POV-Ray : Newsgroups : povray.off-topic : An explanation of what next_permutation does Server Time
31 Mar 2026 16:37:42 EDT (-0400)
  An explanation of what next_permutation does (Message 21 to 30 of 32)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: An explanation of what next_permutation does
Date: 5 Dec 2009 14:09:17
Message: <4b1aafdd$1@news.povray.org>
Warp wrote:
>   You seriously claiming that if you make a typo in Haskell, it always
> magically knows that and gives you an error message?
What's magic?
If you type something wrong, it might be a syntax error. (Any
half-decent compiler will catch these.) If you type the wrong name by
mistake, it's probably a type error. If you assume that a certain list
will always contain 3 items (for example) and actually it doesn't,
you'll get an exception when you try to access a non-existent element.
It's not *guaranteed* that all mistakes will be caught. If you
accidentally write "x + x" instead of "x + y", no error (just the wrong
result). Same as any other language.
Let's look at this the other way around: There is no typo you can
possibly make which will result in a segfault. (Unless you're doing
something *very* special, like calling an external C routine or
something.) About the worst that can happen is that your program eats
craploads of RAM or goes into an infinite loop. (Or, if you're using
explicit concurrency with locks, you might deadlock or something.)
http://blog.orphi.me.uk/
Date: 5 Dec 2009 17:55:21
Message: <4b1ae4d9$1@news.povray.org>
Orchid XP v8 wrote:
> C and C++ have debuggers which are actually useable. I'll give you that
> one.
Because they need it, because when something goes wrong you have to step
outside the language into a different address space to be able to figure out
why. ;-)
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 5 Dec 2009 17:57:25
Message: <4b1ae555$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> Orchid XP v8 wrote:
>>> make a typo in a C program, the program stops and says "error:
>>> segmantation fault".
>> *If* you're lucky.  What's worse is when it *doesn't*. :-)
Me? No.
I'm saying you're lucky if when you make a mistake in C you get a segfault.
If you're unlucky, you clobber some random unrelated variable that *is*
allocated and things progress as normal except with totally undefined results.
If you make a mistake in Haskell such that the results are undefined, it
stops in a way that's probably pretty easy to debug compared to a segfault in C.
Date: 6 Dec 2009 08:29:43
Message: <4b1bb1c7@news.povray.org>
> > one.
> why. ;-)
  Can you name one language which would not benefit from a debugger (which
you can use, among other things, to insert breakpoints, execute the program
step-by-step and examine the values of all objects at current scope)?
Date: 6 Dec 2009 08:37:20
Message: <4b1bb390$1@news.povray.org>
I know *I* would like it better if Haskell had a quality debugger.
They say if a Haskell program compiles, it usually works correctly. This
is true, but note that the phrase is "usually".
(There *is* a debug feature in recent versions of GHC, but it doesn't
seem to work terribly well. And crawling through a complicated piece of
program using a CLI interface isn't much fun anyway...)
Date: 6 Dec 2009 12:22:03
Message: <4b1be83b$1@news.povray.org>
No language per se, but environments. :-)
I just try to avoid languages where the primary debugging tools are outside
the language. (Altho APL is cool, I can't imagine doing a production program
in a language that needs something like OBSERVE[1], for example.)
I was pretty impressed at how VS lets you put breakpoints in code-behind
pages so you can single-step a piece of code as it processes a web request,
which is really a PITA in most of the other web-oriented languages like PHP.
So yeah, of course debuggers are *useful*. Do I want an external program to
be the *only* way to track down bugs? Nah.  C is useful too. That doesn't
mean I want C to be the only language I can use.
[1] Since Google is making it hard to find, the "observe" command sets a
flag that makes each APL statement print the line it's running, puts a
carret under the current operator it's evaluating, prints out both
arguments, and then the result, essentially single-stepping the evaluation
of a single expression with copious output.
Date: 7 Dec 2009 02:59:07
Message: <4b1cb5cb@news.povray.org>
>>>     ([] , _  ) -> Nothing
>> Yeh, it's really clear what this line does to a non-Haskeller :-)
> It's pretty standard notation for functional languages. Erlang uses the
> same notation. If you get a two-element tuple with the first element being
> an empty list, the result is an arbitrary atomic value (not unlike an
> "enum") called "Nothing".
Sure, I didn't doubt there was a pretty easy explanation behind it, it's
just [], _ and the whole statement syntax had no meaning to me before it was
explained.  I would imagine once Andrew knew what -- and * does in C (I
think < and ! are common enough not to need to explain?) he would know what
the statement he highlighted meant too.  I don't see much difference.
Date: 7 Dec 2009 04:30:38
Message: <4b1ccb3e$1@news.povray.org>
> was explained.  I would imagine once Andrew knew what -- and * does in C
> (I think < and ! are common enough not to need to explain?) he would
> know what the statement he highlighted meant too.  I don't see much
> difference.
I *already* know that * is pointer dereference and -- is decriment. But
now I have to sit here and wonder "is that pre-decriment or
post-decriment? And in why is it 'not (x < y)" rather than 'x >= y'?"
And similar questions. (Why "for (;;)" rather than "while true"? Is
there some difference?)
(Also... I just noticed how many one-letter variable names there are. So
much for that being a bad thing.)
Date: 7 Dec 2009 04:43:18
Message: <4b1cce36$1@news.povray.org>
> post-decriment?
Like I have to sit and wonder why it's (suffix,prefix) and not
(prefix,suffix) in your example?
Aren't they the same? (btw the only reason I can see that you would use the
first one is if the types being used don't have the >= operator defined).
IIRC quite a lot of functions and libraries only assume that one of those
operators is implemented, so that's probably why you'll see stuff like that.
> And similar questions. (Why "for (;;)" rather than "while true"? Is there
> some difference?)
Not that I'm aware of.
Date: 7 Dec 2009 04:50:09
Message: <4b1ccfd1@news.povray.org>
>> But now I have to sit here and wonder "is that pre-decriment or
>> post-decriment?
No specific reason. I probably did it that way around because "split"
takes the list in reverse order. (Working from the back towards the
front is inefficient for a single-linked list, so I reversed the list so
it can be processed from front to back instead.) Technically you could
return the sublists either way around if you wanted. I just did it this
way because if you take (x, y) and do x ++ y, you get the original
(backwards) list. If you'd returned the components the other way around,
you'd have to do y ++ x instead.
You'd certainly think so.
> the first one is if the types being used don't have the >= operator
> defined). IIRC quite a lot of functions and libraries only assume that
> one of those operators is implemented, so that's probably why you'll see
> stuff like that.
Hmm, I see.
Of course, we're working with *digits* here, for which both operators
are definitely defined. However, it seems this part of the code is from
a library, so presumably it's supposed to work with anything.
(In Haskell, it is impossible to define one ordering relation without
also defining the others. Well, no, not impossible, but you'd have to
purposely go out of your way to do it. So in Haskell it's not something
a library needs to worry about it. But now I recall that in C++, these
are all seperate, notionally unrelated operators.)
It's like when a Haskell programmer writes a new function that's
equivilent to an existing one. You have to sit there and wonder why they
did that. Was it personal taste, or is there actually some subtle
difference you've missed?
