Is there a way in the window editor to highlight matching <>{}() : When
your cursor is close to one opening brace {, the editor make the
matching closing brace blink or highlight or whatever. ( as found in
many editors in Windows or Unix)
When using a texture or a function with countless (){}, it is easy to be
lost when POV tells you that they do not match.
Fabien
Subject: Re: Matching braces, brackets and parentheses
Date: 10 Aug 2000 04:00:56
Message: <39926138@news.povray.org>
I'm glad I not the only one who has that problem. It would be very helpful.
Mick
news:3991D974.912623FE@club-internet.fr...
> Cheers
> Fabien
Date: 10 Aug 2000 04:17:55
Message: <39926563.E89F4CCF@aetec.ee>
> Cheers
> Fabien
You can use Search/Match Brace (or Ctrl-] as shortcut). This is not as
good as highlighting, for it moves cursor to matching brace, but it
helps sometimes.
Only problem here is that this shortcut does not work with national
keyboard, as for getting ] character AltGr has to be pressed and instead
of matching I get ] when pressing Ctrl-AltGr-].
> > Cheers
> > Fabien
> helps sometimes.
Yes, I noticed that too.
Fabien
If you use proper indentation it shouldn't be hard to see matching brackets.
Date: 10 Aug 2000 17:18:41
Message: <39931c31@news.povray.org>
I recall that Borland C++ used to momentarily bold the matching braces as
you typed allowing you to see the blocks of code you were editing. That
would be a nice feature for the Windows or Mac editor. ( do any of the other
platforms have integrated editors?)
I usually use good indentation practices, but sometimes I like to put one
short but complex expression on a single line and then the order of the
braces and parentheses can be confusing.
One other thing bothers me about the editor in Windows. Tabs don't seen co
come out as tabs. If you tab once, you have to backspace several times to
get back to where you were.
HH
Well, I do use indentation a lot, but when you get material { texture { ... down
to a color_map mixed with other normal_map, there's bound to be an error.
Fabien
Exel also does this when you are editing a formula.
> That would be a nice feature for the Windows or Mac editor. ( do any of the
> other
I think Mark was contemplating a Linux one
very true, me to
This is because you have set the option to convert tabs to spaces when typing.
Click on an editor tab, choose "Editor/Codemax properties" from the menu, click
on the "Language/Tabs" tab & uncheck the "Convert tabs to spaces while typing"
checkbox.
You would have to ask the POV-Team to make this change to their (donated) custom
version of the Codemax dll & include this in WinPOV 3.5 - I am under the
impression that the codemax's original author donated the src with this control
- is this true ?? If not you could suggest this to the author.
Also - Some WinPOV 3.5 feature requests.
- is there any chance that when the "Keep single instance" option is on and the
user opens a new instance of WinPOV with /EDIT on its command line that the file
will be opened in the already running instance. In 3.1g the running instance is
just brought to the foreground.
- when the "Keep single instance" option is on could new instances with /RENDER
or +i on their command line put these files in the render queue of the currently
running instance. In 3.1g /RENDER does the same as /EDIT & +i causes the
specified file to be rendered if the running instance is not already rendering
Bye
Pabs
: Well, I do use indentation a lot, but when you get material { texture { ... down
: to a color_map mixed with other normal_map, there's bound to be an error.
Again: A proper indentation should help.
material
texture
pigment
onion color_map
[0 rgb 0]
[1 rgbf 1]
turbulence .5
finish
specular .5 roughness .05
interior
ior 1.5
At least I can distinguish quite well matching parentheses there.
Date: 11 Aug 2000 05:45:05
Message: <3993cb21@news.povray.org>
Well throw in a few directives like #if #switch #while and the rest, along
with more of the possible keywords, and you might start losing sight of
those neatly ordered braces :-)
