![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah yes, but for the weird capitalisation, this could look even more
dangerous than it already does...
Yeah, the trouble with LaTeX is that you sometimes get so excited with
how awesome the typesetting looks and writing the intro page and setting
up clever macro frameworks that you forget to, you know, WRITE SOME CONTENT!
Or maybe it's only me that does this?
I also find that whenever I go to somewhere like Staples, I have to
resist the urge to buy *everything*. It's like, "OMG, look! They have
*pens*! They have *pens* that actually *work*!! And look here! They sell
*paper*! Ooo, and *rulers*! I can never find one of those at home! Oh
God, over here they've got *erasers*! And a *hole punch*!! Ooo, and this
isle sells *card*! And..."
And then you have to stand back and say "no, *wait*. What the hell do I
need this much stationary for? Put it back on the shelves."
There's something really addictive about stationary...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> CONTENT!
Raw LaTex can be disturbing... that's why using a GUI like lyx is
somehow helpful, at least for me.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> CONTENT!
LyX is nice, but it doesn't let you use certain features. (And it
certainly doesn't let you add custom environments and stuff.) That's why
I generally use LaTeX directly. Still, LyX certainly has advantages -
like having some idea what your document is going to look like without
recompiling it every 20 seconds...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I love how beautiful the output of TeX is. But I utterly hate the
trouble and strife of trying to alter how it does its job in even the
most trivial way.
I guess the fundamental problem is that TeX forces you to write
imperative instructions describing what actions to perform, rather than
allowing you to declaratively specify what you want the final result to be.
(And the *other* problem is that back when TeX was designed, you had to
actually care about whether the character set was ASCII or EBCDIC.)
For example, I want to typeset all my source code examples in dark green
instead of black. No problem. Define a new environment that inserts a
"change to green" command right before you start typing.
Oh, wait. Only THE FIRST LINE of text comes out green. The rest is
black. WTF?
Now I guess I could go digging and try to figure out what deep, dark
command sequence LaTeX is executing at each line end and start hacking
away at it. But I'd really rather not. So let's see if I can use
grouping to apply the colour change to everything...
Ah yes, that works. Now the whole example is green.
EXCEPT when the code fragment just happens to fall on the very first
line of a page, in which case it unexplicably comes out black again.
*facepalm*
If only you could take the beautiful fonts and wonderful typesetting
engine of TeX and stick it in a modern, modular, extensible framework. :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You know that you should concentrate on your actual text rather than
playing with the fancy gadget, unless you are in design mode.
That's why I like lyx: when you create a text, you do not change the
model; and when you create a model, you are not writing actual text.
WYMIWYG, not WYSIWYG !
Good works remain good works under a better presentation.
Hiding bad works within good presentation is just B*S*ing the readers:
fine for marketing, bad for scientific publication.
If you need a specific presentation, either you are a template designer
or you are wasting your productivity on minor details.
Prepare your template, then write all your documents; Do not make the
"template" at the same time than the documents, think beforehand!
The time spend in the preparation will be factored in the ease to write
the documents later (and staying away of eye-candy at that time).
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Indeed. That's one of the dangers of using something that looks as
lovely as TeX.
When I tried LyX, I found it to be rather nice to use, but you can't
change *anything* at all. At least with using TeX directly, there is
some chance of altering things.
Anyway, this is one of the things I like about HTML. If I want my source
listings in green, I can say in the document "this bit is source", and I
can say in the stylesheet "please make source green", and it's done in,
like, 20 seconds. In TeX you have to spend hours faffing around trying
to get it to do that.
What all this means is that HTML lets me concentrate on the structure of
my document, not how to format it. I can experiment with formatting
later. I can with TeX too - it's just 400x harder. On the other hand,
HTML documents aren't very attractive to look at, while TeX documents are.
I'm not going to pretend to be able to decipher that.
Sure. But the presentation I'm trying to achieve is hardly elaborate. I
just want to visually distinguish program identifiers from prose.
Perhaps. It just irritates me that something this trivial is so
difficult to do.
That only works if you know what you're going to write before you write
it - and *that* is a whole other debate. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> *facepalm*
And then I spent 20 minutes wondering why a code fragment works just
fine in the document body, but breaks in a source listing. Of course,
the tabbing environment redefines the accent commands. *sigh*
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
http://www.tex.ac.uk/cgi-bin/texfaq2html?label=tabacc
I guess this is what you get for using a typesetting system based on a
1970s-era text macro substitution system written for the PDP-10...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> *facepalm*
This just gets weirder. Apparently this is a DVI previewer thing. If you
have colour commands near the very top or bottom of a page, the
following page sometimes changes colour. Sometimes flicking forwards and
backwards through the pages changes the colour that the text appears in.
PDFTeX seems to have no such issue - but still, this just goes to
hilight that TeX was never designed to cope with colour in the first
place. It's a miracle it works at all!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Stolen. Thanks.
Mary had a little lamb, a little beef, and a little ham.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
