POV-Ray : Newsgroups : povray.off-topic : Latest Logicsim build ... Server Time
14 May 2026 20:03:36 EDT (-0400)
  Latest Logicsim build ... (Message 10 to 19 of 29)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Latest Logicsim build ...
Date: 15 Jun 2010 16:02:48
Message: <4c17dc68$1@news.povray.org>
On 6/15/2010 1:53 PM, Orchid XP v8 wrote:
> Adding a tristate buffer works, but not a tristate inverter. Also,
> neither the clock source nor the splitter work, but I guess that's
> intensional.
Yep. Those aren't there yet.
> For the first time, I tried actually wiring together a simple circuit.
> Wiring seems to be quite buggy. Sometimes you join wires together and
> they don't actually join. Sometimes they look like they aren't joined,
> but when you connect the other end of the wire to something, suddenly it
> works. And sometimes it's difficult to figure out just what on Earth is
> going on. (Especially since you can't, say, delete the wires you've
> already made. *g*)
The problem, I think (aside from not being able to delete things...) is
kind of two-fold... Connecting the pins while on the surface seemed very
simple, some cases quickly become a royal PITA.... There are some
modifier keys in wiring that will cause some of the connection stuff to
behave differently, generally if it has an orange indicator, it should
be connected when you release the mouse button. The other half of it is
that it appears to have not connected because it doesn't always take the
characteristics of what you just connected it to until the other end is
connected to something else. This has more to do with the sim core, though.
There's also a major annoyance with-- for example-- altering the layout
of a circuit. You pull a wire from one location, leaving 2 wires
connected straight together, you then draw a new wire across that
junction (which happens to be invisible...) and it joins everything at
that intersection. One of the things I need to do is when reconciling
the wires, ensure any wires that are joined at the same angle get
consolidated into a single wire. After drawing wires for a few minutes I
was able to slice and dice a single wire into a dozen pieces. Nasty.
> Still, I've spent several days now just trying to build the internal API
> to manage something like this, and I'm getting nowhere, rapidly...
That happens with lots of things ;)
~Mike
Date: 15 Jun 2010 16:22:09
Message: <4c17e0f1$1@news.povray.org>
On 6/15/2010 2:59 PM, Orchid XP v8 wrote:
> I generally just don't code anything at that hour. It never ****ing
> works right anyway.
Yeah, probably good advice. ;)
> Heh, well, I did wonder. Actually, as I say, I just assumed that since
> it was *so* wrong, you must already know about it but just haven't got
> round to fixing it yet.
There are some things like that in there at the moment, but that was not
one of them.
> Pah. Mutable state is evil! ;-)
Eh, I'm thinking of a way of managing that part of the app in a much
cleaner manner, anyway.
You have to change the state of the objects somehow....
> Very, very slowly. Like, I'm having trouble making it so that I can add
> and remove wires and stuff efficiently and still be able to look up what
> connects to what efficiently and...
My progress isn't as quick (or as clean) as I would like, but yeah... I
had similar challenges. Quadtrees help if you're looking for something
at a particular location, btw ;)
> (See my post about "highly redundant data structures.)
I'll have a look at this...
> You, by comparison, have got something that *runs*. I'm still faffing
> around with design choices.
Yeah, it limps along, I suppose ;)
You're coding it in Haskell, aren't you?
~Mike
Date: 15 Jun 2010 16:41:45
Message: <4c17e589$1@news.povray.org>
Do not try to change the state of the objects. Instead only try to
realise the truth: there is no state. Then you will see that it is not
the *state* that changes, it is only *yourself*. ;-)
Oh hell, I haven't even got that far. When the inputs to a gate change,
and its output changes, it has to notify everything connected to its
output. But to do that, you have to be able to somehow look up what it's
connected to... and be able to change it later... and check that you
don't have outputs connected to other outputs... and...
There's really nothing to see. I just meant that that's what my comment
is about. ;-) Because I want to look up information five different ways,
it's in five different indexes, all of which need to agree with each
other...
You trying to imply there's a causality relationship there? :-P
http://blog.orphi.me.uk/
Date: 15 Jun 2010 17:02:43
Message: <4c17ea73$1@news.povray.org>
Welcome to the Matrix, Neo.
Yup, been there .. still there .. still not exactly what I want. Mine is
a bit more weird than that. I start somewhere, and begin fanning out
looking at various pin states, If I see more than one output, I flag
it... and so on. It's a sucktacular process and has many, many failings.
Plus, it doesn't lend itself very well to being able to follow signals,
being able to step from gate to gate, being able to follow a particular
signal path into a subcircuit...
> other...
That's ok.. I couldn't find the post anyway.
Oh, no ... But I did have to get a Haskell dig in somewhere ;)
I am interested in seeing what your Haskell implementation will be like.
