POV-Ray : Newsgroups : povray.unofficial.patches : MegaPov 0.4 Now Available (Windows/Macintosh) Server Time
16 Mar 2026 09:35:11 EDT (-0400)
  MegaPov 0.4 Now Available (Windows/Macintosh) (Message 13 to 22 of 32)
Subject: Re: A trivial #version conundrum
Date: 30 Jan 2000 19:39:33
Message: <3894d9c5@news.povray.org>
In article <3894D0C0.CBF01B51@enter.net> , Charles Fusner
<cfu### [at] enternet>  wrote:
> ...won't change this behaviour even though setting...
> "#version official 3.1;"
You should be able to continue to use the "#version 3.1;" for backward
compatibility with the official 3.1 parser.
> in, it apparently automatically sets itself for version 3.00 which
> of course kills the #macro directive.
It still sets itself to 3.1, so this is either a bug (or a precision
problem).
     Thorsten
Subject: Re: MegaPov 0.4 Now Available (Windows/Macintosh)
Date: 31 Jan 2000 05:20:14
Message: <qqm1z6yee5e.fsf@schlatt.fmi.uni-konstanz.de>
sme### [at] skynetbe (smellenbergh) writes:
> MegaPov 0.4 is ready for downloading.
> You can find Nathan's Windows version at (this is not the usual place!):
> ftp://ftp.povray.org/pub/povray/Unofficial/MegaPOV/
> The Macintosh version at the usual site:
> http://users.skynet.be/smellenbergh
First, let me thank you for the time that you invest in the megapatch.
In frame.h it says:
    #define CLOCKDIVIDER CLK_TCK /*provided by standard c? */
and as far as I know the answer is "No". According to the documentation
available to me, you should use CLOCK_PER_SEC instead and include <time.h>.
In postproc.c there are two //-comments. Remove the lines or comment
them out with /* */.
In tokenize.c I have removed the "Not-quite-so-Static" function declarations.
Now, only the static declarations exists.
With these changes it compiles flawlessly under Sun Solaris using gcc.
You can dowload the modified version including the Makefile at
http://www.povray.willhalm.de/povaddon/
http://thomas.willhalm.de/ (includes pgp key)
Date: 31 Jan 2000 05:56:14
Message: <38956a4e@news.povray.org>
Yes, I use Ron Parker's brick wall code. Shouldn't it run with MegaPov 0.4?
What #statements should be present?
Sander
Ken <tyl### [at] pacbellnet> schreef in berichtnieuws
3894ABB8.FA864E23@pacbell.net...
> Did you by any chance check it against the code Ron Parker recently
> posted in povray.text.scene-files ? That code is known to work with
> earlier versions.
>     Subject:  Re: Brick wall and paving stones macros (~80kb)
>        Date:  19 Jan 2000 10:15:35 -0500
>        From:  ron### [at] povrayorg (Ron Parker)
>  Newsgroups:  povray.binaries.images, povray.text.scene-files
>  Followup-To: povray.text.scene-files
>   References: 1 , 2 , 3 , 4
Date: 31 Jan 2000 18:50:09
Message: <38961FDE.38E9E839@enter.net>
"mr.art" wrote:
> I have used the #macro statement without any problem.
> I did have to set  #version unofficial MegaPov 0.4; to
> get isosurfaces to work, but that was all.
> I am using WinMeagPov0.4. Are you on a different os?
No, WinMegaPOV0.4 here. The only thing required to (reliably)
reproduce the problem for me is that I have to pull the...
Version=3.1
...out of my INI file. When this is done, without expressly
saying "#version official 3.1;" before the macro definitions
causes them to fail with the following error message:
C:\C_wip\test.pov:1: error: Macros require #version 3.1 but #version
3.00 is set
I may be the only person this even affects, of course.
I imagine most people keep the Version=3.1 in their INI
even though logically, it seems to me it should be
useless since the default version compatibility should
logically be the latest syntax. I would think the only
time Version should be needed in an INI is if you are
distributing a custom INI designed to render a piece of
"legacy" POV code, and even then, it would normally be
unneeded, since you could always use #version in the code
itself more effectively.
Anyway, just thought I'd mention it in case anyone else
sees a similar problem. The solution is just to add the
"Version=3.1" back to your INI file. It's weird, but not
a show stopper.
Charles
Date: 31 Jan 2000 18:56:17
Message: <3896214F.9BBB720D@enter.net>
Yup, that also works. I was just keeping in the spirit of the
new syntax in the MegaPOV docs <g>.
> problem).
The only way I can reliably reproduce the behaviour is to yank
"Version=3.1" from my INI file, and since I would think the parser
would naturally assume version 3.1 until told otherwise, I'm
inclined to agree its a bug. A very very tiny one with an easy
workaround though, so I'm just observing, not complaining.
Charles
Date: 31 Jan 2000 19:43:30
Message: <38962c32@news.povray.org>
In article <3896214F.9BBB720D@enter.net> , Charles Fusner
>> problem).
The parser sets 3.1 but sometimes precision comes in the way and a compiler
stores (= presets) 3.1 as 3.09999999.  The code correctly initialises to 3.1
so that is the likely cause as this has also been a problem with certain
compiler settings for the official 3.1, at least on Macs.
       Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 1 Feb 2000 11:18:43
Message: <3897068A.7984E169@my-dejanews.com>
> New in this version:
>   *Chris Huff's blob pattern, proximity pattern, evaluate pigment/pattern, noise3d.
Days when new pov versions arrive are like Christmas :)
I have used noise3d, however, in 0.3.  Was there some kind of change to this function?
Date: 1 Feb 2000 15:30:12
Message: <chrishuff_99-0CB7D2.15310201022000@news.povray.org>
In article <3897068A.7984E169@my-dejanews.com>,
> this function?
I wrote a patch which allows it to be used in normal POV-Ray script,
instead of only in isosurface functions.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 1 Feb 2000 15:44:23
Message: <389745a7@news.povray.org>
Sander <san### [at] stolscom> wrote...
> Maybe I forget something, but the 'reset-children' feature doesn't work
even
> after adding the #version etc. line. What do I do wrong??
What does 'not work' mean?  Do you get a #version-related error message, or
does it parse and then not function.
-Nathan
Date: 1 Feb 2000 15:47:17
Message: <38974655@news.povray.org>
Charles Fusner <cfu### [at] enternet> wrote...
> While I'm on the subject, I'll mention here for the benefit of
> anyone else who doesn't bother putting Version=3.1 in their INI
> files (like me, duh!), if you don't tell MegaPOV anything going
The default should be 3.1.  Do you have Version=3.0 in an ini file
somewhere?  Otherwise, it might be a round-off error.
> For some reason, setting ...
> #version unofficial MegaPov 0.4;"
Just "#version 3.1;" will work.  The word "official" will disable the
unofficial features, but if you don't use the word "official", then the
unofficial features will remain activated.
-Nathan
