POV-Ray : Newsgroups : povray.off-topic : Try Haskell Server Time
4 Jul 2026 18:40:07 EDT (-0400)
  Try Haskell (Message 3 to 12 of 62)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Try AJAX
Date: 2 Mar 2010 05:19:04
Message: <4b8ce618@news.povray.org>
>> Actually, I have a question. How is a site like this even physically
>> possible in the first place? How can you send a request to the server
>> and receive a response without reloading the entire page?
> The term you're looking for is AJAX, which is a method of programming
> web pages that uses the XMLHttpRequest function. If you understand
> generally how XMLHttpRequest works, you'll understand how this works.
Right, so... if I'm understanding this right, XMLHttpRequest allows a
mere script to instruct the browser to send an HTTP request, and return
the body of the response as data, which the script can then further
manipulate? (Rather than, say, just nagivating to another page, in which
case the script can't process the data because the script won't even
*exist* any mroe...)
I had no idea that you can actually do that...
(Then again, Wikipedia's example code seems to show JavaScript doing
exception handling too, which I had no idea was possible.)
Date: 2 Mar 2010 05:56:44
Message: <4b8ceeec$1@news.povray.org>
> manipulate?
http://www.w3.org/TR/XMLHttpRequest/#the-xmlhttprequest-interface
Seems reasonably clear...
Subject: Re: Try Haskell
Date: 2 Mar 2010 06:43:58
Message: <4b8cf9fe$1@news.povray.org>
> http://tryhaskell.org/
The tutorial was good up until step 7, then the line:
> let villain = (28,"chirs") in fst villain
Made no sense at all.  I get it returns 28, but it's confusing what's going
on, why the need for a variable (I assume villain is a variable name?).  I
would have thought that writing 'fst (28,"chirs")' would be the thing to do
to return 28? (I guess that fst returns the first element of a list?)
A lot of guessing and confusing on my part without much explanation...
Date: 2 Mar 2010 06:48:19
Message: <4b8cfb03$1@news.povray.org>
I agree. Several concepts introduced at once without much explanation.
(Apparently the author also agrees, and is looking at trying to do
better...)
Date: 2 Mar 2010 11:56:28
Message: <4b8d433c$1@news.povray.org>
Exactly, yes.
Well, there ya go. MS actually invented that technique with ActiveX for
their Outlook web thing, and everyone else picked up on it and turned it
into a standard.
Huh. I don't remember ever doing that, but I guess if the browser can tell
you about errors, then there's probably some way to catch them.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 2 Mar 2010 11:58:50
Message: <4b8d43ca$1@news.povray.org>
> into a standard.
Looking at the W3C standard spec, there seems to be *huge* abouts of
tricky processing and non-obvious behaviour which strongly looks as if
it's only there for backwards compatibility (i.e., because this is the
ad hoc way the first implementation happened to do it).
Man, web stuff is messy...
Date: 2 Mar 2010 12:06:24
Message: <4b8d4590$1@news.povray.org>
Yeah. You want to know who started the browser wars? Look at your agent
string. :-)
There are also a lot of standards that got changed in subtle ways that broke
a lot of stuff, because the first spec was basically "here's how we do it."
For example, Netscape said "Here's how we do cookies.  Yadda yadda only save
20 per site yadda yadda."  IE did the same thing.  W3C comes along and makes
a standard that says any number of cookies per site. Lots of web sites that
for some stupid reason depended on only having 20 cookies fail with
W3C-compliant browsers, continuing to work with IE *because* MS won't follow
the standards and instead wants the web pages to work right for their
customers, even when the pages on the server are stupidly coded. Launch
complaining in 3... 2... 1....
Date: 2 Mar 2010 12:17:52
Message: <4b8d4840@news.povray.org>
  You clearly haven't used gmail.
Date: 3 Mar 2010 04:06:29
Message: <4b8e2695@news.povray.org>
Indeed. But I have, at least, heard of it. ;-)
Date: 3 Mar 2010 05:03:46
Message: <4b8e3402$1@news.povray.org>
> Right, so... if I'm understanding this right, XMLHttpRequest allows a mere
> script to instruct the browser to send an HTTP request, and return the
> manipulate?
What happens when the user presses the back button after such a process?
Can the script intercept this and provide its own "back" functionality?
I've definitely got annoyed by some sites where you hit the back button and
it takes you to a site you were looking at 10 minutes ago, because all the
things you've been doing on this site haven't actually loaded a new page...
