POV-Ray : Newsgroups : povray.programming : Compilation options for MinGW Server Time
11 Nov 2025 05:06:06 EST (-0500)
  Compilation options for MinGW (Message 1 to 10 of 13)
Subject: Compilation options for MinGW
Date: 28 Jul 2004 04:25:00
Message: <web.4107624feaaac709117bdd960@news.povray.org>
Hello POV Team,
I hope you can give me some hint about this topic...
I've tried to compile PovWin with MinGW 3.3 (gcc 3.2.3).
I had to comment out a couple of functions from pvupdate.cpp (reg_printf and
GetInstallTime) because of error messages complaining about redefinition.
(I didn't try to investigate this more deeply).
After this, I obtained a working pvengine.exe.
Rendering a sample scene with this compiled-by-me version takes about 90'',
while with the official executable rendering time is about 30''!
My compile was done with -O3 option (full optimisation for speed, I think).
I had to add this in the makefile as it was not present in the "release"
build options. Without this the rendering time was even longer.
Now, I know from reading some posts in this group that the POV team uses the
Intel compiler, that produces very fast executables, but a difference of
three times seems a bit strange to me.
Can you tell me whether this is just what you expect from these compilers or
I should adjust optimisation options differently?
Can you give me suggestions about what optimisations I should use?
Thanks in advance,
acasta
Subject: Re: Compilation options for MinGW
Date: 28 Jul 2004 04:45:02
Message: <ce7ous$7ub$1@chho.imagico.de>
It is well known that MinGW produces very slow executables.  This is not
due to the compiler itself though (since on other platforms this is not
a problem).  On Intel systems you should always make sure you use
-march=pentium4 (or whatever suits).
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 28 Jul 2004 04:54:53
Message: <0tpeg053e5tr9k3a8ni8cckcccomfi992a@4ax.com>
On Wed, 28 Jul 2004 04:22:39 EDT, "acasta" <acastagnini AT yahoo DOT com>
What's comparison between rendering times under MinGW GUI and MinGW console
builds ?
BTW, I did not tried it myself but there is free console version of VisualC
somewhere at Microsoft site. You could optionally try it.
The difference in speed is "a little" large but OTOH note POV-Ray is threading
software with exception handling. I do not know how GCC of MinGW handles
threads and exceptions in details but there can be source of difference.
I never focused the optimisations under MinGW but I imagine you could find
some help within povray.unix group since they are more experienced in
optimisations of GCC.
ABX
Date: 28 Jul 2004 11:30:00
Message: <web.4107c572533f1f15117bdd960@news.povray.org>
> builds ?
There is not much difference (80'' instead of 90'').
I'll have a look at it. I also tried with Digital Mars, but I couldn't work
it out (some language compatibility problem, maybe).
OK,
thanks to everyone for your comments.
acasta
Date: 28 Jul 2004 18:25:53
Message: <410827f1@news.povray.org>
I can't confirm that.
I compiled Povray (more precise: MegaPov 1.0) with MingGW some time ago (I used
an older version though, for some reason I couldn't get it to compile with
recent versions), IIRC the speed difference was less than 10%.
Lutz-Peter
Date: 28 Jul 2004 18:45:58
Message: <41082ca6$1@news.povray.org>
There shouldn't be such a big difference.
Some results from a couple of winpov binaries I have available:
Chess2.pov, 320x240, no AA
My version (MingW): 39s
My version (BCC5):  55s
MegaPov 1.0 (MSVC): 40s
Povray 3.5 (ICL):   32s
I used these flags with mingw:
-DPRECISION_TIMER_AVAILABLE=0 -ffast-math -fomit-frame-pointer -malign-double
-march=pentium2 -mcpu=athlon-xp -O3 -Wno-multichar -mno-cygwin
-Wunused-variable -static -mwindows -mno-cygwin
I don't remember wich version of MingW/Gcc version I used, though.
Lutz-Peter
Date: 29 Jul 2004 04:47:19
Message: <96ehg0d40bdpfcdg2ge2ek08j264sop1fc@4ax.com>
On Thu, 29 Jul 2004 00:44:33 +0200, Lutz-Peter Hooge <lpv### [at] gmxde> wrote:
Is 'My version' related to 3.5 sources? You probably missed frontend/backend
architecture introduced by 3.6 which is a big difference to internal world of
GUI work.
ABX
Date: 29 Jul 2004 07:30:18
Message: <4108dfca$1@news.povray.org>
It's basically megapov 1.0 with a few small modifications
(bicubic interpolation, better png support).
> You probably missed frontend/backend architecture introduced by 3.6
> which is a big difference to internal world of GUI work.
But the problem was rendering performance, not GUI.
Lutz-Peter
Date: 29 Jul 2004 11:20:00
Message: <web.41091558533f1f15117bdd960@news.povray.org>
I've compiled the unix/linux source distribution with the Cygwin environment
and results have been quite different. A summary:
Official povWin binary: about 30''
MinGW binary (GUI): 90''
MinGW binary (console, tried different optimisation options): 80''
Cygwin binary: 47''
I'll try to replicate exactly the same options in MinGW ans see what happens
(but I think most options were the same).
By the way, what compiler is used for the official linux binary?
acasta
Date: 29 Jul 2004 11:53:11
Message: <637ig05n21890etuj9v9kd65esccevb63b@4ax.com>
On Thu, 29 Jul 2004 11:18:48 EDT, "acasta" <acastagnini AT yahoo DOT com>
> Cygwin binary: 47''
Have you tried to apply the same compiler options from Cygwin build into flags
in makefile dedicated to MinGW build ? That would be worth to compare.
ABX
