POV-Ray : Newsgroups : povray.off-topic : Trivial trigonometry Server Time
4 Jul 2026 18:54:11 EDT (-0400)
  Trivial trigonometry (Message 71 to 80 of 178)
Subject: Re: Trivial trigonometry
Date: 30 Nov 2009 17:54:06
Message: <4b144d0e$1@news.povray.org>
Orchid XP v8 wrote:
>>> babble some nonesense about a "quantum superposition of states" to
>>> make up for the fact that this explanation makes no sense at all.
>> It's only nonsense if you don't know what it means.
> "And the waves interact to generate these interference patterns."
That's mistaken. There are no waves.
> "OK, so why do I still get the exact same patterns if there's only one
> photon there?"
Because there are no waves.
> "Um... right, OK... that's because there are these extra versions of the
> photon, that all exist at the same time.
That's an attempt to explain the interference patterns *assuming* photons
are waves to start with. But they're not, so it's mistaken.
http://www.youtube.com/watch?v=_7OEzyEfzgg
Note that "amplitude" is the 2-D complex probability.  It's not that two
photons get to the same place at the same time and cancel out.  It's that
the photon just doesn't go there. Hence, no need for multiple photons to
cancel.
What he's talking about at the end is things like, you know they're not
waves because you only have two electrons in the innermost shell and you get
lasers with bosons but not fermions.  I.e., you can't make an electron
laser, only a photon laser. Hence, electrons aren't waves.
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 30 Nov 2009 17:58:47
Message: <4b144e27@news.povray.org>
Sabrina Kilian <ski### [at] vtedu> wrote:
> You don't get the interference pattern with only one photon. You get it
> if you sum a lot of photons emitted one at a time. A single photon will
> still hit only one place*, but that place is more likely to be in one of
> the locations that you would expect from a wave.
  To put it more clearly:
  You don't need to send all the photons at the same time in order to get
the interference pattern. You can send photons one by one, with a significant
time interval between sending the photons, and you *still* get the exact
same interference pattern as if you had sent them all at the same time.
This means that a photon does not need other photons to interfere with in
order for the interference pattern to appear. A lonely photon traversing
through the double-slit will still present the same interference.
  I think that the vernacular interpretation is that the single photon
traverses as a wavefront and interferes with itself when it passes through
both slits at the same time.
Date: 30 Nov 2009 18:06:10
Message: <4b144fe2@news.povray.org>
  It looks like a wave, it behaves like a wave, it produces all the effects
that a wave would produce, but it's not a wave.
> > photon there?"
  You get a wave interference pattern *because* (not "even though") there's
no wave. That makes sense.
  I wonder if the same principle could be applied to all non-intuitive
phenomena: The phenomenon happens *because* of what makes it non-intuitive,
not *regardless* of what makes it non-intuitive. Of course that claim is
quite non-intuitive all in itself.
Date: 30 Nov 2009 18:47:14
Message: <4b145982$1@news.povray.org>
On Mon, 30 Nov 2009 11:45:53 +0000, Invisible wrote:
>> There is nothing like spending a couple of hours on your back in a
>> field with a truly dark sky - it feels like there are far more than
>> mere thousands visible!
>> :o
> But where do you have to go? Outer Mongolia?
You could probably see a fair bit from Stonehenge....For me, I'd probably
have to travel about 30 miles up into the mountains (have done, actually,
the night sky is quite cool to see from up on the eastern side of the
mountains to the east of where I live).
As for where Outer Mongolia is, GIYF. ;-)
Jim
Date: 30 Nov 2009 22:00:21
Message: <op.u38nyuhi7bxctx@bigfrog.bredbandsbolaget.se>
On Mon, 30 Nov 2009 23:20:44 +0100, Orchid XP v8 <voi### [at] devnull> wrote:
> It's true that in very low light conditions, vision takes on a
> "speckley" character, presumably due to some combination of small
> numbers of photons or small numbers of individual nerve impulses
> generating a fairly noisey signal. I'm not sure whether one single
> photon is enough to generate a nerve action potential though; maybe it
> takes 10 or so?
Not a bad guess.
http://math.ucr.edu/home/baez/physics/Quantum/see_a_photon.html
FE
Date: 30 Nov 2009 22:54:17
Message: <4b149369$1@news.povray.org>
Well, not really. The basic problem is people calling it an "interference
pattern" to start with. It's not really "interference" as such, since
there's only one particle. Calling it "interference" just encourages people
to go looking for what wave is causing the interference.
Date: 30 Nov 2009 22:56:26
Message: <4b1493ea$1@news.povray.org>
No, it doesn't. It has the same math as a wave, *if* there's only one. If
there's more than one, the behavior isn't like waves.
What function of waves produces lasing? Polarization?
>>> photon there?"
No, you get the exact same patterns when there's only one photon there,
because it's not caused by interference between photons.
Date: 30 Nov 2009 23:04:17
Message: <4b1495c1$1@news.povray.org>
Actually, if you really want to push it, you could say the pattern is caused
by interference between the two slits, not between multiple photons. That's
why it changes based on whether you measure what goes thru the slits or not.
Date: 1 Dec 2009 10:59:56
Message: <4b153d7c@news.povray.org>
  I see a pattern here (pun semi-intended). Shooting individual photons one
at a time results in a pattern which is identical to the interference pattern
which results from shooting huge bunches of photons at the same time, a
pattern which is what one expects from a wave. But since a photon is not a
wave, it's not an interference pattern. It's just a pattern which happens
to look exactly like an interference pattern, but without being one.
  And if I follow your earlier logic, the pattern looks like an interference
pattern *because* it's not an interference pattern.
Date: 1 Dec 2009 11:06:27
Message: <4b153f03@news.povray.org>
  Your logic seems to be that since photons do *more* than waves do, in
other words, photons seems to be a superset of pure waves, then they are
not waves at all.
  Why not apply the same logic in reverse? Since photons seem to do more
than pure particles would be expected to do, then they are not particles
either.
  It feels a bit like saying that a seaplane is not a plane because normal
planes can't land on water but a seaplane can.
> >>> photon there?"
  I find it rather amusing that QM doesn't seem to have any problem in
accepting phenomena which feel completely supernatural and counterintuitive,
such as the state of one particle instantly determining the state of another
particle which is light-years away, when the state of the particle is
"observed" (whatever that might mean), but the idea of a photon passing
through two slits at the same time and interfering with itself seems too
hard to swallow.
  (I'm not saying that's what's happening. I'm saying that the way you write
makes it sound like that.)
