POV-Ray : Newsgroups : povray.off-topic : Electronics research Server Time
15 Mar 2026 21:41:08 EDT (-0400)
  Electronics research (Message 65 to 74 of 104)
Subject: Re: Electronics research
Date: 21 May 2010 04:20:47
Message: <4bf6425f$1@news.povray.org>
andrel wrote:
> Ok, Andy, here is the deal: we trust Ken in this, you put one of these
> books on your Amazon Wish list and you give me a link to that wish list.
> In exchange, after you received it, you read it and you stop asking
> questions that are answered in the book. Remember: Ken has also a copy.
My mother once said something to me, which I try to follow [although I
don't always succeed]. She said "if you don't have anything nice to say,
don't say anything".
If you think my questions are stupid or you don't feel like answering
them, then fine. Don't answer them. Ignore the thread or something. But
there's no need to make a point of telling me I'm stupid just because I
*dared* to ask for a few pointers. OK?
Date: 21 May 2010 04:22:01
Message: <4bf642a9$1@news.povray.org>
scott wrote:
> I was going to suggest he learnt about transistor basics (including the
> analogue analysis of simple transistor circuits) before embarking on a
> project using them - but you said it much better than I could :-)
The entire reason I find digital circuits interesting is that it avoids
the bewildering complexities of analogue design. ;-)
(OK, that's a lie. I find computers interesting, and computers are digital.)
Date: 21 May 2010 05:54:01
Message: <4bf65839@news.povray.org>
> them, then fine.
As has been said many times, the only stupid question is the one that is not
asked. Keep asking questions, Andrew, it's the best way of learning.
BTW We still reserve the right to say GIYF or even WIYF ;-)
John
Cogito sum,|| wbu### [at] tznvypbz (rot'ed) || GPG Key Fingerprint:
ergo sum,  ||   These opinions are mine alone,   || 0D9BCF4CF1B71CA2F5F7
cogito     ||     others can find their own      || BFBBCBC34EDEAEFCE453
Date: 21 May 2010 06:06:05
Message: <4bf65b0d$1@news.povray.org>
Sure, but you should least have a basic understanding of the properties and
characteristics of the transistors that you are using.  And especially if
you are trying to wire up LEDs you should also get a basic understanding of
simple LED circuits, ditto for switches and inputs.  It's not that hard and
will make your life much easier when you start wiring up actual logic chips
to do useful things.
Date: 21 May 2010 06:25:56
Message: <4bf65fb4$1@news.povray.org>
>> avoids the bewildering complexities of analogue design. ;-)
> and characteristics of the transistors that you are using.  And
> especially if you are trying to wire up LEDs you should also get a basic
> understanding of simple LED circuits, ditto for switches and inputs.
> It's not that hard and will make your life much easier when you start
> wiring up actual logic chips to do useful things.
FWIW: I have owned a total of 3 different electronics kits as a kid. I
have no difficulty wiring together arrangements of switches, LEDs,
relays, and so forth. But all the manuals were a little vague on how
transistors actually work.
(I'm actually pretty damned certain I had some 7400s, and I made useful
circuits with them. But it was a long, long time ago now...)
Of course, when you buy a kit, somebody else has already figured out
what kind of LEDs to put in there, and what resister you need to connect
it to. I recall routinely using ICs to drive LEDs - but that was TTL,
and now I'm looking at CMOS, which has different characteristics.
Anyway, we'll see what happens I guess.
Date: 21 May 2010 08:24:13
Message: <4bf67b6d$1@news.povray.org>
On 5/20/2010 10:29 AM, Invisible wrote:
> Mike Raiford wrote:
>> Unrelated, but tangential, How do you like LogiSim?
> Not very much.
> I mean, it *works*, but that's about it. It's really hard work to *do*
> anything with it. All gates default to having 5 inputs, no matter how
> many times you change it back to 2. All devices default to East
> orientation, no matter how many times you change it. Even just moving
> part of the circuit to make some room is quite unecessarily difficult.
Funny, it seems to get high ratings on SourceForge. ;)
But, yeah, all of your complaints are legitimate. Actually, if you click
an item on the toolbar (And I hate the way the toolbar is tied to the
project, BTW...) and change its attributes there, then it should stick.
Pin labels on a subcircuit are a major PITA. IMO it should print the pin
on the block (even if the block needs to be a tiny bit larger)
One thing that is particularly annoying is if you need a gate with an
even number of inputs beyond 2: They don't exist. So, you wind up tying
2 inputs together, then later (because you can barely see the wire
connecting those 2 inputs) wind up wiring 2 wires together and getting
an error.
> On top of that, the graphics look horrible, pin labels refuse to display
> when you need to see them, it's quite hard to label anything properly,
> and it spazzes out if you try to built a latch.
Yeah, it doesn't do too well with latches or flip-flops. I tried to
build a J-K flip-flop in it, and it fell flat. Surprisingly the latch
worked fine (Maybe because it was a NAND latch, instead of a NOR latch?)
Another nuisance that I've encountered a frustratingly large amount of
the time is the "phantom wire", where you'll click somewhere to select
something and a wire will appear out of what appears to be nowhere
(usually connecting to half a dozen wires that shouldn't be tied together.)
Also frustrating is the lack of bidirectional pins for subcircuits. I
started my design, and only when going out to the main block and
wondering why the app didn't seem to pass signals out when I was asking
for signals did I discover that inconvenient fact.
I'm not terribly concerned with how the application looks. It functions
reasonably if you stay away from the caveats.
> But apart from all that, it works perfectly. :-}
It does the job, at least. It's somewhat better than the rest of the
programs out there.
One thing the program truly needs is hotkeys. The way it is now requires
excessive mousing.
