POV-Ray : Newsgroups : povray.off-topic : Bar codes Server Time
18 Oct 2026 00:12:26 EDT (-0400)
  Bar codes (Message 4 to 53 of 53)
<<< Previous 3 Messages Goto Initial 50 Messages
Subject: Re: Bar codes
Date: 13 Oct 2009 21:20:03
Message: <4ad52743@news.povray.org>
Invisible schrieb:
> The impressive thing is, as far as I can tell, almost all barcode
> scanners support almost all kinds of barcodes. Even though each coding
> scheme is utterly unrelated to any of the others. God only knows how
> this is physically possible...
Not much magic in there.
Barcodes are designed to have a lot of redundancy, so that reading
errors can be detected.
So a barcode scanner just checks whether the code it just read makes
sense (i.e. check digits match etc.) when interpreted as any of the
codes it supports.
Conflicts seldom occur /because/ the barcodes are so dissimilar. Still,
it is a good idea to configure the scanner to recognize only barcodes
you actually expect to use, especially if you expect to work with
barcodes that may be smudged or otherwise messed up.
Date: 13 Oct 2009 21:43:35
Message: <4ad52cc7$1@news.povray.org>
Gyscos schrieb:
> Isn't there some bars at the beginning or the end that indicate the encoding ?
No, not really. Though many barcodes include some "frame" to (a)
identify the side at which the barcode starts, and/or (b) calibrate for
the size of the barcode; such frames can often double-act to prevent
misinterpreting other barcode types.
For instance, Code39 IIRC always starts and ends with the bars it uses
for the Asterisk (*).
EAN-13, on the other hand, uses one pair of simple bars at the
beginning, end, and in the middle, respectively, to calibrate for size,
while the reading direction can unambiguously be inferred from any
"character" of the barcode "payload".
But these "frames" are only standardized for each individual barcode
type, and there is no universal scheme to identify the type. All you can
do is test for which types of barcode this particular specimen reads
without error.
Date: 14 Oct 2009 03:33:11
Message: <4ad57eb7@news.povray.org>
> It's great fun. EAN-13 is apparently an "extension" of UPC-A,
Those are used in supermarkets mainly, which is why you find them on all
products sold to the public.
For non-public uses (eg on shipping cartons, internal parts of products etc)
the company is obviously free to make up or use their own standard for the
bar code.  You didn't find any 2D barcodes?
Date: 14 Oct 2009 04:22:58
Message: <4ad58a62$1@news.povray.org>
Yeah, apparently UPC-A is for America, EAN-13 is supposedly for
everywhere, but almost all scanners support both. They can only encode
numbers though - usually standardised product codes.
> etc) the company is obviously free to make up or use their own standard
> for the bar code.
Yeah, the shipping box I've got has several extremely wide barcodes.
These codes encode letters as well, but I can't determine exactly which
system they are. (Assuming they're even a standard one...)
None.
However... The Royal Mail allow you to print your own stamps, for a fee.
You give them money, they give you a PDF file containing a 2D barcode
[which presumably encodes the date of purchase, since it apparently
expires after so many days].
Now I'm thinking... it appears to be a standard Data Matrix barcode, so
if I could figure out WTF the data encoded in it is, I could print as
many of them as I like, without a fee...
Date: 14 Oct 2009 04:33:22
Message: <4ad58cd2$1@news.povray.org>
Interesting fact: I actually have a barcode scanner here. Specifically,
our tape robot has a barcode scanner. We've never used it, but
apparently our Director of IT has suddenly decided that we're going to.
In a few days' time I should have a stack of preprinted barcode labels.
I wonder what kinds the scanner can read?
Date: 14 Oct 2009 04:47:48
Message: <4ad59034@news.povray.org>
> Now I'm thinking... it appears to be a standard Data Matrix barcode, so if
> I could figure out WTF the data encoded in it is, I could print as many of
Won't they encode a serial number in there? As soon as they detect a 2nd
stamp in the system with the same serial number (or with one they know they
haven't sold yet) there will be trouble.
Also it probably has some checksum, you'd need a shed load of stamps to
figure it out probably.
And hope they don't encode your IP address or payment details in there too.
A bit like that system on Blu-Ray discs, where every player plays back a
very slightly different version, so when someone rips and uploads to
BitTorrent, they can tell exactly which player it was ripped from.
