POV-Ray : Newsgroups : povray.off-topic : New LuxRender web site (http://www.luxrender.net) Server Time
4 Mar 2026 05:28:53 EST (-0500)
  New LuxRender web site (http://www.luxrender.net) (Message 96 to 105 of 175)
Subject: Re: Brute force renderers
Date: 21 Feb 2008 07:43:48
Message: <47bd7204@news.povray.org>
Invisible wrote:
> nemesis wrote:
>> I want povray to evolve.  Being provocative is a way to do that.
> No - being provocative to the point of trolling is a way to get
> everybody to completely ignore you. ;-)
eventually, that kind of attitude will lead to everybody ignoring
povray, except for the geekiest of geeks...
Subject: Re: New LuxRender web site (http://www.luxrender.net)
Date: 21 Feb 2008 07:45:00
Message: <web.47bd7183b014483d5054540d0@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Does anybody, anywhere, have any details of how the algorithm actually
> works? As in, how is this different to a normal ray tracer?
Yeah. Just search google:
path tracing
monte carlo path tracing
bidirectional path tracing
etc.
Basically it is this simple:
1. You shoot ray to scene and let it bounce randomly as it wants based on
material characteristics.
2. Repeat many times.
Date: 21 Feb 2008 07:49:11
Message: <47bd7347@news.povray.org>
Invisible wrote:
> OOC... Clearly Crysis has some pretty serious graphics. But is it *fun*
> to play?
dodging the real-time rendering quality discussion by asking about
something so irrelevant as the game itself or if it is any fun? ;)
Date: 21 Feb 2008 07:49:49
Message: <47bd736d$1@news.povray.org>
nemesis wrote:
> Sure, you can endlessly tweak the povray scene or settings in other
> biased renderings to get very photorealistic results.  You may also
> endlessly tweak the light sources and radiosity/photon mapping settings
> to get the illumination just right.  You can do nothing at all about
> aliasing of edges against very bright backdrops.
Wouldn't you still need to tweak light sources to get the scene to look
"right"
> Or you can just buy top hardware, model, texture and drop accurate
> lighting in your scene and let an unbiased rendering method handle it
> overnight.
Top of the line hardware is expensive. Having a renderer that can
produce a usable image in minutes is not. One more thing to throw in
(This isn't even raytraced, but scanline rendered) at this point,
unbiased rendering is not practical for creating any 3D animated film,
or even 3D special effects. The rendering tools they use in the movies
produce excellent results, sometimes indistinguishable from the actual
filmed portions.
Date: 21 Feb 2008 07:56:29
Message: <47bd74fd$1@news.povray.org>
*And* web buttons designers ;-)
Vincent
Date: 21 Feb 2008 07:57:48
Message: <47bd754c@news.povray.org>
47bd6ea9$1@news.povray.org...
> I can certainly see the advantage of a "I just throw objects in and it
> works" approach to lighting. But then, that's more or less how POV-Ray's
> radiosity feature works. You usually don't have to twiddle the settings
> all *that* much - it's more a question of how many years you're willing to
> wait for the result.
Just wondering... Could you show us some of your own experiments with
radiosity in POV-Ray or is your position just theoretical? Because after
using (and being in love with) POV-Ray's radiosity since 1996 and hundreds
of tests and pictures later, that's not really what I've experienced. Even
when using insane settings, there are situations where you just can't get
rid of artifacts and other problems and where workarounds (or Photoshop...)
are necessary to hide them. Unbiased renderers do that naturally and
traditional high-end renderers have lots of built-in optimisation tricks
that POV-Ray just doesn't have.
> And that's the kind of worrying part - how many years will you have to
> wait for the result from an unbiased renderer?
As I said it's now used *** for actual production *** of stills (mostly
architectural, design and even TV commercials) so apparently that's not such
a problem, at least for commercial production with access to networks of
fast machines and render farms. But even on a "normal" hobbyist machine, my
tests with Maxwell were rather positive, i.e. it was slow, but so was
radiosity in 1996. My "glasses" picture that's in the "Digital art" article
in Wikipedia took 500 hours to render. For POVers, speed isn't always an
issue.
G.
http://www.oyonale.com
- Graphic experiments
- POV-Ray, Cinema 4D and Poser computer images
- Posters
Date: 21 Feb 2008 08:07:46
Message: <47bd77a2$1@news.povray.org>
Well, maybe my scenes aren't complicated enough then. Usually if I just
insert an empty radiosity{} block, I get a reasonable image. Sometimes I
have to tweat a few parameters and then it looks good. Occasionally it
just becomes so absurdly slow that I give up.
But then, as you know, most of my renders are pretty trivial. For
example, the image attached to the first post in this thread. I have no
idea how the hell it's possible to model something that complicated.
Surely something like that must take many months of modelling?
Heh. Any algorithm can be made fast enough if you throw enough CPU power
at it. ;-) [Er, well, any linear-time algorithm anyway...]
> radiosity in 1996.
OK, well that's encouraging then...
http://blog.orphi.me.uk/
Date: 21 Feb 2008 08:09:17
Message: <47bd77fd@news.povray.org>
> path tracing
> etc.
None of those are search terms I thought to try...
Right. So trace rays, let them bounce off diffuse surfaces at
semi-random angles, and gradually total up the results for all rays?
Presumably that won't work with point-lights though? (You'd never hit any!)
Date: 21 Feb 2008 08:16:01
Message: <47bd7991$1@news.povray.org>
mama mia!  and it still features a strange little dark spot right in the
middle of the ground...
but it's a wonderful photorealistic povray render...
perhaps fidos could try that one next to see how it comes along. Andrew,
go to the "Montecarlo path tracing with MegaPov 1.2.1" thread in p.b.i
to find out more...
Date: 21 Feb 2008 08:29:51
Message: <47bd7ccf$1@news.povray.org>
default radiosity settings look hardly any better than just simple flat
ambient lighting.  If radiosity is not getting your render above 1 hour,
then it's really not doing much.
no, most probably a couple of hours in a visual modelling package like
Blender or Wings 3D.  Many people actually just reuse premade models and
just work on composition, texturing and lighting.  The real hard work is
in the rendering, but this is now mostly automated.  You just say "use a
bright clear sky at 16:00" or "the lamps should be 160W fluorescent" and
let it go.
>>> to wait for the result from an unbiased renderer?
on quad-cores, fidos has been posting slightly noisy results in the 11
hour range.  In other more mature ubiased renderers, 10-20 hours on
powerful hardware already give pretty good results for scenes much more
complex than just RSOCP...
