POV-Ray : Newsgroups : povray.off-topic : 3D modelling in the 70's Server Time
27 Feb 2026 18:14:29 EST (-0500)
  3D modelling in the 70's (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: 3D modelling in the 70's
Date: 22 Nov 2009 04:12:26
Message: <4b09007a@news.povray.org>
Chambers <Ben### [at] gmailcom> wrote:
> So, 30 seconds to build the model & send it to the screen.  It still
> seems ridiculously slow, but this *was* 1976 :)
  Well, one should consider that nowadays when they make computerized images
for movies, one single frame can take up to 48 hours to render, and even more,
so in fact it seems we have gone backwards... ;)
Date: 22 Nov 2009 09:50:00
Message: <web.4b094e7629ec646651b504a30@news.povray.org>
I don't believe that is true anymore.  2 hours is more common in renderfarms, or
so I heard...
Date: 22 Nov 2009 11:45:25
Message: <4b096aa5$1@news.povray.org>
The Asteroids video game came out in 1979, so it's hard to believe that it
really took that much more compute time, going from 2 minutes a frame to
real-time, without something odd in the hardware going on.
   Is God willing to prevent naglams, but unable?
     Then he is not omnipotent.
   Is he able, but not willing, to prevent naglams?
     Then he is malevolent.
Date: 22 Nov 2009 11:54:56
Message: <4b096ce0$1@news.povray.org>
> it really took that much more compute time, going from 2 minutes a frame
> to real-time, without something odd in the hardware going on.
Asteroids wasn't 3D.  Even slightly.
Tim Cook
http://empyrean.freesitespace.net
Date: 22 Nov 2009 11:56:59
Message: <4b096d5b@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> [-- text/plain, encoding 8bit, charset: iso-8859-1, 14 lines --]
> so I heard...
  Are you talking about averages or about worst-case scenarios? If I remember
correctly, the slowest frames in the Transformers 2 movie took well over a
day to render. (I have read that one of the reasons why Devastator had so
little screen time is that it took so much time to render each frame that
they were simply hitting deadlines and computing budgets. The Devastator
model had like an order of magnitude more detail than any of the other
robots.)
Date: 22 Nov 2009 11:57:16
Message: <4b096d6c@news.povray.org>
> so I heard...
One of these things says 'up to', another says 'more common'.  We are
referring to an outlier vs. modal statistic.  I don't see the conflict.
Tim Cook
Date: 22 Nov 2009 11:59:45
Message: <4b096e01@news.povray.org>
  Maybe it's like I suggested, ie. with the lack of support for division in
hardware, they implemented a completely naive division algorithm in whatever
interpreted scripting language they were using. Multiply that by some hundreds
of vertex points, on a 70's computer, and 30 seconds could perhaps even be
plausible.
Date: 22 Nov 2009 12:16:58
Message: <4b09720a$1@news.povray.org>
I heard the same was true of the "gridwalkers" in Tron, which is why there's
a whole level of the video game dedicated to about 10 seconds of screen time
for that particular bad guy. :-)
Date: 22 Nov 2009 12:18:13
Message: <4b097255$1@news.povray.org>
Tim Cook wrote:
>> that it really took that much more compute time, going from 2 minutes
>> a frame to real-time, without something odd in the hardware going on.
Yes. I'm saying the actual rendering and calculating hardware was probably
already pretty fast, so there must have been something odd going on, right?
It wasn't general slowness. It was slowness particular to this problem.
Date: 22 Nov 2009 12:20:57
Message: <4b0972f9$1@news.povray.org>
Perfectly reasonable, to accomplish a one-time tasks when you're not on the
critical path.  I know a guy[1] who worked on some of the graphics routines
in Antz. The cost of human time has to be factored into the cost of the
render time, so if you spend two days of programming time coming up with an
algorithm that'll save 5 seconds of render on each of 2000 frames, you don't
do it.
[1] He was an awful programmer, but clever. He got into exactly the field he
should have been after he left where I was: a place where it's OK to come up
with a half-decent solution that you run once for one particular input and
then throw away. ;-)
