POV-Ray : Newsgroups : moray.win : How do I do this? Server Time
17 Jan 2026 07:13:58 EST (-0500)
  How do I do this? (Message 1 to 6 of 6)
Subject: How do I do this?
Date: 7 Jun 2001 22:34:50
Message: <3B203994.7A204225@notathome.com>
I'm trying to create model of baseball.
I worked out a way of creating interlocked halves but can't figure a way
of getting the stitching right.
I got close by using Rhino's "baseball sphere" and then using curve edge
to extrude curve into surface but the "baseball" shape is all wrong
I have Moray and Rhino and 3DS. The best attempt cheats using material
maps on plain ball but I reaaly want a solid. Anyway the material map is
awful to do as I don't have a graphic program than can create an array
of images (stitches) following a line/curve.
Ideas?
Subject: Re: How do I do this?
Date: 8 Jun 2001 00:25:21
Message: <utk0itgn35je696uc8c861clerg6qtg582@4ax.com>
On Thu, 07 Jun 2001 22:33:56 -0400, Andrew Hutchinson
See if this can help you:
Message-ID: <38B1C5D8.DFBABF96@stud.ntnu.no>
Date: Tue, 22 Feb 2000 00:10:16 +0100
Newsgroups: povray.binaries.images
Subject: Baseball, strike two 28kbu
References: <38AFF53B.4A483B33@stud.ntnu.no>
<38B1631E.651B9D8D@spiritone.com>
Xref: news.povray.org povray.binaries.images:28987
Peter Popov ICQ : 15002700
Date: 8 Jun 2001 12:10:22
Message: <3B20F95C.D4BC3A5@yahoo.com>
i see you've referenced a previous post.  is there a way to go right to
the message, or do i have to go to the group and then search or
something?  isn't there a way to make it into a link in your message?
> From: Sigmund Kyrre Aas <as### [at] studntnuno>
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Date: 8 Jun 2001 20:50:21
Message: <b0s2it4ug02jju4v0o6rav0f6gq5cq0apl@4ax.com>
On Fri, 08 Jun 2001 09:12:12 -0700, Ryan Constantine
The message ID should be enough for your newsreader to identify the
message. In Agent, I just right-click and select 'Jump to message
URL.' I don't know how you can do it with your reader but it should be
there.
Alternatively, although I absolutely don't know what I am doing, maybe
this will work as a link:
news://news.povray.org/povray.binaries.images/38B1C5D8.DFBABF96@stud.ntnu.no
Date: 10 Jun 2001 23:24:54
Message: <3b243a06$1@news.povray.org>
"Peter Popov" <pet### [at] vipbg> wrote in message
news:b0s2it4ug02jju4v0o6rav0f6gq5cq0apl@4ax.com...
VERY close, Peter!  The correct URL is this:
news://news.povray.org/38B1C5D8.DFBABF96@stud.ntnu.no
I suppose the 38B1C5D8.DFBABF96 is a global ID.
-Ian
Date: 12 Jun 2001 17:21:12
Message: <ho1ditsnh8slhilm21gh0at57fchi7fa1d@4ax.com>
I wrote in message
On Sun, 10 Jun 2001 23:24:17 -0400, "Ian Burgmyer"
Well, I guessed the group mattered as a) Agent seemed to skim through
the groups searching for this message and b) when I telnet-ed
news.povray.org on the nntp port and played around (Hi Chris! :) ) I
noticed an error message along the lines of "No such message ID in
this group."
Anyway, you made it work, so who cares :)
