Maybe I have post this issue several years ago.
When I use mesh_camera to output a uv-map texture(for other 3D software), I
found that the rendered area is not enough, it should extend the render area.
Has these problem been solved?
attachment is POV-Ray's output.
Download 'bake solid wood.png' (1759 KB)
Preview of image 'bake solid wood.png'
When it applied to model:
Download 'test1 1024.png' (1063 KB)
Preview of image 'test1 1024.png'
We're going to need WAY more information to figure that one out.
What model are you using?
What is the POV-Ray scene and mesh camera setup you're using to generate your uv
map?
What uv vectors are being used to wrap the generated image for uv-mapping?
1. That's a pretty complex work flow, where SO many things can go wrong, if only
because of floting point precision, etc.
2. I'm sure people here would love to learn how to use this method for their own
work - thus ensuring that all of the tools needed to make this work get the
attention and fixing that they need!
- BW
Subject: Re: mesh camera ouput uv-mapping has a seam when I using the texture
Date: 14 Feb 2025 10:06:25
Message: <67af5bf1$1@news.povray.org>
Am 14.02.2025 um 11:32 schrieb And:
Jaime Vives Piqueres has written a work-around several years ago.
Fortunately, he has restored this part of his website:
http://ignorancia.org/index.php?page=mesh-camera
Best regards
Michael
> map?
> - BW
Every model it has this issue.
mesh_camera {
distribution_type 3
Because its color only covers the area of the model.
I show you a uv-mapping texture generated by Blender 3D:
Its color covers not only the area of the model, it generate a margin area, too.
It can control margin size (for this example I set 16 px), type("extend" or
using "adjacent faces")
Download 'block color.png' (469 KB)
Preview of image 'block color.png'
> Best regards
> Michael
Well, he(or she @@) has already pointed out the problem.
Date: 16 Feb 2025 14:54:34
Message: <67b2427a$1@news.povray.org>
Am 16.02.2025 um 10:14 schrieb And:
>> Best regards
>> Michael
I admit, his (Jaime is a Spanish variant of the name James) repair_seams
approach of smearing the textures is lossy and cannot always be used.
But it helps with his statuettes. I myself have only used it for such
purposes. But, if Blender helps, why not use it?
Best regards
Michael
> >> Best regards
> >> Michael
> Best regards
> Michael
Thank you.
Well, I have used Blender, I just ask the same situation here.
(I don't actually use 3D for any official purpose.)
