POV-Ray : Newsgroups : povray.off-topic : New computer... Wish me luck Server Time
18 Dec 2025 06:20:07 EST (-0500)
  New computer... Wish me luck (Message 1 to 10 of 20)
Subject: New computer... Wish me luck
Date: 16 Feb 2010 10:29:01
Message: <4b7ab9bd$1@news.povray.org>
I pulled the trigger, and finally ordered my new computer components.  I did
quite a bit of research, but of course I'm still nervous about putting it
all together.
I pretty much bought everything just like I said in my last post, but for
anyone interested, here are the specifics.  Ordered from newegg.com.
1 x G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual
Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ - Retail
1 x Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
1 x MSI N250GTS Twin Frozr 1G GeForce GTS 250 1GB 256-bit DDR3 PCI Express
2.0 x16 HDCP Ready SLI Support Video Card - Retail
1 x Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5"
Hard Drive -Bare Drive
1 x ASUS P7P55D LGA 1156 Intel P55 ATX Intel Motherboard - Retail
1 x VANTEC TF12025 120mm Case Fan - Retail
1 x LIAN LI Lancool PC-K62 Black 0.8 mm SECC, Plastic + Mesh ATX Mid Tower
Computer Case - Retail
1 x Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V
version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC
"compatible with Core i7/Core i5" Power Supply - Retail
1 x Intel Core i7-860 Lynnfield 2.8GHz LGA 1156 95W Quad-Core Processor
Model BX80605I7860 - Retail
1 x Prolimatech Megahalems Rev.B CPU Cooler - Retail
This is the largest single upgrade I have ever done, that did not require
buying an actual new computer (meaning an HP, Dell, etc.)  Actually, I
haven't bought a new computer pre-assembled since I bought a 386-25MHz back
in 1990.  I'd buy a new CPU/mobo/RAM or whatever, but keep my old case,
graphics card, hard drive, etc.  But this time, the only thing I'm planning
to keep is my DVD drive and my monitor (1080p).  So, future upgrades will
likely be more RAM, more HD space, and probably Blu-Ray at some point.
Hopefully, all of the components will arrive by Friday, and I'll probably
have the thing put together late that night.  With luck, it will all work
together.
Subject: Re: New computer... Wish me luck
Date: 16 Feb 2010 12:40:01
Message: <web.4b7ad7af92f89cfdf71d62990@news.povray.org>
> all together.
aside from W7, pretty good-looking gear.  Best of luck! :)
Date: 16 Feb 2010 12:54:01
Message: <4b7adbb9$1@news.povray.org>
Does anyone ever get even close to 3Gb/s on their hard drive? I have SATA
drives and I get about 80MB (340Mb/s). I have a hard time believing that
Linux has 5x overhead writing to a hard drive.  Is there some SATA card I
don't know of that's significantly faster than the bus I have or something?
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 16 Feb 2010 13:31:09
Message: <4b7ae46d@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4b7adbb9$1@news.povray.org...
>> 3.5" Hard Drive -Bare Drive
> something?
I've always figured that if something was already in the drive cache, it
would probably transfer at (close to) 3Gb/s, but I don't think the actual
drive itself could read data anywhere near that fast.
Somewhere I saw a RAID array of (I think) 24 SDD's.  While I don't recall
what the transfer rate was, it was insanely fast.  Maybe someone here posted
it.  Don't recall.
Date: 16 Feb 2010 13:33:30
Message: <4b7ae4fa$1@news.povray.org>
"nemesis" <nam### [at] gmailcom> wrote in message
news:web.4b7ad7af92f89cfdf71d62990@news.povray.org...
>> did
>> all together.
>> OEM
>> Express
>> 3.5"
>> Tower
I'd be happy with XP 64-bit, but there doesn't seem to be such a thing...
But I can still run Linux in a vmware session, if I want.
Date: 16 Feb 2010 13:45:13
Message: <op.u78g1mqi7bxctx@toad.bredbandsbolaget.se>
> SATA drives and I get about 80MB (340Mb/s).
With an actual hard disk with actual platters you would be lucky to get a
sustained transfer rate of 100 MB/s (1 Gb/s). Burst rates can be much
higher, though.
SSD is another matter. The good ones can have sustained transfer rates
that push the limits of SATA/300.
My current system drive:
http://fe79.myftp.org/misc/HDTune_Benchmark_INTEL_SSDSA2M080G2GC.png
FE
Date: 16 Feb 2010 14:28:57
Message: <4b7af1f9@news.povray.org>
Ah, that makes sense. Thanks!
Date: 16 Feb 2010 15:48:50
Message: <4b7b04b2$1@news.povray.org>
"Fredrik Eriksson" <fe79}--at--{yahoo}--dot--{com> wrote in message
news:op.### [at] toadbredbandsbolagetse...
*drool*
Date: 16 Feb 2010 16:10:27
Message: <4b7b09c3$1@news.povray.org>
Unrelated to your question, but... At work all our servers used to use
Ultra320 SCSI drives. This bus has a max transfer rate of 320 MB/s.
Then again, when you have 6 drives on one ribbon cable, having the cable
support up to 320 MB/s suddenly makes a lot more sense...
http://blog.orphi.me.uk/
Date: 16 Feb 2010 16:12:19
Message: <4b7b0a33$1@news.povray.org>
> a sustained transfer rate of 100 MB/s (1 Gb/s). Burst rates can be much
> higher, though.
I read some benchmarks from Tom's Hardware which suggested that
expensive magnetic drives can actually beat cheap SSD in some cases, in
terms of transfer rate and/or power consumption.
This utterly boggles my mind.
(Unless they're talking about *write* speed, which is the only real
weakness of SSD, AFAIK...)