(In a way, this reminds me a bit of a small friendly "competition"
between a friend of mine and I back when I was a kid. We both wrote
different implementations of the same game....)
~Mike
Date: 16 Jun 2010 04:16:15
Message: <4c18884f$1@news.povray.org>
Coding stuff in Haskell encourages you to try to make everything
"perfect", which is possibly why I'm still designing and redesigning the
thing rather than making it actually do stuff...
Small example: Different gates have different numbers of pins. Now in an
OO language, you'd probably just have an array (or some other container)
of pins and be done with it. You *could* do that in Haskell too,
except... well... there's always the possibility of a gate ending up
with the wrong number of pins. In an OO language, you'd probably just
ignore that possibility, in which case the code will throw some kind of
exception if the number of pins is wrong. But in Haskell, you're more or
less forced to explicitly handle this possibility. And that tends to
discourage you from ignoring it, since if this happens, there's
basically no good way to recover. (You just throw an exception I guess -
which is quite frowned - or you make your functions explicitly partial,
which is quite a bit more work.)
The net result is that in Haskell, you take more notice of this problem.
And it turns out that by using ADTs, it's quite simple to statically
prevent the problem from ever occuring in the first place. So you can
design your code so that there's this problem that might happen that you
have to explicitly test for and explicitly deal with, or you can design
your program so that the problem is guaranteed to never happen in the
first place. Guess which option the typical Haskell programmer is going
to go for. ;-)
Of course, making everything "perfect" like this requires quite a lot of
think-time. Haskell strongly encourages this style of "think twice, code
once". Anyway, I believe I'm closing in on a solution, but I'll believe
it when the code actually runs properly!
Subject: LogicWorks
Date: 16 Jun 2010 06:38:05
Message: <4c18a98d@news.povray.org>
Yeah, the internal layout management code appears to be operating
correctly now. In the end, I applied a tried and tested analysis
technique: a relational-style ERD.
The problem was that I'd design a data structure, start coding away, and
then discover some query direction that wasn't easy to support. So then
I'd change the data structure, which makes half the code break, so I
have to go rewrite that... In the end, the solution was to sit down and
draw out a propper plan. Once you comprehend the exact structure of the
information you want to store and the directions in which you want to
access it, you can come up with a nice *simple* data structure which
does what you actually need.
It works a lot better now - although I'm still finding minor bugs here
and there...
Who knows? I might even get the simulation algorithm running today.
Subject: Re: LogicWorks
Date: 16 Jun 2010 11:35:06
Message: <4c18ef2a$1@news.povray.org>
Affirm that. After many hours' work, I have now reached the point where
I've simulated a binary half adder which correctly computed that 0 + 0 =
0 carry 0. Woo.
Date: 16 Jun 2010 12:20:00
Message: <4c18f9b0$1@news.povray.org>
Hate to tell you, you take notice of it in an OO language also. :-) It's not
any easier to deal with things like that.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 17 Jun 2010 03:56:27
Message: <4c19d52b$1@news.povray.org>
I didn't intend to make any absolute statements. I just meant that in
general, Haskell tends to make you notice certain things more.
Subject: LogicWorks rev #6
Date: 24 Jun 2010 11:37:00
Message: <4c237b9c@news.povray.org>
OK, so I just finished the 6th complete rewrite of the LogicWorks
simulation core. And it seems to be working, as best as I can tell.
I spent a long time trying to hyper-compartmentalise the thing so that
every tiny aspect of its operation was a seperate source file, with a
tightly-controlled interface to it. The trouble is, everything depends
on everything else, so you end up going mad trying to avoid circular
module dependencies. Eventually I just put everything related to
simulation into one utterly giant module. Circular dependencies within
the same module don't matter. ;-)
Secondly, I spent ages trying to design the circuit as a dozen seperate
data structures, each representing different facets of its operation,
and several different modes of operation depending on what you want to
alter. And then I realised that in the real application, you only want
one mode: the mode where you can modify the live circuit as you simulate
it, and everything needed to do the simulation is one data object. So
instead of having dozens of datatypes, I put everything into one big
record and wrote all my functions to work on that.
The net result is what I'd consider to be utterly huge, although other
people's opinions may differ. It's a single source file, 660 lines long
(including comments) and 20 KB in size. When you compile it, it
generates a 38 KB interface file plus a 182 KB object file.
(For reference, I usually structure my programs so that each module is
about 150 lines or so.)
It's about now that an IDE starts to sound attractive. It would be nice
to be able to glance at a panel and see the sames and types of all the
functions I've written, and be able to quickly navigate to them.
Actually, hell, just some syntax hilighting would be nice! Oh well...
Anyway, I could show you the code if you _want_, but... it's kinda
large. (And most of it is just searching for or storing data, which
isn't tremendously interesting.)
