POV-Ray : Newsgroups : povray.programming : I have some external OOP interface for povray. Server Time
11 Nov 2025 05:06:05 EST (-0500)
  I have some external OOP interface for povray. (Message 1 to 8 of 8)
Subject: I have some external OOP interface for povray.
Date: 28 Apr 2004 09:15:01
Message: <web.408fadc5786546717a2708b0@news.povray.org>
Look at http://povtoray.chat.ru/
What would you say about it.?
Subject: Re: I have some external OOP interface for povray.
Date: 28 Apr 2004 09:40:02
Message: <c6oc0s$5m4$1@chho.imagico.de>
Quoting from that site:
"Though POVray has C-like script language, it lacks such powerfull
things as loops, if/then statements, variables, OOP. It is easy to
excuse, becouse POVray distributed for free, and authors working hard on
graphic aspects of system, involving new rendering features and ray
processing."
That's not correct, apart from OOP (which you can argue about how useful
it would be for actual scene design) POV-Ray comes with all those
features you mention it has not.
The main disadvantage of your system to me seems you don't have access
to the internal functions of POV-Ray which otherwise are very important
for creating scenes.
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 28 Apr 2004 09:48:45
Message: <408fb63d@news.povray.org>
  Why do you do it in such needlessly complicated way?
  The example in the page could perfectly be implemented like this (with
the proper modifications to the library):
#include "povtor.hh" // This is not a C header. Don't name it as if it was.
int main()
    Frame frame("c:\\my\\sedlo.pov");
    Camera cam(1050, 950, -500, -300, 0, 1500);
    Light light(2000, 2000, 2000, 50, 5, 5);
    frame << "#include \"colors.inc\"\n#include \"textures.inc\"\n\n"
          << "global_settings {ambient_light rgb<4,4,4>}\n\n"
          << cam << light;
    Cylinder cyl(3); // Could have this kind of constructor to set the radius
                     // If it's odd, you could just do cyl.Radius(3) instead
    for(int x = 0, y = 0; x < 1000; x += 10, y += 10)
	cyl.SetEnds(x,y,0, x,1000-y,1000);
        cyl.Texture.Color(1+sin((x+y)/500), 1+sin(x/300), 1+sin(y/300));
	frame << cyl;
    for(int y = 0, z = 0; y < 1000; y += 10, z += 10)
	cyl.SetEnds(0,y,z, 1000,1000-y,z);
        cyl.Texture.Color(1+sin(y/300), 1+sin(z/300), 1+sin(y+z/400));
	frame << cyl;
    frame.Render();
    return 0;
Date: 28 Apr 2004 09:50:38
Message: <408fb6ae@news.povray.org>
  That's true. For instance being able to call trace() or inside() is
pretty handy sometimes. I don't see any easy way of doing the same
with a C++ frontend (at least not without a lot of work).
Date: 28 Apr 2004 10:34:39
Message: <s9fv80lihsserosev6uibg0jg6ps2gj89a@4ax.com>
Something like below (not perfect at all) workaround comes to my mind:
bool Inside(Object& obj,Vector& V)
  Frame temp_frame("c:\\temp\\temp_file.pov");
  temp_frame << "#declare Object =";
  temp_frame << obj;
  temp_frame << ";\n\n";
  temp_frame << "#declare Vector =";
  temp_frame << V;
  temp_frame << "#declare is_inside = inside( Object , Vector );\n\n";
  temp_frame << "#fopen MyFile \"c:\\temp\\temp_file.out\" write";
  temp_frame << "#write (MyFile,is_inside)";
  temp_frame << "#fclose MyFile";
  temp_frame.render();
  FILE *temp_file = fopen ("c:\\temp\\temp_file.out" , "r");
  int is_inside = fgetc(temp_file);
  fclose(temp_file);
  return is_inside == '1';
ABX
Date: 28 Apr 2004 13:32:47
Message: <cjameshuff-91C3B5.13314928042004@news.povray.org>
In article <s9fv80lihsserosev6uibg0jg6ps2gj89a@4ax.com>,
Sorry, but...ew. Set up a scene, write the file to disk, and run a
POV-Ray render just to find out whether a single point is inside an
object?
A better option would be to implement the intersection and insideness
tests in C++. Of course, this practically entails writing a raytracer
instead of a simple interface, which is a little more work...or you
could write your code as an addition to POV-Ray.
http://tag.povray.org/
Date: 28 Apr 2004 13:40:21
Message: <lqqv809aof77rh3s1bnn90c4b23eaufrte@4ax.com>
On Wed, 28 Apr 2004 13:31:49 -0400, Christopher James Huff
> object?
Sure, wasting of CPU power, but only from POV-Ray/3D guru who has good
knowledge about math behind POV. I wrote that piece of code for those who
found original Xoid software usefull in current task and could looking for
this particular missed feature. I intentionally marked it "workaround". I
agree that in long run it deserves better solution.
ABX
Date: 28 Apr 2004 15:22:49
Message: <cjameshuff-0F7939.15215028042004@news.povray.org>
In article <web.408fadc5786546717a2708b0@news.povray.org>,
As already mentioned, POV-Ray already has loops, conditionals, and
variables. Here's a POV-only version of your scene:
    location < 1050, 950, -500>
    look_at <-300, 0, 1500>
#include "textures.inc"
global_settings {ambient_light rgb <4,4,4>}
// <4,4,4> as the global ambient?!? Don't you think that might be
//a little high?
light_source {< 2000, 2000, 2000>, color <50, 5, 5>}
//Again, rather insane color values.
//More oddball color values here...the components will reach values of 2.
//This is legal, but highly unrealistic.
#local X = 0;
#local Y = 0;
#local Z = 0;
#while(X < 1000)
    cylinder {< X, Y, 0>, < X, 1000 - Y, 1000 - Z>, 3
        pigment {color rgb < 1 + sin((X + Y)/500),
                            1 + sin(X/300),
                            1 + sin(Y/300)>}
    #local X = X + 10;
    #local Y = Y + 10;
#local Y = 0;
#local Z = 0;
#while(Y < 1000)
    cylinder {< 0, Y, Z>, < 1000, 1000 - Y, Z>, 3
        pigment {color rgb < 1 + sin(Y/300),
                            1 + sin(Z/300),
                            1 + sin((Y + Z)/300)>}
    #local Y = Y + 10;
    #local Z = Z + 10;
That's it...it's shorter, generally clearer, you don't have to mess
around with allocating and deleting memory (though that is only a
problem with the design of your C++ library...it could isolate the user
from memory management), and you don't have to go through a
compile-link-run cycle to render the image. (Though that isn't as much
of a pain as it could be...my Lumini tracer is driven by C++, I use a
script that builds the executable, runs it, and does whatever else is
needed.)
