POV-Ray : Newsgroups : povray.unofficial.patches : Tessellation Server Time
27 Jul 2026 02:29:31 EDT (-0400)
  Tessellation (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Tessellation
Date: 10 Oct 2001 16:46:11
Message: <3BC4B392.623DED52@free.fr>
>   I have been thinking about using the marching triangles algorithm in the
> tesselation patch, as I think it gives much better results than marching
> cubes/tetrahedrons.
	I guess the problem with "marching" algorithms is the fixed step
used to sample the space; even if you try using an adaptive method, as
supersampling. While Delaunay triangulation - if possibly implemented in
a tesselation procedure - would give triangles of different sizes according
to the local complexity of the scanned object (so leading to the curvature
dependant tessellation discussed earlier). Triangles are not required to have
vertices of the same size; complexes shapes give small, numerous triangles,
while relative flat shapes give just a few large triangles. This could in
principle give good results even for simple flat objects, e.g. cubes,
including at the edges.
	I guess Christoph Hormann was actually thinking about this kind
of method, since AFAIR it starts from a point and expands in any direction.
	By the way, I don't think it would be a good idea to change the
tessellation accuracy according to distance from viewpoint, simply in
order to save memory. Tesselation can be made just once, for instance
in an animation. And that's much better for exporting (probably one of
the main purpose actually).
	- NC
Date: 10 Oct 2001 16:53:40
Message: <slrn9s9dam.a0h.ron.parker@fwi.com>
I think you're thinking of something besides Delaunay triangulation.  That's
a purely 2d technique and has nothing to do with meshes.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 11 Oct 2001 09:26:29
Message: <3bc59e05$1@news.povray.org>
You all are talking about problems very well known to engineers. We use to
call this kind of operation as 'meshing an object'.
I'm looking for some papers I've read about the problem of meshing for
Computational Fluid Dinamics problems as soon as I can find them I will
publish them on my internet site and advise you all.
Massimiliano Cirri
_____________________________________________
Eng. Massimiliano Cirri
Ph.D. Student
Department of Energetics "Sergio Stecco"
e-mail: m.c### [at] ingunifiit
tel: +39 055 4796239
fax: +39 055 4796342
private fax: +39 02 700 544 824
"Ron Parker" <ron### [at] povrayorg> ha scritto nel messaggio
news:slr### [at] fwicom...
according
That's
1/3}[.5F
opinions
Date: 11 Oct 2001 10:40:28
Message: <3BC5AF58.F7057D3E@free.fr>
	Mhhh, guess you're wrong, sorry.
	Delaunay triangulation is commonly used in 3D (and maybe more dim.)
to create meshes from different kind of data, e.g. a cloud of points. I had
got a lot of internet references when looking at a related problem (mesh
simplification) but unfortunately lost all while moving. Probably worth to
search again since there might have new stuffs appearing  :o)
	- NC
Date: 11 Oct 2001 11:37:08
Message: <slrn9sbf55.cj4.ron.parker@fwi.com>
But it's not triangulation in that case; it's a more generalized sort of
related thing involving solids.  The whole idea of triangulation doesn't
make sense unless all of the points are in a plane, because the notion of
"none of the other points fall in the circumscribed circle" doesn't make
sense.  You can construct a Voronoi diagram of sorts in 3-space and then
take something that resembles a dual of that, but it wouldn't be quite the
same sort of dual (because it swaps volumes with vertices and faces with
edges, rather than the 2d version that swaps faces with vertices and has a
1:1 correspondence between the two sets of edges) and it shouldn't be
called a Delaunay triangulation (if for no other reason than that the
mathematically interesting part of the result isn't the triangles, but the
solids that they bound.)
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 11 Oct 2001 11:40:42
Message: <slrn9sbfbs.cj4.ron.parker@fwi.com>
Here's a good place to start (and they call the 3d process tetrahedralization,
which is a better word.)
http://www.ics.uci.edu/~eppstein/pubs/geom-tri.html
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 11 Oct 2001 14:43:04
Message: <3BC5E837.961D789F@free.fr>
	Okay, I won't discuss about terminologies since my skills in maths
are fairly limited, not yours  ;o)  I was just recalling about those possi-
bilities of constructing meshes in a similar way the Delaunay triangulation
works (and yes I remember about the relation with Voronoi diagrams)
> [from your second answer]
	Fine for me. Now I feel a bit more mathematician  :o)
	Wow, I forgot that D. Eppstein works on so many things... I actually
did some recent (and current) work using graph theory and did not remind that
he was also publishing on this mesh problems. I'm sure this link it basically
the first one I found at that time... Thanks for pointing it out again !
	- NC
Date: 11 Oct 2001 15:02:41
Message: <slrn9sbr6j.cn1.ron.parker@fwi.com>
I have to confess that I'm an afficionado of his Geometry Junkyard; I'm
always scrounging around there looking for stuff I can turn into cool
textures or primitives or whatever.  Lately I've been slumming in the
"tilings" section, trying to get up the nerve to write a penrose pattern.
(For those playing along at home, the Geometry Junkyard is at
http://www.ics.uci.edu/%7Eeppstein/junkyard/topic.html )
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 11 Oct 2001 18:00:06
Message: <Xns913847D18Cseed7@povray.org>
> pattern.
Pure penrose or this n-dimensinal quasicrystal thing?
http://www.math.ubc.ca/~robles/tiling/quasitiler.html
http://www.math.ubc.ca/~robles/tiling/quasiinfo.html
Ingo
Date: 12 Oct 2001 09:04:58
Message: <slrn9sdqjr.fkv.ron.parker@fwi.com>
>> pattern.
Penrose tiles are a subset of the quasicrystals, so I'd obviously go with
the more general case.  But of course I won't have time to even think about
that until after 3.5.
