POV-Ray : Newsgroups : moray.win : Frame of reference for car wheel animation Server Time
29 Sep 2024 01:23:32 EDT (-0400)
  Frame of reference for car wheel animation (Message 1 to 2 of 2)
Subject: Frame of reference for car wheel animation
Date: 17 Nov 2003 00:04:51
Message: <3fb856f3@news.povray.org>
Can anyone help me with animation in general and animating cars?
First things first. Thank you a bunch for any help, attention, advice,
blessings and prayers that you give. It is most appreciated.
I want animate car models so that the distance traveled reflects the
rotation speed of the wheels, as if it were actually covering the distance
of land equal to the circumference of the tire. I also want to show
realistic frame of reference for fancy rims as the cars speed up and slow
down. While I'm at it I will probably need to turn the wheels and things as
well.
I am probably going to be using a combination of open-source apps: Blender,
POV-Ray, OpenFX, trueSpace 3.2, Alice and/or Terragen. I am still learning
3D, but POV-Ray and Blender seem to be really, really great apps and great
for the price. I also have access to "Free learning" versions of commercial
apps such as Lightwave Discovery edition, Maya Personal Learning edition and
Houdini Apprentice. I also have a friend that has access to Bryce 5 and
Poser 4.
Whew! Now I'm no physics expert. But I do hold a PhD and a black belt in
ambition. If I'm tackling more than I can chew as a newbie just slap me in
da face. Otherwise let 'er rip. Feel free to hit www.willparis.com with
anything that can help.
Thank you all.
Subject: Re: Frame of reference for car wheel animation
Date: 18 Nov 2003 15:05:30
Message: <cjameshuff-67198F.15021618112003@netplex.aussie.org>
In article <3fb856f3@news.povray.org>,
> well.
You just pretty much said what you need to do. Translate it so it
travels a distance equal to its circumference for every revolution. The
animation tutorial in the manual does just this, only with a ball
instead of a wheel. Taking changing velocity into account is a little
more complex, but not extremely so. It would be simple to do with a
simple simulation: Set up the car position with a spline. Figure out the
car's distance from its previous location, and how much the wheel should
have rotated over that distance.
I'm not sure what you are thinking of by "realistic frame of reference".
> Poser 4.
Overkill...this can be done with a simple POV script. If you want to use
one of the other packages, this is the wrong place to ask for help using
them. Otherwise...I'm not really sure why you mentioned them.
http://tag.povray.org/
Date: 22 Nov 2003 11:53:24
Message: <cjameshuff-986907.11481022112003@netplex.aussie.org>
I've posted some scene code in povray.text.scene-files which does nearly
what you asked for. The code takes a spline path for a single wheel to
follow, and rolls it along the path, rotating it correctly for the
distance it follows. Varying velocity is done by adjusting the spline
path. For a car, you may want to integrate the distances each wheel
travels, otherwise the individual wheels will "slip".
Date: 3 Dec 2003 04:30:01
Message: <web.3fcdacf1a4e89194e1f4eb10@news.povray.org>
>well.
>Poser 4.
>Thank you all.
Dist/Circumference * 360 = angle
It can not get any simpler than that.
