POV-Ray : Newsgroups : povray.unofficial.patches : MCPov: Diffuse Reflection - UR Doin' it Wrong Server Time
19 May 2024 06:02:22 EDT (-0400)
  MCPov: Diffuse Reflection - UR Doin' it Wrong (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: MCPov: Diffuse Reflection - UR Doin' it Wrong
Date: 22 Nov 2009 09:45:01
Message: <web.4b094dd610ccfa8151b504a30@news.povray.org>
> As good as MCPov renders tend look - they're actually physically wrong.
> Have a look at this:
> The following images show a 100% white diffusely reflecting plane
> (actually a large slab; left side),...
> Reflection is perfect, i.e. 100%.
I don't think perfect reflection is physically possible.  100% white is tough
too.
Date: 22 Nov 2009 11:21:12
Message: <4b0964f8$1@news.povray.org>
> too.
Nonetheless computations with such theoretical maximum values give clear
indications about the general quality of an algorithm. As far as that
goes, MCPov apparently sucks: It can do no more than 50% white without
adversely affecting some feature or the other, and that's /definitely/
below even the /practical/ maximum.
Whole milk, for instance, ranges at around 85%. And special materials do
indeed achieve a diffuse reflectance of 99% and higher in the visble
spectrum (e.g. Labsphere Spectralon).
As for perfect specular reflectance, I only used it to create a
reference surface in the image anyway, but for instance water-to-air
interfaces come extraordinary close to perfect reflection.
Date: 22 Nov 2009 11:52:32
Message: <4b096c50@news.povray.org>
> too.
  Talk about missing the point... ;)
  The point is, if mcpov is rendering a 100% white surface wrongly, it's
probably going to render a 50% white surface (perfectly possible in the
real world) wrongly too.
Date: 22 Nov 2009 12:55:00
Message: <web.4b097a8310ccfa816672c09b0@news.povray.org>
> > too.
I think it's perfectly on topic:  how is a "physically-based" renderer supposed
to behave in the face of a situation beyond the realm of physics?  Perhaps they
should do some phong shading?
Date: 22 Nov 2009 13:05:07
Message: <4b097d52@news.povray.org>
  So he should have used eg. 50% white instead of 100% to keep you happy?
Date: 22 Nov 2009 13:20:01
Message: <web.4b0980c510ccfa816672c09b0@news.povray.org>
95% white is ok, I guess, but I'm more concerned about the 100% reflexive
surface.
Date: 22 Nov 2009 13:22:55
Message: <4b09817f$1@news.povray.org>
If physics has a /theoretical/ answer to a certain limit-case situation,
then a "physically-based" renderer should end up producing exactly that
answer when confronted with that case - or at least approach it.
What, btw, has phong shading to do with the test setup??
Date: 22 Nov 2009 13:35:01
Message: <web.4b09844210ccfa816672c09b0@news.povray.org>
I see.  What I see from physically-based renderer forums though is that in the
face of extreme conditions like that (way too high, unrealistic reflectance for
instance) renders tend to break and be very poor and noisy.
It's called irony. :)
Date: 22 Nov 2009 14:11:49
Message: <4b098cf5$1@news.povray.org>
This is not a case of an algorithm becoming too noisy: This is a case of
an algorithm returning too dark colors. The phenomenon of MCPov getting
the brightness wrong by a factor of 2 is not just limited to 100% white
surfaces - I just chose that particular level of reflectivity because it
is easy to model a reference surface for it.
Date: 22 Nov 2009 14:25:00
Message: <web.4b098f4910ccfa816672c09b0@news.povray.org>
ah, well.  Then it's a bug alright.
