POV-Ray : Newsgroups : povray.off-topic : GPU rendering Server Time
3 Apr 2026 00:41:14 EDT (-0400)
  GPU rendering (Message 71 to 80 of 175)
Subject: Re: GPU rendering
Date: 15 Jan 2010 13:11:11
Message: <4b50afbf$1@news.povray.org>
Sabrina Kilian escreveu:
> nemesis wrote:
>> In any cases, you get it wrong:  the amazing speed up is not due to
>> native GPU triangle handling, but faster ray intersection calculations
>> thanks to the GPU sheer parallel vector processing.  You can see that in
>> smallptGPU where you get perfect math spheres much faster, no meshes in
>> sight.
> Spheres are the other special, easy, case. Any ray that comes within
> -radius- of -center point- must intersect the sphere, with a surface
> normal that is pretty easy to compute. From that, the diffuse,
> reflection, and so on. The math, as obvious by the very short
> intersection code in smallpt, is easy and compact.
> Now, for any given cone, with arbitrary rotation and ratio of base to
> height, provide a fast general case for the ray intersection test, that
> will give you the same information. Single test, just to be clear, not
> separate cases for the disc bottom and cone top.
> Then cube, then spline lathe, SOR, blobs . . .
It's an example that the speedup is independent of the native GPU
triangle handling, nothing more.
I'm not math competent at all to give an answer to that.
a game sig: http://tinyurl.com/d3rxz9
Date: 15 Jan 2010 13:21:10
Message: <4b50b216$1@news.povray.org>
>>> 3) Large memory sets (other than textures)
>> My GPU has access to just under 1GB of RAM. How much do you want?
> They lack virtual ram in a simple sense, last I looked, but you can
> manage that by having your CPU thread move things around as needed.
> Messy and annoying, when the CPU gives you just under 4 gigs in a simple
> 32-bit OS as long as the system has the virtual ram space available. And
> even more than that in 64-bit, if you ask the OS nicely. On the CPU,
> when you need different parts of that 4 gigs of stuff, the OS handles
> it. I suspect that, should the GPU need new data fed into memory, it
> would require more than just stalling the threads while the data is
> moved from ram or paged memory over to the graphics card.
You people must render something utterly different to what I render! I
think the most demanding scene I ever ran wanted 10MB of RAM or something...
>>> 4) Independent shaders running on distinct units.
>> What exactly do you mean by that?
> I am guessing that he meant the ability to run multiple threads on the
> GPU, instead of running 100 instances of the same thread with slightly
> different starting conditions. I know that my card supports 4 different
> work groups, split over 8 'processors' each.
The information I got is that the GPU runs "bunches" of threads on its
several-hundred cores, and all the threads in a "bunch" must be
identical [just operating on different data], but different bunches can
run utterly different code...
http://blog.orphi.me.uk/
Date: 15 Jan 2010 13:31:05
Message: <4b50b469$1@news.povray.org>
> something...
I was wrapping an object in wire using a sphere sweep. While it was just
a minor background detail, I had several billion spheres. In my defense,
I was also doing this just to find the point at which I ran out of memory.
In general, though, what is the smallest maximum number of "bunches"
that you can run? I know my card lists 4 work groups, I do not know if
any other cards currently being sold only allow 2, or possibly only 1,
bunch to be run at once.
Date: 15 Jan 2010 13:54:17
Message: <4b50b9d9$1@news.povray.org>
Orchid XP v8 escreveu:
> something...
I'm sure even a game like Crysis needs more memory than your pov RSOCPs.
Date: 15 Jan 2010 13:54:20
Message: <4b50b9dc$1@news.povray.org>
I'll check the CUDA manual. Obviously this stuff varies by GPU, but I
was under the impression my card handles something like 16 bunches at
once or so.
Certainly you can't currently run thousands of seperate tasks at once.
But then, my card (for example) has something like 300 hardware units.
That's a hell of a lot more than 4 CPU cores...
Date: 15 Jan 2010 13:56:09
Message: <4b50ba49$1@news.povray.org>
>> something...
Crysis represents complex shapes by just blindly throwing hundreds of
billions of triangles at the problem.
Also, Crysis has to represent an entire world, not just the image
currently on screen.
Finally, Crysis was made by people who actually possess talent. :-(
Date: 15 Jan 2010 13:56:58
Message: <4b50ba7a$1@news.povray.org>
More than that in 32 bits too, if you ask the OS nicely. :-) You just have
to manage the virtual -> real mapping yourself.  (I.e., the mapping of your
virtual addresses onto disk space, not the mapping of your virtual addresses
into RAM space.)
People nowadays don't remember what it was like when *every* program didn't
have enough address space, when a simple sub-notepad-sophistication keyboard
driven text editor didn't have enough address space to hold a document...
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 15 Jan 2010 14:05:26
Message: <4b50bc76@news.povray.org>
  Good thing that technology marches forward, isn't it?-)
Date: 15 Jan 2010 14:23:05
Message: <4b50c099@news.povray.org>
Indeed. It's nice to be able to tell the customer it's now *his* fault when
his files are too big. ;-)
Date: 15 Jan 2010 14:28:33
Message: <4b50c1e1$1@news.povray.org>
>>> I think the most demanding scene I ever ran wanted 10MB of RAM or
>>> something...
yes, which is why it needs so much memory.
