),
I'm constructing a tunnel out of many small blocks - fairly simple stuff. However, I'd
like to cut a hole in it, for a doorway. Since I'm using while loops, I don't see any
way
to remove certain blocks, and #difference is *really* slow. Any suggestions on this?
By the way, deleting whole blocks to make the hole is perfectly fine.
Thanks!
Jkior
The image thus far:
<a
href="http://www.spacetowns.com/jkior/tunnel.jpg">http://www.spacetowns.com/jkior/tunnel.jpg</a>
Subject: Re: Alternative to CSG
Date: 9 Dec 2001 01:23:06
Message: <3c13034a$1@news.povray.org>
Make an object that defines the doorway shape that you want to cut out.
Then, before placing any blocks, test to see if the center of them is inside
the doorway object by using the inside() function (look it up in the
documentation). Don't place them if they're inside the object.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
<jki### [at] zworgcom> wrote in message news:1103_1007820242@jkior...
However, I'd like to cut a hole in it, for a doorway. Since I'm using while
loops, I don't see any way
suggestions on this? By the way, deleting whole blocks to make the hole is
perfectly fine.
> Thanks!
> Jkior
> The image thus far:
> <a
Date: 9 Dec 2001 02:15:44
Message: <Eb7m5LA36wE8EwoB@econym.demon.co.uk>
>this? By the way, deleting whole blocks to make the hole is perfectly fine.
Rather than trying to work out which bricks to delete, it's possible to
make "difference" got very much faster.
Differencing with collections of many small objects will often defeat
POVRay's automatic bounding algorithm. Effectively you end up with POV
having to check every brick for every ray, rather than only those that
bricks that are close to the ray.
I'd suggest that you try converting it from
difference {
  union {
    lots of {
      individual_brick
  hole
to
union {
  lots of {
    difference {
      individual_brick
      hole
Which will allow POV to apply sensible automatic bounds around each
brick, and the scene will render in a fraction of the time.
Mike Williams
Gentleman of Leisure
Date: 9 Dec 2001 08:22:01
Message: <3c136579@news.povray.org>
Hmm? Wouldn't it just work if you put an #if which checks if the
coordinates of the blocks are inside a certain area, and put the block
only if it's outside this area.
