POV-Ray : Newsgroups : povray.text.scene-files : Golf Ball Help Server Time
17 Nov 2025 07:47:16 EST (-0500)
  Golf Ball Help (Message 1 to 9 of 9)
Subject: Golf Ball Help
Date: 18 Jun 2007 18:05:02
Message: <web.467700fa911d3421793de9de0@news.povray.org>
Hey World,
Well, you have gotten me started on CGSphere stuff.  I'm trying to model a
small scene, but I have gotten stuck early on.  I am attempting to model a
golfball, but I can't find any resources on one.  I just can't seem to
figure out how to get the dimples on the ball.  I can get one row, but then
I still have tons others to hand place.
Can anyone help me develop a macro for this?  I can't figure out the formula
that would allow this to be simplified.  I'll post anything I do figure
out... this isn't something that is easy to find information on.
Thanks in advance,
Allen
View My Portfolio At
http://allen.emailnuts.com/
Subject: Re: Golf Ball Help
Date: 18 Jun 2007 19:05:01
Message: <web.46770edfbc62bf83793de9de0@news.povray.org>
I did a bit more work trying to figure this problem out, and I came up with
the following code.  My only concern is that some of the dimples don't line
up right, and the spacing isn't correct all around, except for the equator
ring.  It is also a big resource hog.
#declare DimplesPattern =
union {
  sphere {
    0,
    3
    translate <0,0,-32.35>
    rotate <0,8,0>
  sphere {
    0,
    3
    rotate <7,4,0>
  sphere {
    0,
    3
    rotate <-7,4,0>
#declare Dimples_Equator =
union {
  #declare Count=0;
  #declare CountMax=45;
  #while (Count < CountMax)
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,Count*8,0>
  #declare Count=Count+1;
#declare Dimples_1up =
union {
  #declare Count=0;
  #declare CountMax=44;
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,-4,0>
    rotate <8,Count*8.2,0>
#declare Dimples_2up =
union {
  #declare Count=0;
  #declare CountMax=43;
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,0,0>
    rotate <16,Count*8.4,0>
#declare Dimples_3up =
union {
  #declare Count=0;
  #declare CountMax=42;
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,-4,0>
    rotate <24,Count*8.6,0>
#declare Dimples_4up =
union {
  #declare Count=0;
  #declare CountMax=40;
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,0,0>
    rotate <32,Count*9,0>
#declare Dimples_5up =
union {
  #declare Count=0;
  #declare CountMax=39;
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,-4,0>
    rotate <40,Count*9.5,0>
#declare Dimples_6up =
union {
  #declare Count=0;
  #declare CountMax=37;
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,0,0>
    rotate <48,Count*10.3,0>
#declare Dimples_7up =
union {
  #declare Count=0;
  #declare CountMax=36;
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,-4,0>
    rotate <56,Count*10.9,0>
#declare Dimples_8up =
union {
  #declare Count=0;
  #declare CountMax=34;
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,0,0>
    rotate <64,Count*11.4,0>
#declare Dimples_9up =
union {
  #declare Count=0;
  #declare CountMax=20;
  object {
    DimplesPattern
    translate <0,0,0>
    rotate <0,-4,0>
    rotate <64,Count*14,0>
// Golf Ball
difference {
  sphere {
    0,
    30
    rotate <0,0,0>
    translate <0,0,0>
  object { Dimples_Equator }
  union {
  object { Dimples_1up }
  object { Dimples_2up }
  object { Dimples_3up }
  object { Dimples_4up }
  object { Dimples_5up }
  object { Dimples_6up }
  object { Dimples_7up }
  object { Dimples_8up }
  object { Dimples_9up }
  rotate <0,180,0>
  translate <0,0,0>
  union {
  rotate <0,180,-180>
  translate <0,0,0>
      color rgb <1,1,1>
  translate <0,-10,0>
Date: 18 Jun 2007 19:35:01
Message: <web.4677167dbc62bf835e73ab330@news.povray.org>
"Allen" <nomail@nomail> wrote:
> Hey World,
> Thanks in advance,
> Allen
Have a look at the geodesic dome macro I posted a while ago here:
http://news.povray.org/povray.newusers/message/%3Cweb.45ba5cd1a6cc4078c150d4c10%40news.povray.org%3E/#%3Cweb.45ba5cd1a6
Not necessarily the best layout for real golf balls, but will give you a
fairly homogenous looking layout.  There are other packings that can be
developed too, then it's just a matter of mapping them to a sphere.
You may want to do a little bit of trig and CSG if you can to add to this so
you get rounded dimples rather than sharp edged ones.  Right now I don't
have time to help you lay this out, maybe later or perhaps someone else can
point you in the right direction.
-tgq
Date: 19 Jun 2007 09:49:19
Message: <4677dedf@news.povray.org>
I tried to do a mace with evenly spaced spikes. I found I could either do a
geodesic dome as mentioned above OR itterate repeatedly simulating the
"dimples" as electrons stuck to the surface of a sphere repulsing each
other - after a couple of hundred itterations, the opints are pretty evenly
spaced.
For the record, I cheated - I found a list of polar co-ordinates on the net
and just dumped them into an array - lots of dimples, yet (relatively) low
parse time.
Hope this helped
~Simon
"Allen" <nomail@nomail> wrote in message
news:web.467700fa911d3421793de9de0@news.povray.org...
> Hey World,
> then
> formula
> Thanks in advance,
> Allen
Date: 19 Jun 2007 10:16:58
Message: <4677e55a$1@news.povray.org>
> spaced.
Google actually turned up a patent applying this to golf balls ;)
"A golf ball having a plurality of dimples on its surface, the dimples
as a whole are distributed on at least a portion of the golf ball using
principles of electromagnetic theory. The dimples placed on the golf
ball surface are assigned charge values that are used to determine the
electric potential. A solution method is then applied to minimize the
potential by rearrangement of the dimple positions."
http://www.freepatentsonline.com/6884184.html
Date: 19 Jun 2007 10:45:01
Message: <web.4677eba5bc62bf83c150d4c10@news.povray.org>
Interesting idea, but I wonder how this actually works with respect to the
prinicpal of having the dimples in the first place which is an aerodynamic
flow problem...
-tgq
Date: 19 Jun 2007 16:14:15
Message: <46783917@news.povray.org>
My solution was emrely for evenly spaced and visually "average" dimples. I
have to say that it never occured to me the technique might be copytight. in
my defense, I was doing spikes on a mace :)
As to the aerodynamics - I only know that the dimples cause pockets of air
reducing the friction/air resistance by creating an envelope around the
ball. Beyond that, I'm afraid yuou're on your own - if it's any consolation,
I doubt many people will know if it's wrong.
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.4677eba5bc62bf83c150d4c10@news.povray.org...
> flow problem...
> -tgq
Date: 20 Jun 2007 08:10:02
Message: <web.4679185abc62bf83c150d4c10@news.povray.org>
I was just derailing the thread a bit, wondering whether the patentee
created a concept that has any valid correlation to what it's meant to
accomplish.
I agree that no one would notice.  The kind of person who notice an
incorrect ball dimple pattern is more likely out on the course these days
than in here :D
-tgq
Date: 13 Jul 2013 11:35:01
Message: <web.51e17368bc62bf83aee21ad10@news.povray.org>
> 8>< trim code 8><
Allen, how would the attached work for you?
Download '200 sides.png' (61 KB)
Preview of image '200 sides.png'
