POV-Ray : Newsgroups : povray.unofficial.patches : What software do *YOU* open and edit 48bpp images with? Server Time
6 Oct 2024 12:27:47 EDT (-0400)
  What software do *YOU* open and edit 48bpp images with? (Message 1 to 10 of 19)
Subject: What software do *YOU* open and edit 48bpp images with?
Date: 11 Sep 2001 13:01:46
Message: <UUGeO2+lfRigGcT=HKxECjb0RrNf@4ax.com>
Ok, after getting a good dose of negative comments about trying to
make POV-Ray and Photoshop more compatible, in regards to 48bpp
images, I have one burning question in my mind:
What image editor (available for Windows) will open and properly edit
a POV-Ray 48bpp image?
By "properly", I mean it will open the image in 48bpp mode, not 24bpp.
It will be able to perform "curves" and "levels" operations on the
48bpp  image. It offers a 24bpp preview on my monitor. It can convert
the 48bpp image to a standard 24bpp file, after I am done tweaking the
curves or levels.
So what software do I use? What software do *you* use?
I'd really like to know.
Thanks,
Glen
Subject: Re: What software do *YOU* open and edit 48bpp images with?
Date: 11 Sep 2001 13:21:39
Message: <Xns9119C4F32AEC7seed7@povray.org>
 Imagemagick, don't know what 'curves stuff' it can do as I mainly use
it for simle things from commandline. Just tried adjust of brightness
and it works, with 48bit PNG input from POV-Ray, the output is also
48bit.
 For viewing with Imagemagick you'll need an x-server. I use cygwin/x-
free, but there seem to be pure windows solutions.
Ingo
Date: 11 Sep 2001 13:40:28
Message: <slrn9psj4f.mc4.ron.parker@fwi.com>
Photoshop will, if you use ppm format and tell Photoshop that it's
really a raw image.  See Kari's post about this somewhere around here.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 11 Sep 2001 17:16:55
Message: <mnyeO=beu2uM61syz5wuRJkYLMC9@4ax.com>
On 11 Sep 2001 13:40:28 -0400, ron### [at] povrayorg (Ron Parker)
Unfortunately, I only have Photoshop 5.0 LE, and not the full package.
I tried Kari's suggestion, but my "LE" version of Photoshop won't open
RAW format images, at least as far as I can tell.
It will open 16 bit per channel images in the PSD and TIFF formats,
but I see no support for any "RAW" formats at all, 16 bit or
otherwise. I also checked for "PPM" and couldn't find any support for
that either.   :(
Later,
Glen
Date: 11 Sep 2001 17:21:25
Message: <slrn9pt02o.mo1.ron.parker@fwi.com>
>that either.   :(
In that case, perhaps you can use a recent build of the PBM utilities to
convert POV-generated 16-bit images in PNG or PPM format to TIFF format.
You can find Windows binaries at the URL below, but I note that they are
for version 9.14 rather than the current 9.18 and I'm not sure if they'll
have support for what POV calls a 16-bpp PPM.  Can't hurt to try, though.
  http://gnuwin32.sourceforge.net/packages/netpbm.htm
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 11 Sep 2001 17:30:28
Message: <jYCeO+qp8u2fGgBjrjRk3UZHE4Cu@4ax.com>
On 11 Sep 2001 17:21:25 -0400, ron### [at] povrayorg (Ron Parker)
Thanks for the suggestion. I'll give it a try a bit later.
I don't know about anyone else, but here in West Virginia, I'm having
trouble reaching a lot of internet sites today. I suspect it has
something to do with the terroist activity earlier today, in NYC and
Washington, DC. Suprisingly, I can access the New York Times website
without too much difficulty, but this news group for example, is only
accessable about one in every thirty attempts. Even when I can get
access to this server, it doesn't last for very long. If only the
internet slowdown was the worst problem anyone faced today...
Later,
Glen
Date: 11 Sep 2001 21:27:24
Message: <3B9EF244.B6B8B7F0@chesapeake.net>
I thought that PaintShop Pro might. But I cant even verify that
the files are other than 24 bpp. No mater how I set the option
for pixel depth (+fn5 to +fn16) PSP always shows a 24 bpp/16 million
color report when I ask for image information.
Is it something with POVRay or PSP?
> curves or levels.
> Thanks,
> Glen
Date: 12 Sep 2001 11:20:58
Message: <3b9f7d5a$1@news.povray.org>
"Glen Berry" <7no### [at] ezwvcom> wrote in message
news:UUGeO2+lfRigGcT=HKxECjb0RrNf@4ax.com...
Does Gimp work with 48bpp? It seems to open 48bpp png's okay.
Date: 12 Sep 2001 11:50:54
Message: <3B9F8438.3E44BD90@geocities.com>
IIRC, the Gimp will open 48bpp, but will only actually use and work in
24bpp +alpha.
For 16bpp, you'd have to look to the 'hollywood' branch
http://film.gimp.org/
Wind the Frog!
Date: 13 Sep 2001 04:55:46
Message: <3ba07491@news.povray.org>
Mr. Art <mra### [at] chesapeakenet> wrote:
: Is it something with POVRay or PSP?
  Does the image file size grow when you use more bits per pixel? If so,
that's a quite clear sign that povray is working ok.