Date: 14 Oct 2009 08:47:07
Message: <4ad5c84b$1@news.povray.org>
>> so if I could figure out WTF the data encoded in it is, I could print
>> as many of them as I like, without a fee...
> they haven't sold yet) there will be trouble.
Yeah, this is probably the main problem. If they know which numbers
they've actually sold and which ones have actually been used, there's
not much you can do.
Well, if you were going to reverse-engineer it, sure. But if you could
figure out the algorithm...
It's like Windows license keys. Each one is a 20-character alphanumeric
string. There must be some algorithm that Windows uses to decide whether
the key you just entered is valid. If you somehow knew what that
algorithm is.......
If you *knew* how they generate the barcode, you could put an arbitrary
IP address in there. (Besides, knowing somebody's IP address doesn't
really tell you a whole heap.) Payment details might be more fun...
Really? That's news...
Date: 14 Oct 2009 09:01:09
Message: <4ad5cb95$1@news.povray.org>
How are you going to figure out the algorithm without access to lots of
stamps you know are valid?
> If you *knew* how they generate the barcode, you could put an arbitrary IP
> address in there.
Isn't the problem here that you're trying to work out how to generate the
barcode?
http://www.freedom-to-tinker.com/tags/aacs?page=1
Date: 14 Oct 2009 10:26:00
Message: <4ad5df78$1@news.povray.org>
>>> to figure it out probably.
I suppose the fatal assumption here is that the encoding of the
information into the barcode is trivial. If these guys are sensible, it
won't be...
>>> back a very slightly different version, so when someone rips and
>>> uploads to BitTorrent, they can tell exactly which player it was
>>> ripped from.
Interesting. So the film actually ends a different way depending on
which player you play it with?
I bet that'll be popular...
[But then again, all these copywrite notices and "piracy is stealing"
ads and aggressive copy-protection systems only piss off paying
customers. They have no effect on criminals...]
Date: 14 Oct 2009 11:17:25
Message: <4ad5eb85@news.povray.org>
> Interesting. So the film actually ends a different way depending on which
LOL, I suspect they can do it slightly more subtly than that!  They only
need to make some tiny changes to some of the pixels to be detectable.  In
theory they could do what you suggest though, would be fun :-)
Date: 14 Oct 2009 11:33:38
Message: <4ad5ef52@news.povray.org>
> In theory they could do what you suggest though, would be fun :-)
Well, the article states that it's supposed to resist somebody pointing
a video camera at their TV screen, so a 1-pixel alteration won't do.
What I suppose they might do is have maybe a 1-frame difference in how
long a given scene is. Like, on some disks the shot of the ocean is 1362
frames long, and on others it lasts for 1366 frames. The difference
should be reliably detectable no matter how you film it.
Still, it seems like a hell of a lot of work considering that it doesn't
actually stop illegal copying, it just makes it hypothetically possible
to find out who did the illegal copying...
Date: 14 Oct 2009 12:35:40
Message: <4ad5fddc$1@news.povray.org>
With the understnading that a "player" in this context means "model number"
at least in the hardware players. I.e., they can tell it got ripped by a
Sony XYZ-1230 brand blu-ray player, not Joe's blu-ray player.
The idea is to identify it enough to black list the leaked keys, not to
catch the person who distributed the movie.
Date: 14 Oct 2009 12:36:48
Message: <4ad5fe20$1@news.povray.org>
Probably different watermarks encoded, without actually looking visibly
different in a way you could tell. Otherwise, someone might just rip it
twice and change the file to use (say) 1364 frames of ocian.
Date: 14 Oct 2009 14:16:17
Message: <4ad61571$1@news.povray.org>
>> pointing a video camera at their TV screen, so a 1-pixel alteration
>> won't do.
Well, to lots of people digital watermarking is the Holy Grail of
digital technology, the thing that will finally stop the pirates.
Trouble is... it's extremely hard.
If the watermark is encoded in a way that's perceptually
insignificant... well guess what lossy codecs are specifically designed
to do? Yes, that's right: *remove* perceptually insignificant information!
I'm thinking things like small timing differences would be too subtle to
notice, but significant enough for encoding to not screw them up. And
you could try to correct it yourself, but you'd have to know exactly
which bits of timing are varied in order to know what to change...
http://blog.orphi.me.uk/
Date: 14 Oct 2009 14:17:40
Message: <4ad615c4$1@news.povray.org>
> number" at least in the hardware players. I.e., they can tell it got
> ripped by a Sony XYZ-1230 brand blu-ray player, not Joe's blu-ray player.
