POV-Ray : Newsgroups : povray.off-topic : Web page construction Server Time
30 Mar 2026 23:23:15 EDT (-0400)
  Web page construction (Message 21 to 30 of 35)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Web page construction
Date: 14 Sep 2010 08:47:49
Message: <4c8f6ef5$1@news.povray.org>
>>> Hmm, so why doesn't the next heading tag get inlined into the previous
>>> paragraph?
>> because paragraphs are display:block by default?
> True - but that still doesn't explain how the spacing is still correct.
> (I.e., there's more space around a heading than there is around a
> paragraph.)
Because both <h1>'s and <p>'s margin-top and margin-bottom are 1ex; in
height, but since usually <h1> uses a bigger font, its margin will be
bigger.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 14 Sep 2010 12:15:36
Message: <op.vi054jw4mn4jds@phils>
And lo On Tue, 14 Sep 2010 12:33:05 +0100, Invisible <voi### [at] devnull> did
spake thusly:
>>> Is there some way I can style it so that it shows up more like
>>> Introduction
>>> (Show/hide)
>>> ...real content...
>> .h1 {margin-bottom:0}
> Wouldn't that mean that the margin between the header and the real
> content would now be incorrect?
Should still conform to line-height
<snip>
> I always try to design my pages so that if you totally disable all CSS,
> it still displays sensibly. It might not be pretty, but it's readable.
> Then I apply CSS to make it pretty.
> Not sure you need to use ".indent"; why not just "li ul" or something?
Because the first ul isn't indented and it allows you to create an extra
indent for a third level if needed without messing with child indicators
that IE doesn't understand.
> Anyway, absolute positioning seems to work fine, but for the minor
> detail that I need to figure out how wide the columns are supposed to
> be...
I try to avoid absolute positioning when possible, just because it takes
things out of the flow. if I have to use it I ensure it's well-wrapped,
but even then there can be some glitches where the positioning relates to
the first parent that specifies a position rather than its container.
> Also, whenever I try to open an XHTML document in IE (v7), it asks me
> what application I want to use it open it with, and defaults to Firefox.
> I can't seem to convince it to open it. The best I can do is get it to
> display a blank page.
Well I know they separated out online and offline content between two
windows, perhaps its related to that?
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 14 Sep 2010 13:22:43
Message: <4c8faf63$1@news.povray.org>
> <snip>
I didn't think inline elements could have margins?
Ah. So the answer to "why not use child selectors" is simply "IE doesn't
understand child selectors"? Oh I *so* don't give a damn. :-P
>> be...
> to the first parent that specifies a position rather than its container.
Yeah, it looks like styling this correctly is going to be fun... Still,
at this point, I'm still getting the page content to be generated
correctly. Assuming I tag enough stuff, it should be possible to fiddle
with the CSS later.
http://blog.orphi.me.uk/
Date: 14 Sep 2010 13:55:17
Message: <4c8fb705$1@news.povray.org>
Invisible escreveu:
> On 13/09/2010 10:14 PM, nemesis wrote:
>> You indeed can generate the tree server-side. What's the problem with
>> nested ul's again?
> I want the other columns (e.g., timestamp, attributes, owner, etc.) to
> line up vertically.
see Phill Cook's reply
a game sig: http://tinyurl.com/d3rxz9
Date: 15 Sep 2010 04:03:32
Message: <op.vi2d0ggcmn4jds@phils>
And lo On Tue, 14 Sep 2010 18:22:43 +0100, Orchid XP v8 <voi### [at] devnull>
did spake thusly:
>> <snip>
No it's just that the default is 0 for inline elements but some differ.
Ah well they do work for IE7 so ul>ul would have been neater.
>>> be...
> with the CSS later.
Well the benefit to the way I've done it is that it keeps the flow. That
is the third column will be positioned by default behind the second column
with no extra styling so you only need to set the sizes to indent+width
for everything to line up.
Phil Cook
Date: 21 Sep 2010 16:59:14
Message: <4c991ca2$1@news.povray.org>
On 12/09/2010 01:21 PM, Orchid XP v8 wrote:
> 2. I want to build a file tree where you can collapse or expand tree
> nodes. The obvious way to do this is with the <ul> element. However, I
> also want each file to have attributes, a creation date, and so forth,
> and all these columns should line up vertically. The obvious way to do
> that is with a table. But it can't be a table and a list at the same time!
> I could use nested tables I suppose, but nested tables are EVIL! Is
> there some more semantically-transparent way that I can do this?
> Root 2009-09-12 Ahsc
> Resources 2009-09-10 Ahsc
> Main.css 2009-09-10 Ahsc
> Main.js 2009-09-10 Ahsc
> Packages 2009-09-12 Ahsc
> ansi-terminal 2009-09-12 Ahsc
Facepalm moment: Using CSS, you can render any element AS A TABLE! >_<
Date: 22 Sep 2010 05:14:24
Message: <op.vjffyfepmn4jds@phils>
And lo On Tue, 21 Sep 2010 21:59:13 +0100, Orchid XP v8 <voi### [at] devnull>
did spake thusly:
>> time!
Well yeah that was going to be my first response, but you wanted the
columns offset within rows and that would have ended up just as messy as
absolute positioning.
Phil Cook
Date: 22 Sep 2010 05:35:10
Message: <4c99cdce@news.povray.org>
Well, I can make it so that a <ul> who's <li> elements contain multiple
<span> tags gets rendered as a regular table. What I *cannot* do is make
nested <ul> elements render correctly. Not for love nor money.
I can, however, take a <table> and annotate each <tr> with a style class
indicating how far to indent it, and get a result that looks exactly
like what I want.
So I have a choice here: The information I want to present is
semantically tabular *and* hierarchical. I can mark it up as <ul> (which
lets be expose the hierarchy but hides the tabular nature in <span>
tags), or I can mark it up as <table> (which exposes the tabular
structure but hides the hierarchy in style class declarations).
I think I'm going to go with <table>, simply because it lets me actually
achieve the rendering result I want. Sure, tables are evil. OTOH, my
data actually *is* a table! So putting it in <table> isn't that much of
a hack.
Date: 22 Sep 2010 05:50:08
Message: <op.vjfhl0s3mn4jds@phils>
And lo On Wed, 22 Sep 2010 10:35:08 +0100, Invisible <voi### [at] devnull> did
spake thusly:
> a hack.
Well yeah if it's tabular data present it in a table nothing evil about
that well unless you're going to use nested tables just for display
purposes that's frowned upon; and if you're not then you're going to have
to style every single cell and that's just messy.
Phil Cook
Date: 22 Sep 2010 05:52:31
Message: <4c99d1df$1@news.povray.org>
> spake thusly:
>> actually achieve the rendering result I want. Sure, tables are evil.
>> OTOH, my data actually *is* a table! So putting it in <table> isn't
>> that much of a hack.
> have to style every single cell and that's just messy.
Nested tables won't even help me here. And no, I don't need to style
every single cell. I just style each row (so I can get alternating
colours) and each cell in column 1 (so I can set the indent). And since
the whole table will be machine-generated anyway...
