POV-Ray : Newsgroups : povray.off-topic : Network devices hanging explorer Server Time
13 Oct 2024 05:17:01 EDT (-0400)
  Network devices hanging explorer (Message 1 to 10 of 22)
Subject: Network devices hanging explorer
Date: 8 Mar 2010 04:08:08
Message: <4b94be78@news.povray.org>
On my laptop I have 2 network drives mapped, and a network printer.  It
works fine when connected to the network that these devices are on.  However
if I go to a different network (eg home WLAN) then windows  explorer becomes
almost impossible to use.  Every single time I click a folder or file the
explorer window hangs completely for 10 or 20 seconds.
If I am not connected to any network, or I remove the two network maps and
the printer, this problem disappears.  This makes me think explorer is
somehow searching for these network resources, even when there is no chance
to find them.
How do other people cope with this, I can't be the only one in this
situation?
Subject: Re: Network devices hanging explorer
Date: 8 Mar 2010 04:18:57
Message: <4b94c101$1@news.povray.org>
> folder or file the explorer window hangs completely for 10 or 20 seconds.
That is one of the things I love about Windows Explorer - it's complete
inability to handle delays.
Click on A: by mistake, when there's nothing in the drive, and
essentially the entire Windows UI locks up until it has determined
there's nothing in the drive. And I don't just mean the window in
question. The start menu stops working, windows stop repainting
themselves, virtually the entire damned OS locks up because of one
stupid disk drive! WTF?
Anyway, as to *your* problem... The whole "it locks up for 20 seconds"
deal reeks of "network timeout". BTW, does anybody know why network
timeouts are always set to 7 minutes or something? I mean, if you
haven't got a reply in 800 ms or so, it's *obvious* that you're never
going to get one! Retry or give up. Don't sit there for 7 minutes waiting!
I presume you've tried unmapping the mapped drives. Is the laptop part
of a domain?
Date: 8 Mar 2010 04:23:55
Message: <4b94c22b@news.povray.org>
I bet there's some core code that is still from Windows 1 :-)
> Click on A: by mistake, when there's nothing in the drive, and essentially
> the entire Windows UI locks up until it has determined there's nothing in
> the drive.
Don't remember the last machine I used with an "A" drive, but the same
happens with CDs and DVDs that it can't read properly.
As I said, if I unmap the drives the problem goes away.  Issue is that I
don't want to have to remap them everytime I connect to the network they're
on!
I just couldn't find the "Only try to connect once to mapped drives until
the network connection is changed" checkbox...
> Is the laptop part of a domain?
Yes.
Date: 8 Mar 2010 04:48:54
Message: <4b94c806@news.povray.org>
>> complete inability to handle delays.
Would surprise me. Apparently Windows NT still contains the entire
Windows 3 kernel, unmodified, in case any software wants to use it.
Backwards compatibility is a truly evil thing. (This is why Haskell's
unofficial motto is "avoid success at all costs".)
Or just the drive is empty. You'd think this wouldn't take long to
figure out, but...
> they're on!
> until the network connection is changed" checkbox...
I'm not sure if there is one.
What I'd probably do is write a batch file to unmap the drives, and
another to map them again. Put those two scripts on the desktop, click
'em when required.
> Yes.
It's probably searching for a domain controller to authenticate to so
that it can map the network drives. That's probably what the problem is.
Date: 8 Mar 2010 06:42:16
Message: <op.u88ysvaumn4jds@phils>
And lo On Mon, 08 Mar 2010 09:08:06 -0000, scott <sco### [at] scottcom> did
spake thusly:
> However if I go to a different network (eg home WLAN) then windows
> explorer becomes almost impossible to use.  Every single time I click a
> and the printer, this problem disappears.  This makes me think explorer
> is somehow searching for these network resources, even when there is no
> chance to find them.
> situation?
Hmm okay you don't say which version of Windows you're running, but in
Folder options try turning off "Automatically search for network folders
and printers" if that doesn't work try turning off the SSDP service.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 8 Mar 2010 06:54:29
Message: <4b94e575@news.povray.org>
Ah yes - I forgot that when I get a new PC I always turn this setting
off. Maybe that's why I haven't seen this problem before...
Date: 8 Mar 2010 07:22:00
Message: <4b94ebe8@news.povray.org>
XP 32 bit
> but in  Folder options try turning off "Automatically search for network
> folders  and printers"
Did that already, as it looked liked a useless feature anyway :-)
Done it - will see what happens later at home...
Date: 8 Mar 2010 07:26:31
Message: <op.u880unxdmn4jds@phils>
And lo On Mon, 08 Mar 2010 12:21:57 -0000, scott <sco### [at] scottcom> did
spake thusly:
> XP 32 bit
>> network folders  and printers"
The only other thing I can think of off the top of my head is UPnP
Phil Cook
Date: 9 Mar 2010 02:51:26
Message: <4b95fdfe$1@news.povray.org>
OK I think I've sorted it.  After more googling using some of the info given
here I tracked down a copy of Filemon to see what explorer was doing.  It
turns out that every time I tried to navigate or open a right click menu
explorer was looking for "shell32.dll" in C:\Windows and failing to find it
(it is is the system32 folder), and then it was looking for it in the root
of G:\ (my personal network share).  I have no clue why it was doing this,
but it was doing it mulitple times whenever I tried to do anything in an
explorer window.  Obviously explorer only works in a single thread, so the
call to open a non-existant network file was hanging the entire process for
10 seconds or so.
I simply copied shell32.dll from C:\Windows\System32 into C:\Windows and now
everything is zipping along like a new machine - even with the inaccessible
network shares and printers!
Date: 9 Mar 2010 03:24:43
Message: <op.u9akbgon7bxctx@toad.bredbandsbolaget.se>
Not a good idea.
Try using ShellExView to see if there is a misconfigured shell extension,
or a remnant of some malware.
FE