The article suggests that the system *is* supposed to be able to narrow
it down to a specific machine or possibly a small number of such
machines, not just a specific model.
Of course, it depends on whether the makers bother to fit each player
with semi-unique keys or not... One commenter pointed out that hardware
manufacturers have no vested interest in making DRM work. Only studios do.
Date: 14 Oct 2009 14:49:51
Message: <4ad61d4f@news.povray.org>
Certainly.
Well, you can spread it across lots of media, a few bits at a time. Xerox
had a mechanism where you could vary the spacing between words in a
document, and encode maybe a couple dozen bits per page of a document, for
example.
But yes, it's difficult. Anything else is open to fairly simple subversion,
tho.
Could be, until you convert PAL to NTSC. :-) What you'd want is to have
something where it's difficult without the key to even know where the data
is encoded.
But you have the different pieces all on the disk. All you need is the keys
from two different players and you can tell what's different.
Date: 14 Oct 2009 14:51:13
Message: <4ad61da1$1@news.povray.org>
No, that's what I'm saying.  "Player" in *this* context means a set of keys
(obviously). Software players can each get a set of keys from the
manufacturer when you install the machine. But people don't, in general,
program a unique key into each hardware player.
Date: 14 Oct 2009 17:33:09
Message: <4ad64395$1@news.povray.org>
Until you got caught, that is, and fined/put in jail for fraud.... ;-)
Jim
Date: 14 Oct 2009 17:34:04
Message: <4ad643cc$1@news.povray.org>
Probably a form of steganography, at a guess.
Jim
Date: 14 Oct 2009 22:09:13
Message: <4ad68449$1@news.povray.org>
Darren New schrieb:
>> narrow it down to a specific machine or possibly a small number of
>> such machines, not just a specific model.
> keys (obviously).
What's obvious about that?
Hardware players are likely to have a Flash ROM or EEPROM anyway, so
it's no technical problem to equip each individual player with a unique key.
And as for motivating manufacturers to do that, it might be a
requirement of the license agreement they had to sign to implement
BlueRay technology in the first place.
Software players, OTOH, typically seem to share a common Device Key for
all installations of a particular player version.
At least that's what I read between the lines of the article.
Date: 14 Oct 2009 23:36:55
Message: <4ad698d7$1@news.povray.org>
>> keys (obviously).
Because I've read more than just one article on the subject?  The point is
to track down the key used to decrypt the content so the key can be added to
the blacklists on future players.
> key.
The hardware players are required to have FLASH in them, because they need
to update to new versions of blacklists. They're not (last I read) required
to actually have a separate key per player.
It might. But it isn't.
Typically they often do, but contractually they may be forced to provide a
separate key for each player if the blu-ray licensing folks feel it's
appropriate given the structure of the decoder in the software.
Read up more on how it all works. It's really quite impressively complex.
Date: 15 Oct 2009 00:48:57
Message: <4ad6a9b9@news.povray.org>
>>> of keys (obviously).
Does that make it /obvious/ in this context? It may make it obvious to
/you/, but that's a different story.
 > The point
> is to track down the key used to decrypt the content so the key can be
> added to the blacklists on future players.
No. The point is to track down the key (as you say) to add it to the
blacklist on future /discs/.
>> unique key.
> need to update to new versions of blacklists. They're not (last I read)
> required to actually have a separate key per player.
What on earth should the players blacklist?
Unless the security stuff also contains an /additional/ mechanism to
somehow identify pirated copies of movies. But that's not what the
article is talking about.
Date: 15 Oct 2009 01:01:51
Message: <4ad6acbf$1@news.povray.org>
> keys (obviously). Software players can each get a set of keys from the
Not that Wikipedia would be free from error, but they explicitly state
that having a different key for each /individual/ player is the major
difference in key management between CSS (as used on DVD, having one key
per player model) and AACS (having one key per individual player) - the
idea apparently being that keys /can/ be revoked without hurting many
honest consumers.
Date: 15 Oct 2009 02:46:37
Message: <4ad6c54d$1@news.povray.org>
> frames long, and on others it lasts for 1366 frames. The difference should
I think there are lots of possibilities for things they could do.  When a
disc is released that actually uses this feature, I'm sure lots of people
will be jumping up and down trying to find the differences.
