POV-Ray : Newsgroups : povray.off-topic : Network devices hanging explorer Server Time
27 Feb 2026 09:53:10 EST (-0500)
  Network devices hanging explorer (Message 13 to 22 of 22)
Subject: Re: Network devices hanging explorer
Date: 9 Mar 2010 04:51:29
Message: <4b961a21@news.povray.org>
> Just off the top of my head:
> - Files that share the name, but not the path, of a system file are common
> indicators of malware.
> - The original file in 'system32' is protected against unauthorised
> changes (though less so in WinXP if you are using an administrator
> account).
> - The original file in 'system32' is affected by system updates.
> - You are treating a symptom, not the cause.
Good point about the auto-updates, maybe I'll make it automatically copy the
shell32.dll from system32 into windows each time I boot to make sure any
updates are reflected.
> Try searching for it in AutoRuns (from SysInternals). If it does not show
> up there, try searching for it in the registry.
> Also keep in mind that it might not be registered as
> "windows\shell32.dll". It could be "%WINDIR%\shell32.dll",
> "%SYSTEMROOT%\shell32.dll" or some other variant.
Nothing showed up, every shell32.dll was referenced in the system32 folder.
I don't know what else to try, but at least I have my computer back working
at a normal speed, even if it is a bit of a hacky temporary fix.
Date: 9 Mar 2010 05:09:11
Message: <op.u9ao5jg17bxctx@toad.bredbandsbolaget.se>
> the shell32.dll from system32 into windows each time I boot to make sure
> any updates are reflected.
That may be difficult if the DLL is actually being loaded by explorer.exe.
> folder. I don't know what else to try, but at least I have my computer
> back working at a normal speed, even if it is a bit of a hacky temporary
> fix.
Grasping for straws here, but check that "Windows\system32" comes before
"Windows" in your %PATH%.
It could also be caused by a crappy shell extension with an import table
entry for "windows\shell32.dll". That would be a little more tedious to
track down, though you could come a long way by simply disabling all
non-essential extensions with ShellExView.
FE
Date: 9 Mar 2010 17:20:03
Message: <4b96c993@news.povray.org>
scott wrote:
> I bet there's some core code that is still from Windows 1 :-)
No. Vista added the ability to cancel an outstanding IO request that was
hanging. XP doesn't have that, so you get a timeout. Known problem fixed
years ago.
> Don't remember the last machine I used with an "A" drive, but the same
> happens with CDs and DVDs that it can't read properly.
That in part is a kernel/driver problem, since it actually *does* hang the
whole machine to a large extent.
> As I said, if I unmap the drives the problem goes away.  Issue is that I
> don't want to have to remap them everytime I connect to the network
> they're on!
Shell scripts to the rescue?
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 9 Mar 2010 17:21:09
Message: <4b96c9d5$1@news.povray.org>
Phil Cook v2 wrote:
> The only other thing I can think of off the top of my head is UPnP
SSDP *is* UPnP.
Date: 10 Mar 2010 04:21:27
Message: <op.u9chmarjmn4jds@phils>
And lo On Tue, 09 Mar 2010 22:21:04 -0000, Darren New <dne### [at] sanrrcom>
did spake thusly:
> SSDP *is* UPnP.
I thought SSDP was what found UPnP devices; so it might freeze because
it's looking or it might freeze because it's trying to interface with it.
But yes turning off SSDP should turn off UPnP too.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 11 Mar 2010 10:37:28
Message: <4b990e38$1@news.povray.org>
> did spake thusly:
>> SSDP *is* UPnP.
SSDP is part of uPnP, yes. It's the equivalent of WINS for netbios, tracking
the announcements.
Date: 11 Mar 2010 12:40:01
Message: <web.4b9929f3acd5574b773c9a3e0@news.povray.org>
they are right after all.  Let's all just hang IE... ;)
Date: 19 Mar 2010 03:46:38
Message: <4ba32bde$1@news.povray.org>
> Try using ShellExView to see if there is a misconfigured shell extension,
> or a remnant of some malware.
LOL, my AV software has flagged this as a "hacking tool" :-)
Date: 19 Mar 2010 05:01:20
Message: <4ba33d60$1@news.povray.org>
>> extension, or a remnant of some malware.
According to SecuROM (or whatever it's called), Process Explorer is a
"cracker tool", and having it installed prevents Crysis from running.
Date: 20 Mar 2010 17:52:14
Message: <4ba5438e@news.povray.org>
My AV used to complain about a Windows port of netcat -.-
