POV-Ray : Newsgroups : povray.off-topic : Tell me it isn't so! Server Time
6 May 2026 07:58:00 EDT (-0400)
  Tell me it isn't so! (Message 51 to 60 of 473)
Subject: Re: Tell me it isn't so!
Date: 22 Jul 2009 08:11:29
Message: <4a6701f1$1@news.povray.org>
> - Splitting a program into more than one source file opens up a whole new
> world of pain. (Especially if you don't have the benefit of automake.)
You don't have to do this, and for tiny programs it's probably not needed.
For larger programs I cannot begin to imagine how inefficient it would be to
have it all in one file, let alone when I want to reuse an existing class in
another project.
You sound like you need to get a decent book on C++ (NOT C) and get a modern
IDE (Visuall C++ Express will let you do standard C++ without any .net stuff
and is free).
Of course if you're stuck writing a whole program in one C file in notepad
things are gonna suck big time.
Subject: Re: Tell me it isn't C
Date: 22 Jul 2009 08:21:26
Message: <4a670446$1@news.povray.org>
>> new world of pain. (Especially if you don't have the benefit of
>> automake.)
> needed. For larger programs I cannot begin to imagine how inefficient it
> would be to have it all in one file, let alone when I want to reuse an
> existing class in another project.
The point is, as soon as you have more than one source file, you have to
manually write header files, manually keep them synchronised with the
source files, manually figure out the dependency tree, manually compile
everything one at a time, manually recompile stuff as needed, and
manually link it all at the end. Get any single step wrong, and at best
you'll get an incomprehensible linker error; at worst you'll get a
segfault. Good luck every figuring out why.
If you have automake, a few of those tasks become automated. But
seriously, I'm used to having a language where you say "compiler my
stuff" and it hands you a runnable program.
> modern IDE (Visuall C++ Express will let you do standard C++ without any
> .net stuff and is free).
I've seen more adverts for C than for C++ (although there certainly seem
to be quite a few for C++ as well). I think I might still have VS
installed on my PC at home. I guess it's just finding the motivation to
use a language which is over-complicated, unsafe and difficult when I
could instead use one which is clean, simple and easy...
> notepad things are gonna suck big time.
Actually, Borland's TurboC for DOS IDE. (Or, alternatively, Vim under
Linux.)
Date: 22 Jul 2009 08:37:23
Message: <4a670802@news.povray.org>
  Do you honestly think that an IDE like Visual Studio is not going to
automatically create project dependencies for you?
  In the Unix side of the world knowing a bit of makefile syntax gets you
a long way. It's even possible to create a makefile (at least when using
gnu make) which automates mostly everything, including resolving dependencies.
  And for a small project a simple "g++ *.cc -o myprogram" will do just fine.
Date: 22 Jul 2009 08:41:37
Message: <4a670901@news.povray.org>
> Oh, I have a far bigger "problem" than that: C is the number one
> language requested in job adverts. :-(
  I feel your pain because I hate C (but for different reasons than you).
See http://warp.povusers.org/grrr/HateC.html
  Your problem is that you project your C prejudices onto C++ as well,
and simply refuse to learn the tools C++ offers to make your life easier.
In a past thread I tried to teach you a few things about C++ which make
it a lot easier to write small programs quickly, and for a moment I thought
that you had actually learned something. Then some time after that you wrote
a new thread where you showed your attempts at writing something and it
seemed like you forgot or ignored *everything* that I had tried to teach you.
At that point I completely lost hope.
Date: 22 Jul 2009 08:43:33
Message: <4a670975$1@news.povray.org>
It's not entirely clear to me that the source code alone actually
provides enough information to do this.
Presumably it's simple enough to figure out which source files depend on
which header files. Not sure how you proceed from there though.
Date: 22 Jul 2009 08:44:22
Message: <4a6709a6$1@news.povray.org>
> seriously, I'm used to having a language where you say "compiler my stuff"
VS does most of that for you too (you just press F5 and it compiles and
links the lot, automatically only compiling files that have changed since
the last build), and you don't need to have separate header files if you
don't want to.  A lot of people just find it makes more sense to have one
file that neatly shows the interfaces and another to actually contain the
implementation code.
> I guess it's just finding the motivation to use a language which is
> over-complicated, unsafe and difficult when I could instead use one which
From my point of view Haskell looks over-complicated, difficult and slow,
but I suspect that's just because I haven't bothered to learn much about it.
Anyway, the motivation for you is all those job adverts you say you keep
seeing...
Date: 22 Jul 2009 08:47:48
Message: <4a670a74@news.povray.org>
  Why wouldn't it? If a source code file needs another source code file,
it will #include it, and the IDE sees that and creates a dependency.
  If you don't #include another source code file then there is no dependency
between those two files.
Date: 22 Jul 2009 08:51:02
Message: <4a670b36@news.povray.org>
  My problem with Haskell is that it's hard to learn. It's like it's 1% of
syntax and 99% of "clever" tricks which you just have to learn from somewhere
(often by word of mouth). And these tricks are often rather exotic and
unintuitive to an imperative/OO programmer.
Date: 22 Jul 2009 08:54:40
Message: <4a670c10$1@news.povray.org>
> since the last build), and you don't need to have separate header files
> if you don't want to.  A lot of people just find it makes more sense to
> have one file that neatly shows the interfaces and another to actually
> contain the implementation code.
Now that's interesting.
1. How does it know which files depend on which other files?
2. A header file is what defines what can be accessed from outside a
given source file. Without a header file, how do you determine what's
supposed to be public and what isn't?
> slow, but I suspect that's just because I haven't bothered to learn much
> about it.
To use Haskell, you need to learn something like half a dozen basic
principles. After that it's just figuring out "OK, how the hell do I
perform task X?" Learning C++ it just seems like learning feature after
feature after feature, seemingly without end. (C is a lot simpler, it's
just astonishingly easy to shoot yourself in the foot with it.)
> seeing...
Yeah, but let's think about this. I could spend a few months failing to
learn C++. Hell, maybe I could even write a small program that actually
works. But I'm up against people who have coded in nothing but C++ since
they were 9 years old. I don't really stand much of a chance here...
Date: 22 Jul 2009 08:58:16
Message: <4a670ce8$1@news.povray.org>
I must concurr with Warp here on the "not written down anywhere" part.
People are doing a lot of very cool stuff with Haskell, but it can be
maddeningly hard to find answers.
(E.g., somebody implemented a Doom clone in Haskell, and wrote a paper
explaining how they did it. Except that the paper is utterly
incomprehensible. It makes no sense at all. It's so badly explained that
I just can't follow any of it.)
Actually, I think Warp's assessment of Haskell is about right. Haskell
is like Go. The "rules" are simple, but the "game" is not.
