POV-Ray : Newsgroups : povray.off-topic : Network devices hanging explorer Server Time
12 Jul 2026 05:16:29 EDT (-0400)
  Network devices hanging explorer (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Network devices hanging explorer
Date: 9 Mar 2010 03:41:06
Message: <4b9609a2$1@news.povray.org>
>> I simply copied shell32.dll from C:\Windows\System32 into C:\Windows
> Not a good idea.
OOC why not?
> Try using ShellExView to see if there is a misconfigured shell extension,
> or a remnant of some malware.
What am I looking for in ShellExView?  A lot of them have
system32/shell32.dll as the filename, but none are pointing to
windows/shell32.dll.  I wonder why explorer.exe is looking there for it?
Date: 9 Mar 2010 04:19:53
Message: <op.u9amvevn7bxctx@toad.bredbandsbolaget.se>
>> Not a good idea.
> OOC why not?
Just off the top of my head:
- Files that share the name, but not the path, of a system file are common
indicators of malware.
- The original file in 'system32' is protected against unauthorised
changes (though less so in WinXP if you are using an administrator
account).
- The original file in 'system32' is affected by system updates.
- You are treating a symptom, not the cause.
>> extension, or a remnant of some malware.
Try searching for it in AutoRuns (from SysInternals). If it does not show
up there, try searching for it in the registry.
Also keep in mind that it might not be registered as
"windows\shell32.dll". It could be "%WINDIR%\shell32.dll",
"%SYSTEMROOT%\shell32.dll" or some other variant.
FE
Date: 9 Mar 2010 04:51:29
Message: <4b961a21@news.povray.org>
> account).
Good point about the auto-updates, maybe I'll make it automatically copy the
shell32.dll from system32 into windows each time I boot to make sure any
updates are reflected.
Nothing showed up, every shell32.dll was referenced in the system32 folder.
I don't know what else to try, but at least I have my computer back working
at a normal speed, even if it is a bit of a hacky temporary fix.
Date: 9 Mar 2010 05:09:11
Message: <op.u9ao5jg17bxctx@toad.bredbandsbolaget.se>
> the shell32.dll from system32 into windows each time I boot to make sure
> any updates are reflected.
That may be difficult if the DLL is actually being loaded by explorer.exe.
> folder. I don't know what else to try, but at least I have my computer
> back working at a normal speed, even if it is a bit of a hacky temporary
> fix.
Grasping for straws here, but check that "Windows\system32" comes before
"Windows" in your %PATH%.
It could also be caused by a crappy shell extension with an import table
entry for "windows\shell32.dll". That would be a little more tedious to
track down, though you could come a long way by simply disabling all
non-essential extensions with ShellExView.
FE
Date: 9 Mar 2010 17:20:03
Message: <4b96c993@news.povray.org>
scott wrote:
> I bet there's some core code that is still from Windows 1 :-)
No. Vista added the ability to cancel an outstanding IO request that was
hanging. XP doesn't have that, so you get a timeout. Known problem fixed
years ago.
> Don't remember the last machine I used with an "A" drive, but the same
> happens with CDs and DVDs that it can't read properly.
That in part is a kernel/driver problem, since it actually *does* hang the
whole machine to a large extent.
> As I said, if I unmap the drives the problem goes away.  Issue is that I
> don't want to have to remap them everytime I connect to the network
> they're on!
Shell scripts to the rescue?
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 9 Mar 2010 17:21:09
Message: <4b96c9d5$1@news.povray.org>
Phil Cook v2 wrote:
> The only other thing I can think of off the top of my head is UPnP
SSDP *is* UPnP.
Date: 10 Mar 2010 04:21:27
Message: <op.u9chmarjmn4jds@phils>
And lo On Tue, 09 Mar 2010 22:21:04 -0000, Darren New <dne### [at] sanrrcom>
did spake thusly:
> SSDP *is* UPnP.
I thought SSDP was what found UPnP devices; so it might freeze because
it's looking or it might freeze because it's trying to interface with it.
But yes turning off SSDP should turn off UPnP too.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 11 Mar 2010 10:37:28
Message: <4b990e38$1@news.povray.org>
> did spake thusly:
>> SSDP *is* UPnP.
SSDP is part of uPnP, yes. It's the equivalent of WINS for netbios, tracking
the announcements.
Date: 11 Mar 2010 12:40:01
Message: <web.4b9929f3acd5574b773c9a3e0@news.povray.org>
they are right after all.  Let's all just hang IE... ;)
Date: 19 Mar 2010 03:46:38
Message: <4ba32bde$1@news.povray.org>
LOL, my AV software has flagged this as a "hacking tool" :-)
