POV-Ray : Newsgroups : povray.unix : Pyvon 0.99 released Server Time
10 Jun 2026 21:19:24 EDT (-0400)
  Pyvon 0.99 released (Message 1 to 10 of 13)
Subject: Pyvon 0.99 released
Date: 9 Sep 2002 15:44:22
Message: <3D7CE52D.2040407@caramail.com>
at :
http://pyvon.sourceforge.net
Pyvon now 'speaks'
- English
- French
- German ( thanks to Bonsai)
- Spanish (thanks to John Coppens)
- Italian (thanks to Alf and Martone)
- Dutch (thanks to Ingo)
The problem with the spaces in file name has been worked around ( thanks
to Roz trick)
The compiled file run by the starting script is about 10-15 % faster
than the original file.
Below is part of the readme file :
c94 - 09/09/2002 - Pyvon 0.99
Added the GPL2 licence in the archive
c93 - 09/09/2002 - Pyvon 0.99
Pyvon now renders files with space in their name (thanks to Roz), even
if the normal command line doesn't.
The optimized version is included in the archive.
c92 - 06/09/2002 - Pyvon 0.98
Added Dutch language
Added Spanish language
c91 - 04/09/2002 - Pyvon 0.97
If an error occurs because of an include that is already open, Pyvon
automatically swtich to that file and highlight the error
c90 - 04/09/2002 - Pyvon 0.97
If an error occurs because of an include file that is not open, Pyvon
automatically opens that file and highlight the error.
Fabien H
Subject: Re: Pyvon 0.99 released
Date: 9 Sep 2002 19:35:40
Message: <slrnanqc1p.m2m.steve@zeropps.org.uk>
On Mon, 09 Sep 2002 20:15:09 +0200, Fabien HENON wrote:
> at :
> Pyvon now 'speaks'
> - English
> - French
Doesn't matter how many languages it speaks if the install instructions
are incorrect it's not going to work.
- Untar the archive in a directory where you have writing rights
$ tar -xzvf Pyvon_0.99.tgz
OK so far.
- Type ./Pyvon in the console
$ ./Pyvon
bash: ./Pyvon: is a directory
So this doesn't install Pyvon does it, it just untars the tarfile
into a directory called Pyvon.
Where does it put the Pyvonrc file that I've heard you mention in this
group and what is the syntax for that file?  In the readme file it talks
of a pyvon.ini file?  I've had a look in my home directory and none of
the files are there even after running Pyvon.
I don't want to discourage you from working on this but feel that these
basic issues need sorting out.  A real configure and install script would
be good.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 10 Sep 2002 02:53:41
Message: <3D7D963A.9030905@caramail.com>
>>at :
>>Pyvon now 'speaks'
>>- English
>>- French
> OK so far.
> $ ./Pyvon
Ok, I forgot to add a cd Pyvon.
That commands is a script
It creates a hidden file .pyvonrc in your home directory. ( or it should
I have not heard of any problem or bug so far on this issue.
pyvon.ini was the former file used by Pyvon. I may have forgotten to
remove it if it's mentionned in a readme file.
Writing software times a lot of time already.
> be good.
An install script just to untar an archive ! I don't see what's the point.
A script is good when you have to configure, compile and  move your
libraries into the proper directory.
In the present case, everything you need is in a single directory. Just
type the name of the only file that has executable chmod and that's it.
When you exit from Pyvon, the software does it all for you ( write your
parameters and preferences in your home directory).
Fabien H
Date: 10 Sep 2002 04:51:46
Message: <slrnanrcjt.nev.steve@zeropps.org.uk>
>> be good.
Why shoudn't the components of Pyvon go into the proper directories?
Why isn't the executable put into a bin directory that's in the search
path?  Why are all the other files in the same directory instead of in
their own lib directory?
Yes but to use it you have to go to that directory first becasue you don't
install it into anywhere useful, ie there is no install scirpt and no
reasonable install instructions.
The documentation is every bit as important as the software.
Ok I see the RC file now, but you don't keep to a naming convention,
firstly you call the executable Pyvon and you put it in a directory (that
could be anywhere), called Pyvon but call the rc file .pyvonrc with a
lowercase "P".