> actually stop illegal copying, it just makes it hypothetically possible to
You know what they're like, they like to try and scare everyone with their
copy protection schemes, plus they need somone to sue for $76578236597826457
when they find a copy on bitTorrent.
Date: 15 Oct 2009 04:15:58
Message: <4ad6da3e$1@news.povray.org>
Well, if they're hiding player ID information in the video, then that
would, by definition, be "steganography". That's what steganography
*is*, after all...
The question is which steganographic technique they'll use. ;-)
Date: 15 Oct 2009 04:17:02
Message: <4ad6da7e$1@news.povray.org>
Would they actually bother for 21p?
Now, if I wrote an automated program to print these stamps and posted it
on the Internet... *then* they might have a case. :-P
Date: 15 Oct 2009 08:03:06
Message: <4ad70f7a$1@news.povray.org>
It's actually very simple.  As long as the scanner is close enough, and
is at the proper angle, all stripes of a given width will appear the
same to the scanner.  Each bar coding system uses a series of different
widths to represent each character.  Some systems use only narrow and
wide stripes (double width), while others will have stripes that are
three and four times the size of the narrowest stripe.  Generally each
character is comprised of a set of stripes that add up to a constant
width (or else the bar codes would appear to have different widths).
As you can see, once the series of widths is in the scanner,
interpretation becomes a software issues.  If the data doesn't make
sense under one coding scheme, the scanner can always run the same set
of width data through another scheme.
John
Date: 15 Oct 2009 09:34:21
Message: <4ad724dd$1@news.povray.org>
What would likely happen is the system would detect the stamp was
already used, and kick it back to the sender with "Insufficient Postage"
emblazoned across the stamp.
~Mike
Date: 15 Oct 2009 09:41:45
Message: <4ad72699@news.povray.org>
> What would likely happen is the system would detect the stamp was already
I wonder if they even bother to check them against a database of already
used/issued ones?  Maybe they just check the checksum?
There was a story a few years ago where a self-checkout machine in Tesco
didn't do this for some voucher, and a guy just photocopied it hundreds of
times and it worked :-)  Oh here I found it:
http://www.timesonline.co.uk/tol/news/uk/crime/article1572721.ece
Date: 15 Oct 2009 10:49:55
Message: <4ad73693$1@news.povray.org>
>> Postage" emblazoned across the stamp.
The German "Post" has a similar system, and they /do/ check it against a
database.
BTW, the German 2D "stamp" barcode even encodes the full destination
address information, which has the benefit (for the "Post") of (a)
rendering the stamp fundamentally un-reusable anyway except for mails to
the same addressee, and (b) making the address even easier machine-readable.
Date: 15 Oct 2009 10:57:28
Message: <4ad73858$1@news.povray.org>
> database.
I always wondered, if you posted a letter without a stamp in Germany and
swapped the To/From addresses, would it get delivered to your intended
recipient for free?
Date: 15 Oct 2009 11:10:46
Message: <4ad73b76@news.povray.org>
It's obvious if you read the article in that context what they mean. I guess
if you didn't know that, it's possible it was less obvious.
>  > The point
Yes. I misspoke. But the blacklist from those disks also goes into the
players. (The blacklists being subtrees of the key tree.)
The players actually wind up blacklisting particular keys, IIRC. It's a
highly complex system, and now that you mention it, I'm not sure I still
remember all those details.
They do, but I don't think that has to do with the key stuff we're talking
about, since they just *always* refuse to play pirated movies regardless.
Date: 15 Oct 2009 11:11:36
Message: <4ad73ba8$1@news.povray.org>
It's possible what I've read was wrong too, yes. I've never licensed the stuff.
Date: 15 Oct 2009 11:15:46
Message: <4ad73ca2@news.povray.org>
>> a database.
> recipient for free?
I guess that might depend on how far away the recipient is living. All
letters are nowadays processed in one of dunno-how-many mail centers,
and I reckon the first such center to handle any letter will check it
for sufficient postage; if they find that the alleged sender address is
not anywhere close to where the letter was posted (and I guess they can
narrow that down comparatively well), but the alleged recipient is
living surprisingly close nearby, someone might get suspicious.
So if you intend to send a letter to a friend living a few blocks away,
and you're just too lazy to walk to their home and hand over the letter
in person, this scheme might indeed work.
Date: 15 Oct 2009 11:31:14
Message: <4ad74042$1@news.povray.org>
>>> only need to make some tiny changes to some of the pixels to be
>>> detectable. In theory they could do what you suggest though, would be
>>> fun :-)
> *is*, after all...
