POV-Ray : Newsgroups : moray.win : Advice on Physical Light Sources Server Time
17 Jan 2026 18:04:30 EST (-0500)
  Advice on Physical Light Sources (Message 1 to 9 of 9)
Subject: Advice on Physical Light Sources
Date: 18 Feb 2000 09:26:01
Message: <38ad5679@news.povray.org>
Greetings,
My apologies if this is a frequent topic, but I could use some advice or
some direction on creating a visible light source (not sure what to call
it). Imagine, if you will, seeing a car at night - how do I model the
headlights so that they both interact with the scene and appear to the eye
as an object? Another example is an aircraft's navigation lights. I want to
see the actual light bulb, if you will.
Thank you.
Robert Leahey
Digital Metaphors Corporation
rob### [at] digital-metaphorscom
http://www.digital-metaphors.com
Subject: Re: Advice on Physical Light Sources
Date: 18 Feb 2000 09:51:46
Message: <38ad5c82@news.povray.org>
Create the bulb as an object with "no-shadow" and give it a texture with
ambient 1. Put the lightsource inside of the bulb. (You can group or
union them).
Or don't use a lightsource and use radiosity instead.
Johannes.
"Robert Leahey" <rob### [at] digital-metaphorscom> wrote in message
news:38ad5679@news.povray.org...
> Greetings,
or
call
eye
want to
> Thank you.
> Robert Leahey
Date: 18 Feb 2000 11:30:01
Message: <38ad7389@news.povray.org>
if you want a real headache try modelling an enclosed space - like an open
plan offlice building, no thats a nightmare to light !!
"Johannes Hubert" <jht### [at] nove-mailcom> wrote in message
news:38ad5c82@news.povray.org...
> union them).
> Johannes.
> > Greetings,
> or
> call
> eye
> want to
> > Thank you.
> > Robert Leahey
Date: 18 Feb 2000 14:55:38
Message: <38ada3ba@news.povray.org>
Thanks, I'll have a go at that...
Cheers,
Robert Leahey
Johannes Hubert <jht### [at] nove-mailcom> wrote in message
> union them).
> Johannes.
> > Greetings,
> or
> call
> eye
> want to
> > Thank you.
> > Robert Leahey
Date: 18 Feb 2000 16:25:38
Message: <38adb8d2@news.povray.org>
The usual way is like:
#declare Brightness=.75;
#declare VisibleLight=
 sphere {0,1 scale <1,1,.5> pigment {rgbf <1,1,.95,.75>}
  normal {granite .05 scale .05}
   finish {ambient <1,1,.95> phong .5 phong_size 1}
  interior {ior 1.5 caustics 1 fade_distance .75 fade_power 2}
 light_source {<0,0,0>,<1,1,.95>*Brightness
  looks_like {VisibleLight}
   fade_distance 3 fade_power 1
Then the object used is already implied to have 'no_shadow'; a texture can also
show up if you want.
Date: 19 Feb 2000 09:22:32
Message: <38ADE8BD.EB368F4B@t-online.de>
> Bob
Yo Bob!
That's the way I prefer it. But ASFAIK 'looks_like' is not supported in
Moray 3.2. (Hi Lutz. FEATURE REQUEST!)
Karl
Date: 19 Feb 2000 19:21:20
Message: <38af3380@news.povray.org>
"Karl Pelzer" <Kar### [at] t-onlinede> wrote in message
news:38ADE8BD.EB368F4B@t-online.de...
Wups, I gotta remember what group I'm posting replies in.
Date: 21 Feb 2000 12:01:54
Message: <38b16f82@news.povray.org>
Thanks for all the replies...
So I had a go at this this weekend, and the result is ok, but not quite
achieving the desired effect. I don't know if a lens effect is what I'm
looking for (I've tried a few they were all sort of overkill). I want the
light to glare a bit, or noticeably grow in intensity as it points closer to
the camera. The results I got this weekend were all pretty much the same no
matter where the camera was.
I guess the gist of this is, how do I model light that is traveling straight
to the camera without bouncing off anything? It seems that that is the glare
effect I'm looking for...
Cheers,
Robert Leahey
> union them).
> Johannes.
> > Greetings,
> or
> call
> eye
> want to
> > Thank you.
> > Robert Leahey
Date: 21 Feb 2000 23:25:23
Message: <38b20fb3@news.povray.org>
There's a chance that using a media atmosphere, scattering with type 5 which can
do eccentric (or directional) scattering, might accomplish what you're wanting
to do.
That way when the light source is closer to the camera or pointing toward it
then it should flare up brighter, and when further to the side not have any
"glare".
I checked on this with a regular non-spot light and it's doesn't seem possible
unfortunately.  Maybe a wide spotlight could be okay?  Just an idea.
news:38b16f82@news.povray.org...
| Cheers,
| Robert Leahey
| > union them).
| > Johannes.
| > > Greetings,
| > or
| > call
| > eye
| > want to
| > > Thank you.
| > > Robert Leahey