                                             or http://start.at/zero-pps
  9:44am  up 74 days, 20:09,  2 users,  load average: 1.10, 1.09, 1.02
Date: 10 Sep 2002 05:24:33
Message: <3D7DBA51.30404@free.fr>
> lowercase "P".
	While in principle I agree with these two points, I would suggest
that you help Fabien creating this install script for him. Sounds that it
would be more useful than flamming  :-)
	By the way, any executable should not start with uppercase letter,
which is otherwise very annoying. I would adopt the same rule for the
package name as well.
Date: 10 Sep 2002 15:30:58
Message: <3D7E4752.9070102@caramail.com>
>>>be good.
What do you propose ? /usr/local/bin ?
Besides, users can install Pyvon in the directory they want.
> path?
I am not a Linux Guru. To know which directories are in the search path,
there is the variable $PATH (or something like that), but afterwards,
how do you deal with.
I much prefer to go for simplicity and play safe : I put all the files
into the same directory.
That may not be neat, but it 100 % safe and it works.
I do not count the times I compiled sources of a software and ended up
with an error because some mysterious library from some unknown package
is missing. I have used Linux for 2 years, and there are still many dark
corners to me.
First, there are no lib files, just the equivalent of include files for Pov.
Second, I did try to put the menu_*** files into a sub-directory. But to
no avail. I have to ask a Python newsgroup how to do that.
The other solution is to move those menu_*** into the Python directory.
But I can not be 100 % certain that it is always located in the same
directory on every system. Besides, I don't want to tamper with people's
system by moving files where they are not meant to be.
If an user wants to install a newer version or to get rid of Pyvon, they
  just have to delete its directory. There won't be anything left of it.
I'll try to copy the starting script into /usr/bin and make a link to
/usr/local/pyvon, and see how it works
I have already replied that I forgot to add the 'cd Pyvon' command in
the installation.txt file. I'll try to fix that tonight.
I should have waited a few more days before releasing this version and
spending more time checking the files. I would not have got this kind of
flaming.
I have the impression to work on a on-line help-desk and that you are
calling for a software that you paid for and that is not working.
As far as I know, it is working on your system.
Ok, I have forgotten a few things through an oversight, but I am doing
this on my free time, and it is freeware.
I you want to make an installation script, go ahead, I would be glad to
see one working. I do not know enough shell instructions for that.
> lowercase "P".
Ok, I agree with that. I'll remove the uppercase P of both the directory
and the starting script.
Fabien H
Date: 10 Sep 2002 15:32:55
Message: <3D7E482D.9080704@caramail.com>
>> lowercase "P".
I agree, it would be a bit more constructive.
Ok, I'll remove the uppercase letter P in both the starting script and
directory.
Fabien H
Date: 10 Sep 2002 16:42:22
Message: <slrnansm93.op8.steve@zeropps.org.uk>
> flaming.
I had no intention of flaming anyone.  I just won't comment on it any
more.
Date: 11 Sep 2002 00:55:04
Message: <3D7ECD06.9000304@netscape.net>
Fabien HENON wrote:
> at :
Wow, you've put a lot of work into this Fabien. I had no problems
downloading it and installing it following the directions on the
installation page on your web site. I noticed you already changed
the filenames to be all lowercase. I think that's easier for
people to deal with. You'll probably want to update the installation
page with all lowercase command examples too if you haven't already.
The screen split nicely between the editing window and the streams
window. I opened a filename with a space in it and it rendered
fine. I tested some of the stuff from the insert menu and that all
worked wonderfully as well :)
The only problem I had isn't a big thing, just a little odd. If I
ctrl-c a line of text near the top of a file, then ctrl-v a line
or several lines below, the whole file in the editor window scrolls
down about a screenful. Another odd thing with copy-pasting is
if I copy a line, then paste it, then cut (ctrl-x) a different
line and paste it, I end up pasting the earlier line I had copied,
not the cut line. I hope that makes sense ;)  It's as if the
ctrl-x operation is not replacing the copy buffer.
All in all I'd say the program is working really well :)
Btw, I'm running it under Redhat 7.1 if you're interested.
-Roz
Date: 12 Sep 2002 18:50:32
Message: <3D811987.5030509@caramail.com>
I changed my mind about an installation script.
I compiled an rpm on my Mandrake system. I'd like to know how it works
on your system.
Fabien H
Roz wrote:
> Fabien HENON wrote:
>> at :
> -Roz
