POV-Ray : Newsgroups : povray.unix : QTPOV Editor v0.3.0 stable Server Time
10 Jun 2026 18:53:52 EDT (-0400)
  QTPOV Editor v0.3.0 stable (Message 1 to 10 of 15)
Subject: QTPOV Editor v0.3.0 stable
Date: 21 Mar 2004 11:08:09
Message: <405dbde9@news.povray.org>
the stable release of qtpoveditor v0.3.0 has been published. The
ressources package have also been updated with a new help.
CHANGES :
v0.3.0 stable
* correction of some bugs (or possibilities) of previous version
* completion of help
* added help tool in the ini assistant
* added file chooser
* modification of source code in order to be fully compilant with other
platefor
ms
binaries :
http://sourceforge.net/project/showfiles.php?group_id=92021&package_id=110073&release_id=225324
sources :
http://sourceforge.net/project/showfiles.php?group_id=92021&package_id=110070&release_id=225327
ressources :
http://sourceforge.net/project/showfiles.php?group_id=92021&package_id=110071&release_id=225319
Thierry
http://qtpoveditor.sf.net
Subject: Re: QTPOV Editor v0.3.0 stable
Date: 22 Mar 2004 11:31:16
Message: <405f14d4$1@news.povray.org>
"gRRosminet" <pov### [at] les-charlesnet> wrote in message
news:405dbde9@news.povray.org...
> CHANGES :
> v0.3.0 stable
> platefor
> ms
Good timing :) I brought my laptop to work today, so I can download it and
try it out finally.
ross.
Date: 22 Mar 2004 16:04:10
Message: <405f54ca$1@news.povray.org>
Just had a quick try (no time for a deeper look into the new version,
yet), but here are some things I noticed:
- Binaries would not run on my Mandrake 9.2 (segfault). No problem,
though, compiling worked without any problems.
- The tab-bug of the former version seems fixed (in the last version,
the cursor jumped in the middle of the word if you tabbed the word,
therfore making two or more tabs impossible). Thanks for that :)
- The ini-editor seems very mighty and it's cool that it covers all the
options. However I think it might be to mighty for only quick changes. I
loved the old configuration tab (especially antialiasing, command line,
quality and resolution). Perhaps something like giving some simple
options (like the old ones) directly on the panel and add a button
labeled "more options" which shows the full editor.
More comments when I got time to really work with your app!
Florian
P.S.: I really appreciate the work you're putting into this!
Date: 22 Mar 2004 16:50:30
Message: <405f5fa6$1@news.povray.org>
=> I don't know how to built a binarie that works one every palterforms.
the binaries that I have done where built on mdk 9.1 with QT 3.2.3
=> I was bored too ;-P
=> In fact, you can quickly create an ini file with assistant : create
new ini, click on refresh, click on assistant set width, height, AA and
source file name. Click on OK and save it ... I think it's quick enough
and as you can modify the source of the ini and give extra parameters in
the "ini to use" combo, the old system won't be restored.
> Florian
=> Thanks :)
Date: 22 Mar 2004 17:54:23
Message: <405f6e9f$1@news.povray.org>
news:405f5fa6$1@news.povray.org...
> > Florian
> => Thanks :)
FYI, the binary worked on slackware 9.1 with QT 3.2.1. I'm going to build
from source later. I just wanted to see if it ran :)
Also, as a suggestion to the documentation for people who are not really big
on QT development on linux, simply want to try out your applicaiton, it
might be good to say how they can check to see what version of the QT
libraries they have installed. I don't know if this is a general solution,
but "kde-config -v" displays relevant information.
i'll tinker more with your editor later. thanks for the updates.
ross.
Date: 25 Mar 2004 03:45:35
Message: <40629c2f$1@news.povray.org>
gRRosminet <pov### [at] les-charlesnet> wrote in message
Hmmm, maybe I'm missing something obvious, but how do I tell it where the
help files are?  It only looks at http://qtpoveditor.sf.net
Somewhere local would be nice...
RG
Date: 25 Mar 2004 11:42:14
Message: <40630be6@news.povray.org>
A copy of the help is in the ressources package. If you want to use them
instead of the online version, y'ou'll have to modify line 506 in file
"poveditmainwindow.ui.h"
> RG
Date: 25 Mar 2004 16:21:04
Message: <40634d40@news.povray.org>
Excellent work, thank you for this editor! It compiled without problem
under linux slackware 9.1, gcc 3.3.3, qt 3.2.3. I use it every day now.
Here is the list of my wishes (is this the right place to post them?):
1. Insert menu entries are not recursive. I mean if the insert menu path
contains a deep structure of directories only the first level *.txt
files are displayed in the insert menu (see below)
2. When quitting, even if all files are saved, the editor keeps asking
about open files and if it should save some of them. When there are
unsaved files, this is the normal behavior, but otherwise is somewhat
annoying.
3. It would be nice to have a small preview for the insert menu items
where there is a *.bmp file available (standard windows povray
distribution does that) - it helps a lot the beginners like me :-)
(maybe also an option somewhere to disable this feature if it is
annoying for more experienced users)
4. after running povray it shoud be nice to have a non modal windows
displaying the resulted image. Right now I use am image viewer and
refresh the image every povray run, but again, it is a little bit
annoying. Kpovmodeler has a window like this which displays the image
being rendered while it is rendered, with a progress bar and a speed
indication (in kpixels/sec). I know kpovmodeler is a kde program, but
maybe Qt can do that also.
Concerning the first point, I wrote a (very) small patch to parse
recursively the insert menu path and display *.txt files found as nested
menu items. I use insert menu add-on(s) from Friedrich Lohmueller site
and some others and the directory structure is recursive many times deep.
If anyone is interested, drop me a mail.If Thierry accepts patches maybe
I can send it to him (it's really a small modification).
Happy raytracing for all!
Marin
Replay-to address is fake. Please replace it
with mferecat (at) numericable (dot) fr.
Date: 26 Mar 2004 01:37:49
Message: <4063cfbd@news.povray.org>
Thanks, I'll check it out.  The online help is too unreliable on my
tempermental dial-up.
This would be good to have as an option in the preferences.
Everything else looks great! Thanks for your considerable effort!
RG
Date: 26 Mar 2004 14:48:56
Message: <40648928@news.povray.org>
 > maybe I can send it to him (it's really a small modification).
==> Of course I want it ! actualy, I was realy hurry ti get something
working, but I can remember that doing something recursive would not be
a hard work to do it. I'll integrate it into the source if you've done it !
> annoying.
==> I know, I know ... this was the easiest solution. I think I'll do
something for this
==> If you do it, it'll be integrated, but I don't think I'll do it
(previews are frequently non-representative)
==> Of course, this can be done using QT. Personnaly, I use the povray
output with the "Pause when done" option. Perhaps a viewer could be added.
