![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> Darren New <dne### [at] san rr com> wrote:
>> I always enjoyed thinking about such things. What if we really *are* in the
>> middle of the universe, and it's not that space is expanding, but only that
>> everything really is rushing away from us because it all started right near
>> here? :-)
> What's the difference?
Well, if it was my way, we'd be special. Or at least in a special place.
If you assume we aren't in the middle, then the only reasonable conclusion
is that space itself is expanding, i.e. that everything is the middle. If
we're actually in the middle, it's possible space is completely static, and
everything is just moving away from the center, without any additional space
being created between galaxies. It kind of changes the whole viewpoint of
the Big Bang. (Yes, I know it's nonsense, but think of it in a sci-fi novel
kind of way.) All of space already existed, then there was this big
explosion right about where we are, and everything is still rushing away
from that.
Or perhaps space isn't expanding, but since we're in the center, time is
slowing down as you move farther away. The galaxies aren't red-shifted
because they're receding, but because their time is actually running slower
the farther you get from the center. Which, again, supports us as being the
first species to have evolved to sapience, since we happen to be in the area
of the universe where time is running fastest.
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> Orchid XP v8 <voi### [at] dev null> wrote:
>> On 25/01/2011 08:11 PM, Warp wrote:
>>> My take: If there is life in the Universe (which happens to be the case),
>>> some of that life must have been the first one to form. Well, we might just
>>> be that first, don't you think?
>> My understanding of general relativity is limited, but I was under the
>> impression that "first" is not a meaningful concept at relativistic
>> velocities.
> That would be paradoxical.
> Assume that intelligent life evolves in planet A, and it starts sending
> radio signals to outer space. These radio signals eventually reach planet B.
> Some time later life evolves in planet B to a point where they can receive
> these signals from A. Clearly, intelligent life evolved in A first, and in
> B after that.
If A and B are separated by space-like distances, neither is first. Here
you're postulating that A and B (where A and B are the evolution of initial
radio-emitting life) are separatd by time-like distance.
As you say, if one is in the past light-cone of the other, there's a first
and a second. It only gets ambiguous where neither of the two 4D events are
in the direct past light-cone of the other.
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sounds reminiscent of Vernor Vinge... :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> velocities.
Yes. It's general relativity. It bemuses everybody.
Your language is still assuming that "earlier" and "later" are valid terms.
A small thought experiment: There are two parallel train tracks and a
train station in the middle of the tracks. There is a train sitting at
one end of one line, and another train at the opposite end of the other
line. The station and both trains synchronise their clocks, and at
exactly noon the two trains accelerate down the track to relativistic
speeds. Each train emits a flash of light at 1PM, according to the
on-board clock.
Applying the Lorentz transform makes my head spin. But the general
result is this:
- Train A emits a flash at 1PM. Since train B is travelling at
relativistic speed with respect to train A, from train A the clock on
train B appears to have slowed down, and so it appears that flash A
happens /before/ flash B.
- Train B emits a flash at 1PM, and by the same argument it appears that
flash B occurs /before/ flash A.
- Standing on the station platform, both trains' clocks appear to have
slowed down by the same factor, and hence both flashes appear to happen
at /the same time/.
Thus, depending on who you ask, flash A occurs either before, after, or
at the same time as flash B. QED.
Now replace speeding trains with moving planets, add in the influence of
gravity and perhaps the negative curvature of space, and call me back
when you get over the searing pain in your brain...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In that situation, why would someone in a galaxy not in the center of the
universe not see all the other galaxies receding?
(Anyways, I think that the reason why the universe must be expanding
rather than all galaxies receding from us simply because they got an
initial velocity away from the center is that in the latter case all the
galaxies would be receding from us at the same speed regardless of
distance, while in an expanding universe the farther away from us the
galaxy is, the faster its recession speed, which is what is observed.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> >> velocities.
General relativity does not introduce paradoxes.
Clearly if B receives a radio signal from A, the radio signal was sent
before it was received. The signal being received before it had been sent
would be paradoxical (it would mean that the signal travels back in time,
which would require FTL travel, and as we know, radio signals don't).
If we define the concept of "intelligent life" at "capable of sending
and receiving radio signals to/from space", clearly intelligent life
developed in A before it developed in B.
I'm not saying there aren't situations where whether A evolves before B
or the other way around depends on the frame of reference. What I am saying
is that when A's light cone (which started when intelligent life appeared
on A) reaches B (before intelligent life appears on B), it becomes
unambiguous. An ambiguous situation in this case would require FTL (and
hence time) travel.
Hence you can unambiguously state that intelligent life developed in A
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
While he is one of my heros, that idea is my own. :-)
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
They would, but it would be asymetrical. The galaxies between them and us
would be receding from them more slowly than the galaxies on the other side
of them from us.
Unless the galaxies all exploded out at different speeds, so of course the
ones farther away are receding at higher speeds. ;-)
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
However, in an expanding universe the recession speed accelerates
(because the more the galaxy recedes, the larger the distance from us,
and hence the larger the recession speed). In a situation where the
galaxies simply got an initial speed the recession would be constant.
(Well, in fact that's not true: The recession speed would actually be
decelerating because they are slowed down by the gravity of all the other
galaxies.)
It then comes down to whether we can measure whether the recession speed
of a galaxy is accelerating or not. (Can we?)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You would hve to look for changes in the redshift. I wouldn't think they're
changing recession speed enough for that to be detectable with current
instruments. Especially (I think) if recession speed is increasing because
of increased space between us and not actual acceleration of the galaxies
(because acceleration of the galaxies would affect the photons at the source
while increasing space would only accumulate over time).
"That was fatal?"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
