POV-Ray : Newsgroups : povray.off-topic : A fatal mistake Server Time
15 May 2026 13:32:05 EDT (-0400)
  A fatal mistake (Message 26 to 35 of 45)
Subject: Re: A fatal mistake
Date: 5 Oct 2009 04:59:53
Message: <4ac9b589$1@news.povray.org>
>> Sketckup is a lot of fun,
> Can it export stuff POV-Ray can use?
It can export data as some kind of XML format. (Apparently it's an open
standard - I don't know how well documented!) If you wrote a converter,
then... supposably.
Date: 5 Oct 2009 05:01:02
Message: <4ac9b5ce$1@news.povray.org>
>> welcome to 3D visual modelling! :D
> *That* is what I want Minority Report gloves for! :-)
Ah, Minority Report. How often does a film come along that makes
everybody want a particular fictional technology?
Date: 5 Oct 2009 05:29:19
Message: <4ac9bc6f$1@news.povray.org>
>> ...you need to get a proper 3D CAD program? :-)
> Yeah, figures.
Most CAD programs I've used store a tree of features/actions used to get to
the final shape, this means you can go back and edit any of those previous
steps.  In your example the shape you drew to make the hole is stored
exactly as that in the file, then of course you can edit it and see the
result.  I saw partly this kind of behaviour in 3D Studio Max (or whatever
it's called now), in that you could keep two separate objects and see the
intersection of them, but most mesh editors just store the mesh and no extra
data.
Date: 5 Oct 2009 05:38:11
Message: <4ac9be83$1@news.povray.org>
> to the final shape, this means you can go back and edit any of those
> previous steps.
That sounds like a more logical way to work.
Presumably CAD also allows you to do things like "find a point 3/5 along
the length of this edge". SketchUp automatically marks the 1/2 point for
you, but for any other point you've got to get out a calculator.
Other annoying SketchUp features include the lack of the ability to
manipulate a circle be its center. (Because, of course, once you've
created it, it's not a circle any more. It's 24 unrelated edges.) And
the best feature of all is the way surfaces "stick" to each other as
soon as they touch...
> (or whatever it's called now), in that you could keep two separate
> objects and see the intersection of them, but most mesh editors just
> store the mesh and no extra data.
Yeah. How SketchUp does intersection is that you line up the two
objects, press "intersect", and then delete the geometry you don't want.
Manually. Which, for curved surfaces, takes a really long time.
(Because, naturally, those surfaces aren't really curved. Stupid
idea...) Also, you can't delete any item smaller than a certain size on
screen. You have to zoom in first. And the minimum size is significantly
larger than you'd expect.
Date: 5 Oct 2009 06:38:28
Message: <4ac9cca4@news.povray.org>
AFAIK there is not usually any automatic way to do that, you'd just need to
add a formula to one of the point dimensions that says something like
"Edge1.Length * 3/5".  That way, whenever the length of that edge changes,
the point is always fixed 3/5 of the way along.  You could then draw some
geometry referenced to that point, then of course that would all move with
the point too.  It gets a bit like POV, where you can just define a variable
for something like "screw position", and then drive lots of other features
like holes and cut-outs in lots of parts from that one variable.  The
benefit of this is when your customer says "ok we need that screw moved
1.2mm" it only takes you a few seconds to update all your parts rather than
an hour or two.
> the best feature of all is the way surfaces "stick" to each other as soon
> as they touch...
> Also, you can't delete any item smaller than a certain size on screen. You
> have to zoom in first. And the minimum size is significantly larger than
> you'd expect.
I would expect there would be settings for these sorts of things?
Date: 5 Oct 2009 06:54:32
Message: <4ac9d068$1@news.povray.org>
>> along the length of this edge".
> to add a formula to one of the point dimensions that says something like
> changes, the point is always fixed 3/5 of the way along.
Right.
> You could then
> draw some geometry referenced to that point, then of course that would
> all move with the point too.  It gets a bit like POV, where you can just
> define a variable for something like "screw position", and then drive
> lots of other features like holes and cut-outs in lots of parts from
> that one variable.  The benefit of this is when your customer says "ok
> we need that screw moved 1.2mm" it only takes you a few seconds to
> update all your parts rather than an hour or two.
SketchUp allows you to draw precise sizes easily, and it allows you to
line things up easily. What it does not do is allow you to "link" things
so that when something changes, other things change to match. You'd have
to propogate any necessarily changes manually yourself. SketchUp makes
it quite easy to adjust everything by exactly the right amount, but you
still have to know what to adjust and how to adjust it.
The delete size, maybe. (I haven't found the setting anywhere though.
There are surprisingly few settings you can adjust.) The sticking
appears to be a design feature - annoying as it is. (You can prevent it
by using layers or grouping surfaces into seperate entities.)
Date: 5 Oct 2009 06:57:40
Message: <4ac9d124$1@news.povray.org>
>> Now, sure, if your window is rectangular, the push/pull tool makes it
>> easy enough to continue. But what if you made a *circular* window? Or
>> some even more complex shape?...
On the other hand, weren't you the guy complaining that "propper 3D CAD
programs" are too crash-happy? At least SketchUp is reliable. ;-)
Date: 5 Oct 2009 07:19:42
Message: <4ac9d64e$1@news.povray.org>
Not me, I can't remember the last time Catia crashed on me.  Don't ask me
about the thermal simulation software I use though...
Date: 5 Oct 2009 08:00:17
Message: <4ac9dfd1$1@news.povray.org>
Blender too.  I usually move the original forms to another hidden layer.
> idea...)
What makes you think really curved surfaces would be faster?
BTW, if you want curved surfaces, subdivision surfaces is the way to go
(no idea if Sketchup handles them).  That way, you may keep and handle
operations on very simple "cage" mesh while having a very "curved" final
surface... I'm guessing intersecting between 2 "low-poly" cage meshes is
way faster than between 2 high-poly ones.  You intersect 2 low-poly
cages and give the resulting mesh a subdivision "modifier"...
Date: 5 Oct 2009 08:05:00
Message: <4ac9e0ec@news.povray.org>
Well, it does mean that you have one "intersect" operator rather than a
seperate union, intersection and difference. But for complicated meshes,
it takes forever...
>> (Because, naturally, those surfaces aren't really curved. Stupid idea...)
Treating a curve as one edge, rather than 25,000 edges, makes it far
faster for a human to work on. (I make no claims about how easy or hard
it is for the computer to work with.)
Nope. SketchUp handles only straight lines. The whole program is
optimised for working with geometry with lots of lines in it. If you
want fluid, organic shapes, SketchUp is a very bad choice.
