POV-Ray : Newsgroups : moray.win : Orientation of text in Moray Server Time
20 Mar 2026 13:24:14 EDT (-0400)
  Orientation of text in Moray (Message 1 to 9 of 9)
Subject: Orientation of text in Moray
Date: 16 Jun 2001 10:00:52
Message: <3b2b6694$1@news.povray.org>
Why does Moray put text in so that it is facing up, instead of facing the
front view? Every time I put text in a scene I have to rotate it -90x, which
makes any later manipulation is more complicated, since it is not starting
at zero. Is there any way to make text appear the right way (that is, facing
the front view, rotation 0,0,0) to begin with?
Thank you,
Steve Shelby
Subject: Re: Orientation of text in Moray
Date: 16 Jun 2001 17:02:18
Message: <MPG.1595da09a8ef512a98995d@news.povray.org>
On Sat, 16 Jun 2001 21:01:24 -0500, sshelby wrote...
> Thank you,
Well not automatically, but...
You create your text object.
Select it.
Click the Local Coordinates Button.
Enter -90 into the x Rotate box.
Click local coordinates again.
Tada!
I think that should work.
Bye for now,
     Jamie.
Date: 16 Jun 2001 19:38:14
Message: <3b2bede6@news.povray.org>
> Select it.
> Tada!
> Bye for now,
>      Jamie.
Good trick, I haven't think about it...
thank you
Txemi Jendrix
tji### [at] euskalnetnet
Date: 16 Jun 2001 23:46:10
Message: <3b2c2802@news.povray.org>
Jamie,
Thank you. That works very nicely. My first question still remains
unanswered, though: Why is it programmed so the text faces up instead of
foreward?
Steve Shelby
Jamie Davison <jam### [at] ntlworldcom> wrote in message
news:MPG.1595da09a8ef512a98995d@news.povray.org...
the
which
starting
facing
> > Thank you,
> Select it.
> Tada!
> Bye for now,
>      Jamie.
Date: 17 Jun 2001 07:58:35
Message: <MPG.1596abb017467ed5989960@news.povray.org>
On Sun, 17 Jun 2001 10:46:44 -0500, sshelby wrote...
> Jamie,
> foreward?
Ummm....  Lutz picked an orientation at random?
In other words, I haven't the faintest idea :)
Bye for now,
     Jamie.
Date: 17 Jun 2001 09:47:24
Message: <s6dpitorg34o02p5u2fbgptunb6bjpsivp@4ax.com>
Hi sshelby, you recently wrote in moray.win:
> front view?
That's just the way I picked :-)
Who says that this is the 'right way'? :-)
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 17 Jun 2001 10:13:27
Message: <3b2cbb07@news.povray.org>
Lutz,
Thanks for your input. I would consider the front view to be the primary
view, just as in the front elevation in an archetectural presentation. I
would also think of the front view as the only view you would see if it were
only 2D. Maybe my problem is that my background is in art and not computers.
Steve
Lutz Kretzschmar <lut### [at] stmuccom> wrote in message
news:s6dpitorg34o02p5u2fbgptunb6bjpsivp@4ax.com...
the
> > front view?
> - Lutz
Date: 17 Jun 2001 13:59:39
Message: <utrpit0lo8jmftlsc5vhbd4iapgb65dimu@4ax.com>
Or my problem :-)
I see it like a piece of paper lying on the table... X and Y define
the paper coordinates and Z are then used to extrude for depth.... I
guess part of the reason was also because the translational sweeps
work like that.....
- Lutz
Date: 17 Jun 2001 22:53:47
Message: <3b2d6d3b@news.povray.org>
OK, I see your reasoning. I disagree, but I understand.
Steve
news:utrpit0lo8jmftlsc5vhbd4iapgb65dimu@4ax.com...
> Or my problem :-)
> work like that.....
> - Lutz
