![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have seen how you can apply soft shadows in povray with spot lights and
omni lights. Somebody can tell me how can I do the same in moray?
Thanks.
Antonio
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:3c3cb281@news.povray.org...
> Thanks.
> Antonio
Sorry Antonio, too much work here in Real Life to answer your last post.
I think the soft shadows with spot and point lights can be obtained using
fade_power and fade_distance.
To know how this modifiers work, you can take a look at the documentation
(look at povray docs also).
Good luck
Bye
Txemi Jendrix
tji### [at] euskalnet net
http://www.geocities.com/txemijendrix
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Txemi Jendrix <tji### [at] euskalnet net> wrote:
: I think the soft shadows with spot and point lights can be obtained using
: fade_power and fade_distance.
Not really. You need area_light for that.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
just use area lights
PGP Public Key
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
another way is to use so many lights at *nearly* the same place that the
shadows seem to fade out smoothly. i found out that you will need
between 10 and 20 lights to create a smooth fade. no problem with the
moray duplicate-option!
and rendering seems to be much faster than with area lights.
alex
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I can't really believe that ...
especially, if they are at the same position, how can the shadows become
smooth ?
if you distribute them a little bit, you do the same thing, as area_lights
do,
but a_l do more ... They don't need so much light_sources as they support
jitter and adaptive sampling ...
Note: The more lightsources you have, the slower your rendering will be ...
"Somehow what you suggest is like suggesting to add drills \ jan### [at] lzer net
to cars so you can drill for oil when you run out of fuel. \
Sure you could do it, but it might not be the most practical > Jan
solution." [Thorsten Froehlich in p.u.p] / Walzer
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I agree that your render will be slower. Also keep in mind that if your forget
to lower the
magnitude for each individual point light, your scene might be a bit brighter
than expected,
whereas an area light only has one magnitude value to worry about.
-Lawrence
> smooth ?
> do,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Alex Wolff <ale### [at] gmx de> wrote:
: and rendering seems to be much faster than with area lights.
This can't be true.
You are probably creating a non-adaptive area light with 100 points and
comparing it with 10 individual point lights.
Create the area_light with the same amount of points as your trick and
use adaptiveness (eg. adaptive 0, adaptive 1 or whatever is the smallest
number which gives a good result). The area_light should render a lot faster.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 9 Jan 2002 18:40:42 -0500, Warp wrote...
Or you can use lots and lots of point lights or spotlights with
fade_power etc set. I know you can 'cos i've done it when I got bored.
Bye for now,
Jamie.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Jamie Davison <jam### [at] ntlworld com> wrote:
:> Not really. You need area_light for that.
: Or you can use lots and lots of point lights or spotlights with
: fade_power etc set.
But why would you want to do so? area_lights do exactly that, but you
can use adaptive sampling in order to seed up the rendering.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
