![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
xref like autocad and 3ds max have. it doesn't already have this does
it?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi ryan constantine, you recently wrote in moray.win:
> it?
Maybe you could explain what it does? I'm not proficient in AutoCAD or
3DS Max.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
when you make a model and save the model alone, an xref in a scene file
will check each time you load it to see if the model has been updated.
if it has, it updates the model in the scene as well. xref stands for
external reference. this is handy if for example, you make a car, save
it, then include it in a scene and later change the car model itself. i
have many parts of a model that are saved seperately as models and
combined to form a more complex model. if i notice a mistake in one of
the parts, not only do i have to change the original part, but i have to
delete the part from the big model and then merge the new updated part
back in. is that clear or did i just ramble?
> > it?
> 3DS Max.
> - Lutz
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Clear. Sort of like reference objects, but on a file basis. Sounds
messy, though. I'll have to put it on the list.
- Lutz
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
on a similar note, it would be cool if a 'merged' object were treated as
a udo. for example, separate include file, but good wireframe to work
with in the modeler. the main reason is that when i combine my model
parts into the big model i am working on, a new file which contains all
objects is created, which essentially doubles the amount of hard drive
space the model uses. this could likewise be incorporated into the xref
ability as well. an alternative would be to add 'export as udo' to the
file list.
today is my last day of finals for the semester. i should be able to
finish my xwing model in the next week or two, and then i will be
brushing up on my c++ so that i can write that texture converter. wish
me luck. i'll keep you posted.
> - Lutz
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 22 May 2000 15:52:28 -0700 ryan constantine
<rco### [at] yahoo com> wrote:
>i should be able to
>finish my xwing model in the next week or two...
Would you possibly consider sharing the .mdl with us? I always prefer
a nice CSG model rather than a bunch of triangles.
Alan - ako### [at] povray org - a k o n g <at> p o v r a y <dot> o r g
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> >i should be able to
in other posts, i've mentioned that i will. once it is done, i'll have
to do some house cleaning so you folks will know what the heck i did and
how to animate it. unfortunately, the fuselage is a mesh made in spatch
and then converted. everything else is csg. expect near-finished pics
soon. the mdl will come when it's done.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 23 May 2000 01:03:01 -0700 ryan constantine
Thanks, Ryan.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
