POV-Ray : Newsgroups : povray.off-topic : Task scheduling? Server Time
12 Oct 2024 11:18:46 EDT (-0400)
  Task scheduling? (Message 1 to 10 of 18)
Subject: Task scheduling?
Date: 14 Nov 2010 07:12:56
Message: <4cdfd248$1@news.povray.org>
How would I set up task scheduler to save an internet file every 3
hours?  I just got around to making a task that opens the URL in a new
tab every 3 hours, but would rather it just saved the file (with
timestamp added to filename) silently.  Had been doing this manually for
the past three years every 24 hours, more or less (there are some gaps
when I couldn't do it for a few days and stutters that weren't exactly
on time), and would like a better way of accomplishing the task.
(The URL in question is
http://xplanet.sourceforge.net/clouds/clouds_4096.jpg which updates
every three hours...)
Tim Cook
Subject: Re: Task scheduling?
Date: 14 Nov 2010 07:30:41
Message: <4cdfd671$1@news.povray.org>
My inclination would be to use wget to fetch the file, and a script of
some kind to invoke wget periodically (and decide what to name the result).
http://blog.orphi.me.uk/
Date: 14 Nov 2010 10:48:18
Message: <4ce004c2$1@news.povray.org>
Le 14/11/2010 13:30, Orchid XP v8 nous fit lire :
Same for me, wget & cron, done (as long as the system is up), a mv from
the same cron's line after success of the wget might be a plus, but wget
does not overwrite and rename with *.### so no problem
0 0,3,6,9,12,15,18,21 * * * /usr/bin/wget
http://xplanet.sourceforge.net/clouds/clouds_4096.jpg 2>/dev/null
1>/dev/null
Date: 14 Nov 2010 12:47:04
Message: <4ce02098@news.povray.org>
Alternately,
wget --output-file=/home/save/blah/`date +%s`.jpg
done via cron. Then you get it named with the timestamp it was fetched
(modulo network delays).
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 14 Nov 2010 18:06:22
Message: <4ce06b6e$1@news.povray.org>
> Alternately,
Windows user here, and I seem to be having an issue with getting wget to
actually save the file.  If I run 'c:\progra~1\gnuwin32\bin\wget.exe
http://xplanet.sourceforge.net/clouds/clouds_4096.jpg' from a
commandline it works, but if I try to add the option to save it
somewhere it doesn't fly.  Something's off with the task scheduler, too,
maybe...the task I made wasn't running.  Just tweaked the settings,
maybe that'll work.
Tim Cook
Date: 14 Nov 2010 18:34:30
Message: <4ce07206$1@news.povray.org>
Hmm.  Looks like it's working, but it's saving the files with default
filenames...clouds_4096.jpg.1 and clouds_4096.jpg.2 and so forth, but
I'd like the names to be better.  Hmmm.
Tim Cook
http://empyrean.freesitespace.net
Date: 14 Nov 2010 20:32:43
Message: <4ce08dbb$1@news.povray.org>
You're going to need to write a .bat file or something to pluck the
date/time into an environment variable and use it in a command to either
rename the file or pass it on the -O argument.
date +%s
should give you seconds-since-midnight as a date, if you're comfortable with
unixy scripting. Otherwise, I can put together a quicky .exe for you that'll
do what you want and invoke wget or write out a .bat file or something.
   Serving Suggestion:
Date: 15 Nov 2010 04:14:47
Message: <4ce0fa07$1@news.povray.org>
> Windows user here
I figured that might be the case. Still, wget is easy enough to find for
Windows.
Oh. Really?
I must admit, I do recall trying to use md5sum.exe and discovering that
it only works for files in the current folder. I guess it dislikes
backslashes or something. (You could try using forward slashes instead -
not many people know this, but Windows itself does accept them.) It'll
still break on the drive specifier, most likely.
> maybe...the task I made wasn't running. Just tweaked the settings, maybe
> that'll work.
Beware that Task Scheduler runs things under a different user account,
with different access permissions. If I had a penny for every time a
script has broken due to permission errors when run under Task Scheduler...
Date: 15 Nov 2010 06:04:12
Message: <4ce113ac$1@news.povray.org>
I think I've got things sorted out, including the naming.  Well, mostly.
  I got a batch file that puts GMT into a variable to use, so the file
is named "clouds_4096 %date% %_gmt%.jpg" ...but the internals of the
batch file only fix the time, not the date.  Will see if it's smart
enough to account for that or not.  Still might have to go in and add
checking for day/month/year rollover spots.  wget doesn't like any
colons used in the filename, even when added from a variable, so I had
to trim the time to hhmm instead of hh:mm.  Luckily that's what I was
already doing...
Tim Cook
Date: 15 Nov 2010 06:22:30
Message: <4ce117f6@news.povray.org>
On 15/11/2010 11:04 AM, Tim Cook wrote:
> wget doesn't like any colons used in the
> filename, even when added from a variable, so I had to trim the time to
> hhmm instead of hh:mm. Luckily that's what I was already doing...
As an aside, I think it's a bad idea to put colons in filenames anyway.
(And yes, variables are expended by the shell; wget can't tell the
difference between stuff you typed in and stuff the shell expended from
an environment variable. So if it doesn't like it when you type it, it
won't like it when the shell types it.)
