POV-Ray : Newsgroups : povray.off-topic : NSIS Server Time
14 May 2026 23:53:44 EDT (-0400)
  NSIS (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: NSIS
Date: 24 Mar 2010 07:47:43
Message: <4ba9fbdf$1@news.povray.org>
scott wrote:
>> (E.g., do a default install of Debian. Click the button marked "change
>> screen resolution". In the window that comes up, the slider to change
>> resolution is disabled. Yeah, that's really helpful.)
> This was the same in Windows before XP.  I can't remember the number of
> times I had to go looking for graphics card drivers while not being able
> to change out of 640x480x8bit resolution...
If you don't have the necessary driver installed, it is impossible to
drive the card at a higher resolution.
If Debian wasn't finding the correct driver and defaulting to some
horribly low resolution, I could understand that.
However, the *actual* problem is that Debian is defaulting to a
resolution larger than my monitor, and I'd like to *reduce* it to, say,
1024x768 or something. But nooo...
As petty as it sounds, this is the main reason I'm using OpenSUSE. It
defaults to a sane resolution, and it seems to somehow "know" it's
running under VMware, so things like mouse integration work out of the box.
(I tried installing VMware tools on Debian, but it can't compile it
because there's no compiler. So I installed the compiler, but then it
complained that I don't have the kernel headers. So I installed the
kernel headers. And then it complained that the kernel was compiled with
a different compiler than the one I installed. So I looked for the
version it's asking for... and it's not listed in the Debian package
database. At this point, I gave up in utter frustration.)
It's a pitty really - Debian starts up much faster than OpenSUSE. (Not
that "faster" is the same as "fast", mind you...)
Subject: Re: NSIS
Date: 24 Mar 2010 17:18:57
Message: <4baa81c1$1@news.povray.org>
On 3/24/2010 4:28 AM, Invisible wrote:
> As I say, I did look at making an MSI file, but that is apparently
> drastically more complex still. (And it's even less-well documented. I
> can find the pages that tell you all about how fantastic MSI is, but not
> the pages they tell you HOW TO MAKE ONE!)
This is SOP. Please refer to articles 34234-5434 and 52334-235, where we
explain why this is a wonderful way to document things and became SOP,
but not how it actually works. lol
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Subject: Re: NSIS
Date: 25 Mar 2010 18:41:04
Message: <4babe680@news.povray.org>
You were the one asking about the benefits of using an IDE, yes?  ;-)
   Yes, we're traveling togeher,
   but to different destinations.
Subject: Re: NSIS
Date: 25 Mar 2010 18:43:52
Message: <4babe728@news.povray.org>
Heh, there are IDEs that can do *that*?
http://blog.orphi.me.uk/
Subject: Re: NSIS
Date: 26 Mar 2010 03:49:49
Message: <4bac671d$1@news.povray.org>
I don't know anything about the detail of installers or how they work, I
just click "Publish" in Visual Studio and tell it where to put the
installer.  You can also tick boxes for which prerequisites your installer
also checks for and installs (eg the .net framework, a certain version of
Windows Installer, XNA framework, various SQL servers, etc) - this seems to
be intelligently correct by default though...
Subject: Re: NSIS
Date: 26 Mar 2010 05:01:16
Message: <4bac77dc@news.povray.org>
> installer also checks for and installs (eg the .net framework, a certain
> version of Windows Installer, XNA framework, various SQL servers, etc) -
> this seems to be intelligently correct by default though...
OK, that's kinda cool. What does it make? An executable package? Or an
MSI file?
I wonder if I can convince VS to build an installer for something that
wasn't compiled using VS... (Or, for that matter, whether the free
edition even has this functionallity in the first place!)
Subject: Re: NSIS
Date: 26 Mar 2010 05:38:55
Message: <4bac80af$1@news.povray.org>
> OK, that's kinda cool. What does it make? An executable package? Or an MSI
> file?
I have the free MS Express C#, if you point it to a folder to publish to, it
makes a "setup.exe", a "<name>.application" file and a "Application Files"
folder (that contains any data/content files your application needs).
I think in the non-free VS you have vastly more options for installers, I
would be surprised if what you ask wasn't possible.
Subject: Re: NSIS
Date: 26 Mar 2010 08:01:24
Message: <4baca214$1@news.povray.org>
>> MSI file?
> to, it makes a "setup.exe", a "<name>.application" file and a
> "Application Files" folder (that contains any data/content files your
> application needs).
Right. So it's an executable rather than an MSI file.
(While on the surface there's little obvious difference, apparently MSI
files have certain advantages - like being able to remotely deploy them
and stuff.)
> I would be surprised if what you ask wasn't possible.
Wouldn't surprise me if the free version has fewer options. (Why would
you buy the expensive one otherwise? And deployment is the kind of thing
that only commercial people are likely to care particularly about.) I do
wonder if any version of VS can build arbitrary installers though...
Subject: Re: NSIS
Date: 26 Mar 2010 08:02:27
Message: <4baca253$1@news.povray.org>
http://msdn.microsoft.com/en-us/library/zcbsd3cz%28VS.80%29.aspx
Well, that seems quite clear.
(Oddly, the same table doesn't seem to exist for 2008, only 2005.)
Subject: Re: NSIS
Date: 26 Mar 2010 12:52:10
Message: <4bace63a@news.povray.org>
It depends what you ask for and what version of the IDE you use.
