![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 07/07/2010 9:38 PM, Mike Raiford wrote:
> On 7/7/2010 1:14 PM, Stephen wrote:
>> On 07/07/2010 6:52 PM, Jim Henderson wrote:
>>> The water that goes to the upper floor is full of flouride and other
>>> chemicals that give it an excess of anti-gravitrons, allowing it to
>>> easily get up.
>>> The bigger question is why doesn't the tank fly off into space?;-)
>> The ball cock holds it down. All those chemicals stop it from lifting.
> So, that's how geysers work .... <stares in astonished wonderment>
There are more things in Heaven and Pov, Mike, Than are dreamt of in
your philosophy. ;-)
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> easily get up.
>> LOL
> It's all a conspiracy, I tell ya... ;-)
Mercy buckets, its true. :-)
> Well, that would explain it. ;-)
Some chemicals inhibit rising, whilst others actively promote it. O_o
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Every car I've ever seen has hinges which try to force the door fully open
> or fully closed. Now you can see why fully closed would be a good idea.
> But if you're parked in a tight space, it's really irritating that you
> can't let go of the door because you'll either get a door in your face, or
> the door will spring open and scratch up the car next to you.
> Such a simple problem, yet nobody has solved it. WHY?!! >_<
Huh? Every car I've had for decades has a soft "stop" half way where the
door is quite stable. You can then push it a bit harder and it locks all
the way out. Try it!
> Why are the downstairs taps connected to the mains, but the upstairs ones
> connected to a tank?
To stop you having mains pressure cold (~1-5 bar) next to tank pressure hot
(~0.2 bar) in the bath. Imagine what happens when you connect one of those
old-fashioned shower adapters to the bath taps, turn hot and cold to full
and then turn *off* the shower head. Fortunately now we have taps with
back-flow prevention valves and fancy mixer taps to avoid this problem.
Many houses don't have a cold tank, and some won't have a hot tank either
(the hot is heated on-demand by the boiler).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> ones connected to a tank? Why do we even *have* a tank??
> Because the mains does not have enough pressure to push the water upstairs
> at a tolerable force. If it weren't for the tank, you'd turn on the faucet
> and get barely a trickle... With the tank on the roof, you get nice water
> pressure.
It's different in the UK, the mains pressure usually equates to about 10-50
metres plus of head. Any water from a tank in the roof is usually *way*
lower pressure than mains. For example you can easily block off a fully
open hot tap with your thumb with very little force, but it is tricky, if
not impossible to do the same on a mains pressure cold tap.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> all the way out. Try it!
Doesn't seem to work with my Renault Megan III.
does work there.
> hot (~0.2 bar) in the bath. Imagine what happens when you connect one
> of those old-fashioned shower adapters to the bath taps, turn hot and
> cold to full and then turn *off* the shower head. Fortunately now we
> have taps with back-flow prevention valves and fancy mixer taps to avoid
> this problem. Many houses don't have a cold tank, and some won't have a
> hot tank either (the hot is heated on-demand by the boiler).
My house doesn't have and has never had a hot water tank. As you say,
water is heated on-demand. Which, come to think of it, means that only
the cold tap is fed from a tank. Given that there's no noticable
difference in water pressure between the two, that makes the need for a
tank even more dubious.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That would be the first car I've ever seen (and I've seen lots way older and
smaller than yours!) that didn't have such a feature. You really mean that
once you un-latch the door it is free to swing out to 100% open? Yes, I can
imagine that would be really annoying in car parks and garages.
Was it like that when the house was built?
> Which, come to think of it, means that only the cold tap is fed from a
> tank. Given that there's no noticable difference in water pressure between
> the two, that makes the need for a tank even more dubious.
Yes, it seems odd to build a house like, as you don't need a hot or cold
tank with an on-demand boiler.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> and smaller than yours!) that didn't have such a feature. You really
> mean that once you un-latch the door it is free to swing out to 100%
> open? Yes, I can imagine that would be really annoying in car parks and
> garages.
As far as I can tell...
(The other fun thing is that if you swing it open, it hits the end and
immediately bounces back in your face.)
I can't say for certain. It's been that way ever since I lived here.
Then again, my dad's house is on the same estate and that does have a
hot tank, so...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sounds broken to me, does the passenger door behave the same way?
> I can't say for certain. It's been that way ever since I lived here. Then
> again, my dad's house is on the same estate and that does have a hot tank,
> so...
I suspect it originally had hot and cold tanks, then they changed it to an
on-demand boiler (common when a boiler gets replaced) but left the cold tank
(probably didn't want to re-plumb all the upstairs taps).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 07.07.2010 17:59, schrieb Invisible:
> Why has nobody yet invented a car door which can be opened half way?
> open or fully closed. Now you can see why fully closed would be a good
> idea. But if you're parked in a tight space, it's really irritating that
> you can't let go of the door because you'll either get a door in your
> face, or the door will spring open and scratch up the car next to you.
Because you're once again wrong?
I recall indeed having operated car doors that had two distinctive
"open" positions. Never paid much attention to this though, so I can't
tell what percentage of cars seem to have such a feature.
Maybe because upstairs the water mains pressure drops below atmospheric
pressure (or at least too low to provide any significant throughput) at
peak load times?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> 10-50 metres plus of head. Any water from a tank in the roof is usually
> *way* lower pressure than mains. For example you can easily block off a
> fully open hot tap with your thumb with very little force, but it is
> tricky, if not impossible to do the same on a mains pressure cold tap.
Is this everywhere, though? I imagine in Andrew's Building's case that
it could be that his building was on a hill, while the building gets
reasonable pressure on the lower floor, the upper floor might not get
enough. Where I live, there's plenty of water pressure. But, if your
building is taller than the water tower, it'll need a tank to get
pressure to the upper floors.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
