POV-Ray : Newsgroups : povray.off-topic : This is great Server Time
9 Apr 2026 14:51:02 EDT (-0400)
  This is great (Message 61 to 70 of 94)
Subject: Re: This is great
Date: 24 Aug 2009 09:14:33
Message: <4a929239$1@news.povray.org>
Invisible schrieb:
> Well, yeah, there is that. If you don't *do* crazy stuff with pointer
> arithmetic in the first place, you're less likely to have problems.
"Less likely" hits the nail straight on the head, in every sense.
> In other words, the design of your application doesn't let you solve the
> problem properly, and the only way to get it to work is with a hack that
> doesn't work properly, which then introduces more problems that can only
> be fixed with hacks... until eventually you figure out that it's less
> work to redesign your application to work right in the first place.
Exactly! Except that typically some other bloke did the original design,
has already left the company, and first thing you need to figure out is
whether there was any reason he chose that braindead approach...
> [Can you tell how many large programs I've worked on?]
 From what statements I read from you so far, I'd guess they amount to
something like, roughly, let me think, about.. um - zero?? ;-)
Date: 24 Aug 2009 09:28:06
Message: <4a929566@news.povray.org>
clipka wrote:
> Invisible schrieb:
>> The way I read it, they had a structure with two integers and a void
>> pointer. "But we couldn't just add an extra integer field, because
>> we'd have to change a few thousand other functions." I'm not seeing
>> why changing a structure to have a new field which is only used in
>> certain places is a problem.
> It wasn't a structure: It was a callback function signature.
Oh, right. I thought it was a C struct.
If you're got to actually change function prototypes then, yeah, that's
not going to happen...
Date: 24 Aug 2009 12:02:10
Message: <4a92b982$1@news.povray.org>
Invisible wrote:
> No, what I'm saying is "if adding debug code alters all the bugs, how
> does that not make it scientifically impossible to remove all the bugs?"
Code inspection. You know as well as the computer does what the computer is
doing, so you can sit and pay lots and lots of attention to the problematic
code and figure out exactly what's going on.
Which is what amazes me about medical progress, where you *don't* know
exactly what's going on, but people manage to figure out (for example) what
DNA replication actually *looks* like, and how fast it goes, and etc.
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 24 Aug 2009 12:09:33
Message: <4a92bb3d$1@news.povray.org>
scott wrote:
> I guess they didn't bother with such things in the iPhone :-)
The bit I like best is where they count the number of bytes they received
before they turned off the receiver and then adjust the wake-up time they
program into the hardware, on the basis that the heat from running the
receiver will have made the crystal run at a different speed for the next
1.28 seconds they're asleep, and you don't want to wake up too soon or too
late. :-)  Scary stuff going on inside there.
I also found out that while my car has a bluetooth headset feature built in
that lets me make hands-free calls from the car without taking the phone out
of my pocket, lots of cars in Europe use the "SIM profile" of bluetooth. So
there's an entire phone built into the car that just wirelessly accesses the
SIM chip, pulling in the phone book of whoever is in the car and everything.
Very cool.
Date: 24 Aug 2009 12:14:54
Message: <4a92bc7e$1@news.povray.org>
Invisible wrote:
> software don't just accept random hangups and crashes as an unavoidable
> fact of life. They fix them. All of them.
*Probably*, yes.
It's not a matter of "unavoidable fact of life". It's simply a cost to
benefit ratio. If over the lifetime of your computer you spend (say) six
hours waiting for it to reboot, or you could spend 60 hours finding and
fixing the bug that's causing that problem, what do you do?
> Anyway, embedded programming and safety-critical programming are both
> very specialist.
Not especially, no. Indeed, I bet if you go around your house, you'll find
you have more embedded applications in your house than you have desktop
applications.  (Don't forget to count the BIOS, the NIC card, the sound
card, etc in your PC. ;-)
> I doubt many people will ever see such code in their
> lives.
Sure. And few people will start their own companies. That doesn't mean
business law is a specialized endeavor.
 > And I guess you could argue that games programming is pretty
> specialist too...
I would say so, yes.
