POV-Ray : Newsgroups : povray.off-topic : My computer doesn't like heat, what to do? Server Time
14 May 2026 17:04:01 EDT (-0400)
  My computer doesn't like heat, what to do? (Message 12 to 21 of 21)
Subject: Re: My computer doesn't like heat, what to do?
Date: 14 Jul 2010 05:28:29
Message: <4c3d833d$1@news.povray.org>
scott wrote:
>> Yes, that's right. THE FAN IS CONTROLLED IN SOFTWARE! How retarded is
>> that? Surely this is a serious fire hazard...
> No, because the machine will switch off (which is in hardware) long
> before the chance of any fire breaking out.
As I say, the laptop let itself get hot enough to randomly malfunction
without turning off. What makes you think it would turn off at some even
higher temperature?
(A more likely scenario is that whatever program it's running would
crash, causing the CPU to halt and therefore cool down again.)
Date: 14 Jul 2010 05:36:04
Message: <4c3d8504$1@news.povray.org>
> higher temperature?
Because that's what CPUs are designed to do.  It was probably the RAM that
was overheating giving corrupt data to the CPU.
Date: 14 Jul 2010 08:14:01
Message: <4c3daa09$1@news.povray.org>
Most can be controlled by software. Usually the BIOS is in charge, but
programs can also alter the fan speed. This is useful for more advanced
monitoring programs like SpeedFan.
My system at home has 4 fan ports on the motherboard (3 case, one CPU,
the CPU and 2 of the case fans can be controlled by PWM)
~Mike
Date: 14 Jul 2010 08:19:53
Message: <4c3dab69$1@news.povray.org>
> that was overheating giving corrupt data to the CPU.
Yep... There's usually a thermal sensor either on the die or on the
motherboard.
Some older AMD's I believe rely on the mobo's thermal shutdown. an AMD
chip can be damaged by heat before the mobo registers a problem. On the
Intel side, the chip will throttle down to a snails pace to try to
control the heat, if that doesn't work, it'll tell the mobo to shut off.
I'm not sure about the newer AMDs.
Another interesting thing that's fun to watch: On the later Intel Core2
chips, they have an adaptive multiplier. When the CPU is idle, it will
reduce its clock rate to save on energy and keep cooler when idle.
~Mike
Date: 14 Jul 2010 08:34:39
Message: <4c3daedf$1@news.povray.org>
> motherboard.
http://www.tomshardware.com/reviews/hot-spot,365-5.html
demonstrates how older AMDs had *no* thermal protection at all. They
even have a video of one of the CPUs actually smoking and glowing. Can
you spell "fire hazard"?
They added thermal protection a long, long time ago.
Yeah, most processors do that now (especially "mobile" ones). Initially
they just made it so that a certain temperature, the system powers off.
But later they had adjustable fan speeds and adjustable clock speeds,
and switching off cores and so on.
I'm still puzzled about this laptop though. Considering that fan control
is both trivially simple and utterly safety critical, why is it
controlled by the OS? Why isn't it hard-wired?
Date: 14 Jul 2010 10:46:09
Message: <4c3dcdb1@news.povray.org>
Generally the OS isn't in charge of the fan. Perhaps the linux distro
you're using detects the chipset and grabs control of the fan?
~Mike
Date: 14 Jul 2010 10:50:04
Message: <4c3dce9c$1@news.povray.org>
Why should it even be possible to control it in software? The correct
algorithm is simple: set the fan to the lowest setting that gives
acceptable cooling. Why would you want to be able to control it in
software at all?
(As it happens, once Linux was installed, the fan worked normally. Just
not while the installer was running...)
Date: 14 Jul 2010 11:08:42
Message: <4c3dd2fa$1@news.povray.org>
Because there's usually an IC on the motherboard that reads the temperatures
and controls the fan PWM.  This is mapped to memory so that the BIOS can
control it.  Obviously this means any software running (an OS, a special
program, etc) can also take control.
> The correct algorithm is simple: set the fan to the lowest setting that
> gives acceptable cooling.
That's what it does!  But you have to take into account that there are many
different fan and CPU combinations that will be used on a motherboard, not
giving the option to change the settings would be a bit limiting.  (Plus it
would make it hard for the BIOS to setup the IC, currently it just writes
the data to a certain memory address).
> Why would you want to be able to control it in software at all?
How else do you propose doing it, that isn't 10x more expensive than the
current method?
Date: 14 Jul 2010 11:43:56
Message: <4c3ddb3c@news.povray.org>
scott <sco### [at] scottcom> wrote:
> The fan/BIOS is probably designed to run "silently" at CPU-idle and only
> speed up once it gets loaded.  They are probably doing this by triggering at
> speed trigger temperatures?
  Actually someone else (IRL) suggested checking the BIOS settings for the
CPU fan, so I did so.
  There's some kind of setting which makes the CPU fan target for a certain
maximum CPU temperature. This setting was disabled, so I don't know what the
CPU fan was doing. I tried enabling this (and the default target maximum
temperature seems to be 66 degrees, so I left it like that), and now the
PC is incredibly silent, yet the CPU keeps quite cool when idle (2500 RPM,
47 degrees celsius) even though the room temperature is still unbearably
high (30 degrees celsius at the moment).
  I'm monitoring closely the CPU temperature and fan speed, but it seems to
be quite stable. And incredibly silent.
Date: 14 Jul 2010 11:45:53
Message: <4c3ddbb1@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Warp wrote:
> >   This isn't normal. A friend's PC runs almost silent even at these high
> > room temperatures. My Xbox360 runs very silently.
> >   I have no idea what the problem could be. Any suggestions? I can't use my
> > PC because I'm afraid it will break.
> I would imagine the fan bearings are worn out. That's usually the cause
> of excessive fan noice.
  You didn't understand. I didn't mean to say that the CPU fan noise is
not normal. I said that the fan going at 4000 RPM is not normal (because
its normal speed is somewhere around 2500 RPM).
  Anyways, so far it seems that a BIOS setting fixed the problem.