Falstad's circuit sim seems a bit easier to use at times, and it's
interface isn't stellar.
> As if the problem of designing complex arrangements of logic wasn't hard
> enough to start with...
Heh. A side project to this whole thing is writing my own logic
simulator. I've got it at least moving signals from point a to point b
reliably. I can modify wires and move things around in the program, but
that's about it. My simulation model is different (from what I can tell)
from Logisim, so I'm guessing the whole flipping out over oscillation
and stopping the simulator may not happen. We'll see, but that's the
trouble with feedback. ;)
Actually I'm quite happy with myself as far as my sim's UI code goes at
the moment, even if it's extremely minimal. One of the issues I ran into
was reconciling the pin connections from their locations. Walking the
list of pins for each item's pin took a painfully long time once you had
an appreciable amount of items on the board. My solution: a quadtree.
This morning I filled the board up with over 100 wires, and with an
average of 10 iterations it finds the nearest pin. As opposed to the 100
iterations it would take before. Nice savings (it becomes important
after moving an item, because the program checks that every pin is
connected, and removes connections on any previously connected pins)
Also, when dragging handles or items, the interface highlights areas
where a pin will either split a wire or connect to another pin. Since
this happens hundreds of times in the course of a drag operation, you
get more than a few dozen items, and the UI gets sluggish.
I have the project on SourceForge (yeah, I'm going to do the entire open
source thing with it. Why not?) But, contrary to their suggestions of
releasing files on essentially day 0, I haven't released anything yet.
Once I get more of the basics done, I'll do a preview release.
One of the things that would be nice is the ability to create a timing
graph.
I also have a design goal of allowing the interface to be flexible. Such
as allowing the user to assign hotkeys to items, giving a choice between
We'll see if it turns out to be anything more than vaporware, though. I
have a history of ethereal personal programming projects.
~Mike
Date: 21 May 2010 08:32:24
Message: <4bf67d58$1@news.povray.org>
On 5/20/2010 3:20 AM, Invisible wrote:
> Now looking at <http://focus.ti.com/lit/ug/scyd013b/scyd013b.pdf>, on
> page 231 (which is actually page 236 of the PDF file), we see that for
> the 74HC00 I'm looking at using, we have Icc <= 0.02 mA, Iol = -Ioh <= 4
> mA, and tPLH = tPHL <= 27 ns. Now, if I actually knew WTF that means...
Icc sounds like the supply current, Ioh/Iol would be the currents the
output is capable of sourcing or sinking, tPLH and tPHL would be the
slew rate for the device (e.g. how fast it transitions from one state to
the next)
~Mike
Date: 21 May 2010 08:40:44
Message: <4bf67f4c@news.povray.org>
>> Not very much.
Too right! ;-)
I would literally have never thought of that.
That and the subcircuit label...
Yeah, that too. Hello? It's software? It's not like with real hardware
where it would *cost money* to have more sizes available. :-P
It's trying to be helpful by detecting circuits which are unstable.
Actually, I found a small hack: If you have, say, an RS latch and you
configure the S pin to float low and the R pin to float high, it
generally stops complaining. (Unless something really *is* wrong...)
Yeah. The whole wiring concept is just awkward. For example, Reactor
(which has nothing to do with electronics but does involve wiring things
together) has wires that go in a straight line from pin to pin. And when
you move stuff, IT DOESN'T BREAK ALL THE WIRES OR RANDOMLY CONNECT THEM
TO OTHER PINS! Sheesh, it's not rocket science...
So far I haven't found this to be a problem.
I'd prefer something less ugly to look at, personally.
> programs out there.
KLogic was easier to wire up. And it could do simulation graphs, which
is extremely useful when you're trying to check, e.g., that your flip
actually flops on the rising edge.
On the other hand, KLogic crashes constantly, and sometimes gives you
blatently incorrect results, which is far, far worse than merely being
difficult to use.
> excessive mousing.
It already *has* keyboard shortcuts for selecting different gates and
stuff. What are you asking for?
Which one?
> simulator.
I also considered doing this. It would be nice to be able to concentrate
on building logic rather than working around the limitations of some tool.
The reason I haven't attempted this yet is that I have literally no clue
how to do something as complex as registering arbitrary mouse clicks and
drawing sophisticated graphics in response. (E.g., how the hell do you
figure out what the user just clicked on? Usually I let the toolkit sort
that out - but this doesn't work if you draw everything yourself.)
> graph.
Join the club. ;-)
Date: 21 May 2010 09:20:18
Message: <4bf68892$1@news.povray.org>
On 5/20/2010 3:38 AM, scott wrote:
> The HC series can sink and source up to 4 mA on the output pins if you
> want the signals to still be valid (eg for input to further logic
> gates). If you are just using them to drive LEDs then apparently up to
> 20 mA is OK.
So long as the voltage doesn't sag below the forward voltage for the LED
it should be OK. I think at that current it will barely be able to drive
an LED.
~Mike
Date: 21 May 2010 09:25:05
Message: <4bf689b1@news.povray.org>
On 5/20/2010 12:14 PM, Orchid XP v8 wrote:
> Datasheets aren't manuals. They assume that you already know what, say,
> a Gated D-Latch is, and that you just want to know what its maximum
> driving current is or something. If you *don't* already know what a
> Gated D-Latch is, the datasheet will be of no use at all. You need
> *real* instructions.
Many datasheets will give you a truth table, and some even have
schematic diagrams. They assume a basic understanding of electronics,
though.
>> Have you ever looked at e.g.
>> http://en.wikipedia.org/wiki/File:TTL_npn_nand.svg ?
> 1. What is this thing?
A TTL NAND gate
> 2. How does it help?
You should be able to see why the input floats high from the schematic.
~Mike
