POV-Ray : Newsgroups : moray.win : rotation Server Time
28 Sep 2024 21:17:26 EDT (-0400)
  rotation (Message 1 to 5 of 5)
Subject: rotation
Date: 6 Sep 1998 02:52:17
Message: <35f221ac.2750852@news.povray.org>
Transformations in Moray always happens in the same order , scale ,
rotate, translate. Is there a way to change this order?
Subject: Re: rotation
Date: 6 Sep 1998 06:08:27
Message: <35f2510b.0@news.povray.org>
Roland Vansteenkiste wrote in message <35f221ac.2750852@news.povray.org>...
No.
And if you think about it, it is the logical way too... :-)
Even the POV-Ray docs say somewhere, that this is the way one should create
his objects.
Johannes.
Date: 7 Sep 1998 01:37:31
Message: <35f361c9.1793659@news.povray.org>
On Sun, 6 Sep 1998 11:14:17 +0200, "Johannes Hubert"
>No.
>his objects.
In most cases it is . But suppose you want to ceate a simple roof with
tree  angles  of  60 degrees. The easiest way is to create a box
centered at the world origin rotate is 45 degrees , scale it properly
in the X direction and then translate it to its final location. In
Povray its easy but in Moray it seems impossible. Pitty
Date: 7 Sep 1998 03:28:56
Message: <35f374df.2294078@194.174.214.10>
Hi Roland,
here you are! Please, when you send email, make sure the Reply-To
header is setup correctly.
You can do this by placing the cube in a CSG, rotating the cube 45
degrees and scaling the CSG.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 8 Sep 1998 13:27:18
Message: <35F55A06.3BF0E186@ltu.edu>
Actually, it's not really impossible (but it is more work).  What you need
to do is create the box, rotate it 45 degrees, then add it to a CSG union
object.  Then scale and translate the union.  Granted, POV will complain
and say that you should have more than one object in a union, but this
will work.
-Nathan Kopp