One that's difficult to guess, I'd guess. :-)
Jim
Date: 15 Oct 2009 11:32:43
Message: <4ad7409b$1@news.povray.org>
They'd probably fine you if they noticed it.
That would certainly raise your visibility, yes.  But breaking the law is
breaking the law, and when one does it one has to be prepared for the
consequences.  Thinking "yes, it's illegal but they won't care/will never
catch me" - well, the prisons here (and there) are filled with people who
thought that way.
Jim
Date: 15 Oct 2009 11:35:01
Message: <4ad74125$1@news.povray.org>
> thought that way.
Theoretically, if I pick up one of the pens at work and take it home
with me, that's theft.
Is my employer going to care?
I doubt it...
(And a pen costs significantly more than a stamp.)
Date: 15 Oct 2009 11:38:53
Message: <4ad7420d$1@news.povray.org>
>>> it on the Internet... *then* they might have a case. :-P
>> is breaking the law, and when one does it one has to be prepared for
>> the consequences.  Thinking "yes, it's illegal but they won't care/will
>> never catch me" - well, the prisons here (and there) are filled with
>> people who thought that way.
> I doubt it...
I have worked for employers who did care about pens going home with
employees.
It's a risk analysis, but as I said, the prisons are full of people who
thought they could "get away with it" and were wrong.
Jim
Date: 15 Oct 2009 21:20:01
Message: <web.4ad7c9e5e03ab62834d207310@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Bar codes. They're little bunches of black lines which can be read by a
> scanner. Right?
> Hahaha, well... it turns out there are actually a miriad of different
> kinds. And they're ALL COMPLETELY DIFFERENT to each other.
My Android phone has an app that does a bar code scanner that can eventually
look up the product it scans online to see who sells it for what.  I've found
prices for things when looking up some very boring, unimportant things when I
tested it around the house. It has however failed me twice in computer stores
when I was hurriedly trying to find out if the price were right.  I quickly
scanned one of the five or six bar codes on the box and it never worked.  Maybe
some of these were about the UPS shipping or inventory. I never found the store
product UPC.
Date: 15 Oct 2009 23:15:30
Message: <4ad7e552$1@news.povray.org>
> product UPC.
It seems to me they don't bother about UPC-A (or EAN-13) codes except
for products typically sold at supermarkets and other high-volume
low-margin retailers.
I can imagine that it doesn't pay off for e.g. manufacturers in the
computing industry to apply for a company code, as the customers have a
strong say in what products a shop will carry (at least for the products
the store will make the real money with), so the retailers have
difficulties trying to threaten the manufacturers with boycotting their
products. And most retailers will not really bother too much either, as
the handling expenses are low compared to the margin.
Supermarkets, on the other hand, are strongly motivated to keep handling
costs to a minimum, and it won't hurt them much if they refused to carry
a certain brand of toothpaste.
Date: 19 Oct 2009 11:51:33
Message: <4adc8b05$1@news.povray.org>
http://blog.wolframalpha.com/2009/10/09/what-does-that-barcode-say/
FAIL.
Altough... now I can *print* barcodes. (Just not *read* them.)
Subject: Bar code mystery
Date: 23 Oct 2009 08:58:47
Message: <4ae1a887$1@news.povray.org>
OK, so I now have several sheets of barcode labels.
What I can't figure out is which symbiology they use. Consider, for
example, the label for "UKM11001L3". If 1=black and 0=white, we have
[...000]101101101001010101001101101100101011010110101001011010
11011001010101101100101011010100101101101010010110100101011
011011001010101101101010100110101101101001[000...]
This doesn't seem to match anything Wolfram Alpha can come up with:
http://www.wolframalpha.com/input/?i=barcode+UKM11001L3
None of these barcodes start with the distinctive two thin bars framing
two thick bars ("...01011011010..."). I have no idea what barcode type
this is...
Subject: Re: Bar code mystery
Date: 23 Oct 2009 10:11:04
Message: <4ae1b978@news.povray.org>
> this is...
Why not upload a scan of the barcode?
Mike
Date: 23 Oct 2009 10:19:19
Message: <4ae1bb67$1@news.povray.org>
I'd need a scanner to do that.
Date: 23 Oct 2009 10:46:43
Message: <4ae1c1d2@news.povray.org>
A camera will do too.
