![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Jim Henderson <nos### [at] nospam com> wrote:
> Not a bad idea; I have it sitting in front of my monitor right now, and
> have used it on my lap even (which was actually quite comfortable) - so
> maybe something where I could store it under the desk surface would do
> the trick.
A friend of mine has had bad experiences about using a tablet directly
on his lap. Namely, his tablet got broken, and the reason might be that he
used it so often on his lap that the bending forces might have broken it.
Some tablets might not have been designed to be used that way, but instead
on a flat surface.
Maybe use some plywood or whatever on your lap and use the tablet on top
of it, to be safe.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> the trick.
> he used it so often on his lap that the bending forces might have broken
> it. Some tablets might not have been designed to be used that way, but
> instead on a flat surface.
> top
> of it, to be safe.
Good thought, I probably wouldn't have thought of that. I don't apply
that much pressure to it, but it may not take a lot, and I'd hate to
break something I paid $300 for....
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 20 Sep 2009 06:15:14 -0400, Jim Henderson <nos### [at] nospam com> wrote:
>> Bummer :(
>Yeah. Having done a little research online, looks like the part is about
>$75 and should take less than an hour to replace, complete with
>rekeying. But if the dealership doesn't have the part, I may not be able
>to drive to the office on Weds (and I need to do that).
That's one of the advantage of living in a big city :D
>> I see the problem but can't advise as that is not the sort of thing I'm
>> good at. I am good at saying "you should have listened to me." :-)
>Historically I've been quite good at that as well, but I'm trying to
>translate that skill to a more proactive (and hopefully thus *useful*)
>place. The good news is that after one round of e-mails with two of our
>top execs, I still have a job. I must've done something right. ;-)
>Ouch. Security clearances are almost always a problem, aren't they?
No, this is only the second job that I've had to have clearance. Normally I get
the authority I need just by asking. If my security clearance isn't high enough
to be given the knowledge to understand the processes then they should either be
raised or the company should get someone who has the clearance. It is not as if
I would ever work in the Middle East, anyway.
>> Anyway night, night :)
>Eventually, 4 AM here now.
Tomorrow's Sunday, no work. :)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 20 Sep 2009 06:16:10 -0400, Jim Henderson <nos### [at] nospam com> wrote:
>On Sun, 20 Sep 2009 05:42:10 -0400, SharkD wrote:
>> Jim Henderson wrote:
>>> The next problem I have to solve is finding a good clear space on my
>>> desk for it.
>> Better yet, attach it to a hinged arm that you can swing wherever you
>> want it to (and out of the way of the keyboard when needed).
>the trick.
I keep my big tablet under my keyboard.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> Bummer :(
>>about $75 and should take less than an hour to replace, complete with
>>able to drive to the office on Weds (and I need to do that).
Indeed. I might go down to the auto parts store today and see if they
have what I need and can walk me through the installation.
>>> I'm good at. I am good at saying "you should have listened to me." :-)
> If no one speaks out
Exactly what I thought.
> Normally I get the authority I need just by asking. If my security
> clearance isn't high enough to be given the knowledge to understand the
> processes then they should either be raised or the company should get
> someone who has the clearance. It is not as if I would ever work in the
Well, yeah, same thing here as well (I had to have a background security
check before being employed by Novell since we deal with export-
controlled software), but I meant that getting them when needed tends to
be a problem. And of course getting turned down can be a severe career
limiting move, since that shows up in the next background check....
Heh, I wish. I seem to be saying that a lot today. Gathering statistics
and my thoughts for a discussion this coming week. Finally starting to
get tired, almost 6 AM now...
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>> desk for it.
>>the trick.
That would make it difficult to use. ;-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sounds like a plan :D
>> If no one speaks out ? :)
Right!
We don't want to get two only semi related things mixed up. Personally I can't
see any reason why I shouldn't get clearance, it's not very high. But it is
talking the SAP security guys into understanding the situation in a way that
doesn't put their backs up. The very tight timeline and fixed price budget is a
concern.
One o'clock here. -_-
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mostly I only use a very small area for navigating with the pen instead of a
mouse (about 2" X 3"). If I want to use it properly then I move it out.
Just a thought.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the trick.
> Jim
Another option is one of those little laptop stands, like these:
http://images.google.com/images?hl=en&source=hp&q=laptop+table&gbv=2&aq=f&oq=&aqi=g2
-Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Nope. Gotta have it towed to the dealer, probably to replace the
> ignition switch cylinder. The car is 10 years old, and things wear out.
I've never heard of this, unless you've broken off the key in the switch,
and my dad was an auto mechanic for 30+ years...
In the "is it turned on, is it plugged in" category, do you have a locking
steering wheel? If so, try turning the wheel a bit. Is the car securely in
parking gear? Almost always when I get stuck, it's one of those two things.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