> "Most" programs, after all, are either desktop
> applications or web applications, and most of them just push data around.
Hard to say, really. Certainly the *easy* programs are desktop and web apps.
Date: 24 Aug 2009 12:23:12
Message: <4a92be70$1@news.povray.org>
> pointer.
It says "each event was passed around with two integer arguments and a void
pointer in case you needed extra parameters."
I guess you could read that as an event being an object or structure. I read
it as an event being a function call with three arguments. I see now that it
is pretty ambiguous.
Either way, the right answer was to add the extra field if they needed it.
It's hard to understand how that would be difficult, with the compiler
catching the mistakes for you. Harder to be sure if it's an allocated
structure passed around rather than function arguments, for sure.
> Then again, we're talking about a large, complex codebase. Maybe there's
> something relevant they forgot to mention or something...
If it's passed around as arguments, you first have to track down all the
functions that are "event" functions and add the new argument, then pass
that argument from caller event functions to callee event functions if
events can call other events. The compiler will help here. (Indeed, you can
just add the extra argument, and compile, and fix the
wrong-number-of-arguments error and compile, and etc, working your way up
the call chain.) Falls apart if you're doing something to queue events for
later or some such, and the function doing the queuing fails to queue the
new argument that the function dequeuing needs. That's a bit harder to track
down.
If it's a structure, you have to make sure you allocate and free the right
amount of memory, which could certainly be a problem if you're silly enough
to hard-code the size of the structure (or assumptions about the size)
anywhere. For example, if you have a big queue of events, and you need 1000
of them to fit in 8K of memory, and they're 8 bytes each, adding another 2
bytes to each is going to push you over the limit.
Impossible to say without more info.
Date: 24 Aug 2009 12:24:52
Message: <4a92bed4$1@news.povray.org>
Not sure why not. It's actually pretty easy.
You fix the routine that needs the new parameter, and the routine that has
the new parameter. You compile the code. Anyone who calls the new routine
won't compile. Fix them to accept a new parameter and pass it in. Iterate
until all functions on the call chain between where you have the parameter
and where you need the parameter are passing it down.
Date: 24 Aug 2009 15:02:26
Message: <4A92E3C2.3020506@hotmail.com>
> received before they turned off the receiver and then adjust the wake-up
> time they program into the hardware, on the basis that the heat from
> running the receiver will have made the crystal run at a different speed
> for the next 1.28 seconds they're asleep, and you don't want to wake up
> too soon or too late. :-)  Scary stuff going on inside there.
> in that lets me make hands-free calls from the car without taking the
> phone out of my pocket, lots of cars in Europe use the "SIM profile" of
> bluetooth. So there's an entire phone built into the car that just
> wirelessly accesses the SIM chip, pulling in the phone book of whoever
> is in the car and everything. Very cool.
I like that. Nice idea for our cab-driver when he has to transport
another celebrity.
Date: 24 Aug 2009 18:04:59
Message: <4a930e8b$1@news.povray.org>
>> built in that lets me make hands-free calls from the car without
>> taking the phone out of my pocket, lots of cars in Europe use the "SIM
>> profile" of bluetooth. So there's an entire phone built into the car
>> that just wirelessly accesses the SIM chip, pulling in the phone book
>> of whoever is in the car and everything. Very cool.
> another celebrity.
Yes, that *could* be a security problem :-)
It's not as bad though as one might think: Virtually all phones out
there won't allow a phonebook download without proper bonding, nor allow
proper bonding without user interaction. So unless the celebrity is
really stupid...
... wait - what?! :-P
(BTW, I actually did work on things like those.)
Date: 24 Aug 2009 18:13:44
Message: <4a931098$1@news.povray.org>
Well, if that's a total of six man-hours (as opposed to maybe thousands
of people losing six hours each), then it's more economic to leave the
bug in there. Provided it doesn't cause any other harm like destroying
valuable data, setting off a thermonuclear war or something...
That's one reason why in-house tools tend to be so crappy: It's more
economic to accept the loss of productivity of the few people who
actually use it, than investing that productivity into improving it.
> apps.
I guess old-fashioned mainframe business apps are rather boring, too.