Date: 23 Oct 2009 11:07:52
Message: <4ae1c6c8$1@news.povray.org>
> this is...
Now if you think that those three barcodes on the Wolfram page are all
the world has to offer...
http://www.herdsoft.com/ti/davinci4/examples/barcodecgi.cgi is convinced
that it is a "Code 39" (aka "Code 3 of 9") barcode, and indeed correctly
reads it as "UKM11001L3".
Closer analysis of your barcode pattern shows that your barcode indeed
appears to be Code 39, but flipped horizontally for some reason (which
of course should not matter to a barcode reader).
BTW, Wolfram is doing a poor job at generating Code 39 barcodes, as it
uses different bar widths for the "frame" than for the "payload".
(The Code 39 frame is usually interpreted as a leading and trailing
asterisk (*) character, as it uses the same bar sequence.)
Date: 23 Oct 2009 11:38:21
Message: <4ae1cded$1@news.povray.org>
>> framing two thick bars ("...01011011010..."). I have no idea what
>> barcode type this is...
There don't appear to be many bacode types that handle text. Many handle
only numbers.
Really? (I can't even tell what language that page is in.)
My word... That *does* in fact appear to match. I hadn't noticed that!
I especially love the way the bar widths don't appear to be multiples of
each other. I almost wonder if the image has been scaled down by
rounding each bar to a whole number of pixels, so some "thin" bars are 3
pixels and some are 4... It's very districting!
Indeed, clicking on "PDF" and enlarging the image seems to make the
problem go away... How annoying!
Date: 23 Oct 2009 13:05:39
Message: <4ae1e263@news.povray.org>
>> convinced that it is a "Code 39" (aka "Code 3 of 9") barcode, and
>> indeed correctly reads it as "UKM11001L3".
That's German of course :-)
It is less surprising once you know that Code39 doesn't have fixed bar
width ratios - just "narrow" and "wide" black and white bars (with each
character having 3 "wide" and 6 "narrow" bars, and characters separated
by another white bar; don't know if that is mandatorily narrow, though
it seems common).
Why not get one of those many Code39 TrueType fonts out there?
... or write a POV-Ray SDL script to generate barcode images :-)
Date: 23 Oct 2009 14:10:46
Message: <4ae1f1a6$1@news.povray.org>
>> of each other. I almost wonder if the image has been scaled down by
>> 3 pixels and some are 4... It's very districting!
> width ratios - just "narrow" and "wide" black and white bars.
It's still confusing to have several apparently different bar widths
which are actually supposed to be "the same". The reader might accept
it, but for a visual example, it's sucky.
Why use SDL when you can use PostScript, the language of the laser
printers? ;-)
I have in fact just written a working code-128 reader/writer today. It
only deals with bit-sequences, but I guess the next step is to handle
actual pictures...
Date: 29 Oct 2009 11:16:15
Message: <4ae9b1bf$1@news.povray.org>
Interestingly, though, they all seem to have quite characteristic
start/end markers. It appears to be possible to uniquely discriminate
them by this alone.
(For example, UPC-A and EAN-13 both start and end with ...01010...)
> I just did a cursory scan of my office.
I see what I did there. ;-)
> Here's what I found:
>   SIIG USB-serial box: UPC-A barcode plus one of unknown type.
This appears to be Code-39. (Begins 10010... and ends ...0101101101.)
I'm guessing it encodes the serial number also printed above the barcode.
>   Maxtor drive: 5 barcodes of unknown type.
These all appear to be Code-128. (Begins 11010... and ends ...11101011.)
>   Integral RAM box: One barcode (from Insight UK) of unknown type.
This seems to be Code-39 again. (I'm guessing it encodes the large part
number printed above, not the smaller description text.)
>   TNT shipping box: Two barcodes of unknown type.
I no longer have the box.
>   HP laptop adaptor: 3 barcodes of unknown type.
Two of these appear to be Code-39. The final one might be Code-93. Maybe.
> It's great fun. EAN-13 is apparently an "extension" of UPC-A, and yet
> it's COMPLETELY DIFFERENT. The encoding is entirely unrelated.
 From what I can tell, the two utterly different algorithms are supposed
to produce the same output in the case of an EAN-13 where the extra
digit happens to be zero. I haven't varified how this is possible yet.
Again, it appears the start and stop markers are actually pretty unique
to each barcode type. It seems to be possible to distinguish them by
that alone, without the aid of a computer...
