POV-Ray : Newsgroups : povray.off-topic : An explanation of what next_permutation does Server Time
8 Apr 2026 22:35:47 EDT (-0400)
  An explanation of what next_permutation does (Message 23 to 32 of 32)
Subject: Re: An explanation of what next_permutation does
Date: 5 Dec 2009 17:57:25
Message: <4b1ae555$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> Orchid XP v8 wrote:
>>> make a typo in a C program, the program stops and says "error:
>>> segmantation fault".
>> *If* you're lucky.  What's worse is when it *doesn't*. :-)
>   You seriously claiming that if you make a typo in Haskell, it always
> magically knows that and gives you an error message?
Me? No.
I'm saying you're lucky if when you make a mistake in C you get a segfault.
If you're unlucky, you clobber some random unrelated variable that *is*
allocated and things progress as normal except with totally undefined results.
If you make a mistake in Haskell such that the results are undefined, it
stops in a way that's probably pretty easy to debug compared to a segfault in C.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 6 Dec 2009 08:29:43
Message: <4b1bb1c7@news.povray.org>
> Orchid XP v8 wrote:
> > C and C++ have debuggers which are actually useable. I'll give you that
> > one.
> Because they need it, because when something goes wrong you have to step
> outside the language into a different address space to be able to figure out
> why. ;-)
  Can you name one language which would not benefit from a debugger (which
you can use, among other things, to insert breakpoints, execute the program
step-by-step and examine the values of all objects at current scope)?
Date: 6 Dec 2009 08:37:20
Message: <4b1bb390$1@news.povray.org>
I know *I* would like it better if Haskell had a quality debugger.
They say if a Haskell program compiles, it usually works correctly. This
is true, but note that the phrase is "usually".
(There *is* a debug feature in recent versions of GHC, but it doesn't
seem to work terribly well. And crawling through a complicated piece of
program using a CLI interface isn't much fun anyway...)
http://blog.orphi.me.uk/
Date: 6 Dec 2009 12:22:03
Message: <4b1be83b$1@news.povray.org>
No language per se, but environments. :-)
I just try to avoid languages where the primary debugging tools are outside
the language. (Altho APL is cool, I can't imagine doing a production program
in a language that needs something like OBSERVE[1], for example.)
I was pretty impressed at how VS lets you put breakpoints in code-behind
pages so you can single-step a piece of code as it processes a web request,
which is really a PITA in most of the other web-oriented languages like PHP.
So yeah, of course debuggers are *useful*. Do I want an external program to
be the *only* way to track down bugs? Nah.  C is useful too. That doesn't
mean I want C to be the only language I can use.
[1] Since Google is making it hard to find, the "observe" command sets a
flag that makes each APL statement print the line it's running, puts a
carret under the current operator it's evaluating, prints out both
arguments, and then the result, essentially single-stepping the evaluation
of a single expression with copious output.
Date: 7 Dec 2009 02:59:07
Message: <4b1cb5cb@news.povray.org>
>>>     ([] , _  ) -> Nothing
>> Yeh, it's really clear what this line does to a non-Haskeller :-)
> It's pretty standard notation for functional languages. Erlang uses the
> same notation. If you get a two-element tuple with the first element being
> an empty list, the result is an arbitrary atomic value (not unlike an
> "enum") called "Nothing".
Sure, I didn't doubt there was a pretty easy explanation behind it, it's
just [], _ and the whole statement syntax had no meaning to me before it was
explained.  I would imagine once Andrew knew what -- and * does in C (I
think < and ! are common enough not to need to explain?) he would know what
the statement he highlighted meant too.  I don't see much difference.
Date: 7 Dec 2009 04:30:38
Message: <4b1ccb3e$1@news.povray.org>
> was explained.  I would imagine once Andrew knew what -- and * does in C
> (I think < and ! are common enough not to need to explain?) he would
> know what the statement he highlighted meant too.  I don't see much
> difference.
I *already* know that * is pointer dereference and -- is decriment. But
now I have to sit here and wonder "is that pre-decriment or
post-decriment? And in why is it 'not (x < y)" rather than 'x >= y'?"
And similar questions. (Why "for (;;)" rather than "while true"? Is
there some difference?)
(Also... I just noticed how many one-letter variable names there are. So
much for that being a bad thing.)
Date: 7 Dec 2009 04:43:18
Message: <4b1cce36$1@news.povray.org>
> post-decriment?
Like I have to sit and wonder why it's (suffix,prefix) and not
(prefix,suffix) in your example?
Aren't they the same? (btw the only reason I can see that you would use the
first one is if the types being used don't have the >= operator defined).
IIRC quite a lot of functions and libraries only assume that one of those
operators is implemented, so that's probably why you'll see stuff like that.
> And similar questions. (Why "for (;;)" rather than "while true"? Is there
> some difference?)
Not that I'm aware of.
Date: 7 Dec 2009 04:50:09
Message: <4b1ccfd1@news.povray.org>
>> But now I have to sit here and wonder "is that pre-decriment or
>> post-decriment?
No specific reason. I probably did it that way around because "split"
takes the list in reverse order. (Working from the back towards the
front is inefficient for a single-linked list, so I reversed the list so
it can be processed from front to back instead.) Technically you could
return the sublists either way around if you wanted. I just did it this
way because if you take (x, y) and do x ++ y, you get the original
(backwards) list. If you'd returned the components the other way around,
you'd have to do y ++ x instead.
You'd certainly think so.
> the first one is if the types being used don't have the >= operator
> defined). IIRC quite a lot of functions and libraries only assume that
> one of those operators is implemented, so that's probably why you'll see
> stuff like that.
Hmm, I see.
Of course, we're working with *digits* here, for which both operators
are definitely defined. However, it seems this part of the code is from
a library, so presumably it's supposed to work with anything.
(In Haskell, it is impossible to define one ordering relation without
also defining the others. Well, no, not impossible, but you'd have to
purposely go out of your way to do it. So in Haskell it's not something
a library needs to worry about it. But now I recall that in C++, these
are all seperate, notionally unrelated operators.)
It's like when a Haskell programmer writes a new function that's
equivilent to an existing one. You have to sit there and wonder why they
did that. Was it personal taste, or is there actually some subtle
difference you've missed?
Date: 7 Dec 2009 12:48:48
Message: <4b1d4000@news.povray.org>
  It is customary in the C++ standard library to demand as little as
possible from the types being handled. Anything requiring comparison of
element usually demands only operator< from the elements (if the algorithm
can be feasibly be implemented using that operator only).
  If you are making a generic algorithm or data container which compares
elements, it's also usually a good idea to demand as little as possible
from it, and stick to operator< exclusively, if possible.
Date: 7 Dec 2009 13:30:35
Message: <4b1d49cb$1@news.povray.org>
And other than readability, compilers these days are smart enough to
generate the same optimal[1] code for it regardless.
[1] Funny how "optimized" no longer means what it used to, isn't it?
