Hello,
I would place a text to a elastic band, but I don't know how.
The text should placed to a cylinder and my problem is that the text is in a
horizontal level and I don't know how
it can place it to form from the cylinder. How can i do that?
Sure I can place for every char a text field and can it place with rotate to
the right position, but that is a lot of work and I think it can be easier
Take a look at the thread above, "Ingo's Make Mesh include with udo
support". it tells how to do just that.
Steve Shelby
"Bernd Michler" <mb### [at] anti-trojannet> wrote in message
news:401f5d19@news.povray.org...
> Hello,
a
to
I think I may have given you the wrong advise, unless you are wanting to
create raised or recessed text. For regular text that is simply a different
color from its background, you need to create a graphics file (.bmp,.jpg,
etc.) and use it as an image map (Marerial / standard texture / pigment /
image map).
> Hello,
a
to
Hi Bernd,
Do you want to place just a flat image of text on the cylinder? Or do
you want to do CSG, i.e. cut it out of the cylinder? You could CSG a
cylinder with the text and then the text will scale with the cylinder.
If you want the text vertical, simply rotate it by 90 about the Y-axis
before attaching to the CSG....
If I'm not understanding, please describe it in more detail or with an
example....
- Lutz
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
Hi Lutz,
ich schreibe das mal in Deutsch.
sich der Form des Cylinders annimmt,
oder halt das wenn ich einen Text in meine Szene setze die einzelnen
Bernd
"Lutz Kretzschmar" <lut### [at] stmuccom> schrieb im Newsbeitrag
news:mo1120150qqpscm8s8d5hqhcq6olvldajs@4ax.com...
> Hi Bernd,
> example....
> - Lutz
in a
rotate to
easier
> - Lutz
