POV-Ray : Newsgroups : povray.windows : Accents in a string for 'uv_mapping' Server Time
5 Feb 2026 06:07:27 EST (-0500)
  Accents in a string for 'uv_mapping' (Message 1 to 9 of 9)
Subject: Accents in a string for 'uv_mapping'
Date: 1 Jun 2005 09:00:01
Message: <web.429db02b767e44eba6130c470@news.povray.org>
Hi everybody,
I'm working on windows XP, and I want to use French accents in a string with
'sys'  specific command for .bmp format in uv_mapping.
But I have some problem with it :
with acute) letter strangely
I read that I must specified :
global_settings {
 charset utf8
In order to work with special character like the French accents.
It work well for 'text' object (like in example ttf1.pov)
text { ttf "C:WINDOWSFontsarial.TTF", "Mu00e9tal" ...
But not with 'sys' command in uv_mapping !! (I have got the same problem
with 'gif' 'jpeg' and the others format.)
I have tried several things but in vain ( u00e9 ==  small letter e with
acute ) :
uv_mapping pigment {
 image_map{
POV Ray : Parse Error : Error opening BMP image ' C:WindowsTextureM l.bmp'
Why M...l ?
 image_map{
  sys "C:WindowsTextureMu00e9tal.bmp"
'C:WindowsTextureMu00e9l.bmp'
Ok so 'u00e9' is read as this.. But it is not what I want ...:o(
#declare Text =  "C:\Windows\Texture\Mu00e9tal.bmp"
  image_map{
  sys Text
POV Ray : Parse Error : Error opening BMP image 'C:WindowsTextureM tal.bmp'
And at last
  image_map{
  sys Text
POV Ray : Parse Error : Error opening BMP image 'C:WindowsTextureM l.bmp'
character ???
Has someone an idea ?
Any suggest that could help me is welcome.
Lionel
Subject: Re: Accents in a string for 'uv_mapping'
Date: 1 Jun 2005 09:37:43
Message: <429dba27$1@news.povray.org>
Lionel wrote:
> Hi everybody,
> global_settings {
>  charset utf8
> acute ) :
> texture {
>  image_map{
> Why M...l ?
> texture {
>  image_map{
> texture {
>   image_map{
>   sys Text
> And at last
> texture {
>   image_map{
>   sys Text
> character ???
> Lionel
Try charset ISO-8859-1 (Western) ... This may or may not solve the
problem, but its worth a shot, since I believe this is the charset most
windows files are saved in. It could also be a limitation of POV-Ray in
and of itself. Question: Does it work on PNG or JPG files? If so, it
could be a limitation of the BMP library POV-Ray is using.
~Mike
Things! Billions of them!
Date: 1 Jun 2005 09:38:18
Message: <429dba4a$1@news.povray.org>
Mike Raiford wrote:
> Lionel wrote:
>> Hi everybody,
>> string with
>> letter e
>> global_settings {
>>  charset utf8
>> acute ) :
>> texture {
>>  image_map{
>> l.bmp'
>> Why M...l ?
>> texture {
>>  image_map{
>> texture {
>>   image_map{
>>   sys Text
>> tal.bmp'
>> And at last
>> texture {
>>   image_map{
>>   sys Text
>> character ???
>> Lionel
BTW, do not include (Western), just ISO-8859-1 :)
~Mike
Date: 1 Jun 2005 10:40:00
Message: <web.429dc7d151f18563a6130c470@news.povray.org>
Hi Mike,
Thank you for this answer.
You propose to use charset ISO-8859-1, but is it for global_settings ? Like
this ;
global_settings {
  charset ISO-8859-1
or in a .ini file or other ?
Because in POV Ray for Windows Help in section 3.3.3.6  Charset
There exist only three type:
-"ascii only standard ASCII character codes in the range from 0 to 127 are
valid".
 This set is to restricted for me.
 -"utf8 is a special Unicode text encoding and it allows you to specify
characters of nearly all languages in use today. We suggest you use a text
editor with the capability to export text to UTF8 to generate input files."
 This doesn't work...
- The last possible option is to use a system specific character set. For
details about the sys character set option refer to the platform specific
documentation.
 Well, I don't know where I could find informations on it. Perhaps it is the
solution..
And no ISO-8859-1. (I tried it nevertheless, but a parse error occurs)
That's sad because it is certainly what I'm looking for !!
ISO-8859-1 contains, a priori, all character that I could find on French
Windows system file.
It is the same problem for jpeg & gif...
Sincerly,
Lionel
> ~Mike
Date: 2 Jun 2005 10:15:00
Message: <web.429f131651f18563a6130c470@news.povray.org>
Hi Mike,
Well,
The same problem occurs when I try to include a file with accents in its
name ...
works well
So it is not the call to the different image libraries but a specific
connection between POV Ray and Windows.
It seems that characters in a string representing a file name were not
interpreted or parsed with the charset specified in global_settings. It is
certainly not that ... :o(
static array of char, when it is searching for windows file (searching,
reading, etc...)
I will continue searching for it.
Sincerely
Lionel
Date: 19 Jul 2005 22:40:10
Message: <42ddb98a@news.povray.org>
#debug doesn't work with accents either.
Date: 20 Jul 2005 02:30:51
Message: <42ddef9b$1@news.povray.org>
Lionel wrote:
> Hi everybody,
> global_settings {
>  charset utf8
The "charset" keyword is for use with text strings only.  It is not for any
path or filenames.  All path or filenames should be in ASCII format.
     Thorsten Froehlich, POV-Team
Date: 20 Jul 2005 02:32:39
Message: <42ddf007$1@news.povray.org>
That is the correct behavior.  Output streams only support ASCII characters.
  Unsupported characters are replaced by whitespace characters.
Date: 20 Jul 2005 05:35:00
Message: <web.42de19b051f18563a6130c470@news.povray.org>
Thanks for this precision...
I had stopped searching for a long time... ;o)
Sincerly
Lionel
