POV-Ray : Newsgroups : povray.off-topic : Video Game FPS vs RPG Server Time
1 Aug 2026 02:15:55 EDT (-0400)
  Video Game FPS vs RPG (Message 38 to 47 of 57)
Subject: Re: Video Game FPS vs RPG
Date: 14 Jul 2009 15:09:46
Message: <4a5cd7fa@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Patrick Elliott wrote:
> > Less to do with AI than with animation limitations. The more things you
> > have moving at the "best" rate, the harder your hardware needs to work.
> Is that really true? I thought the whole (visible) scene got pumped out to
> the graphics card on every frame. Hence the need for AGPx8 and such.
  It may have something to do with LODs: When the object is farther away,
it usually will be switched to a version with less triangles. It might also
be that in this case the lowest-resolution LOD models were not animated at
all, and thus the effect you see.
Date: 14 Jul 2009 15:28:41
Message: <4a5cdc69$1@news.povray.org>
Interesting theory! :-)
I'm kind of thinking it'll be cool when motion capture finally comes to the
masses. When someone sends out a PDF you can print out, cut up, and tape to
your clothes, and point a web cam at yourself...
Pretty much everything else is available for free at this point, at least in
the video rendering path.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 14 Jul 2009 23:45:00
Message: <web.4a5d4f9945e8e26c3964e90f0@news.povray.org>
> clipka wrote:
> > That's some other strange association people have: RPG == fantasy.
> > SciFi-RGBs have proven this connotation to be wrong.
> You know you've been ray-tracing too long when...
LOL - yeah, that has happened to me multiple times recently; to me, "RPG" is a
7-letter acronym: "RGB<backspace><backspace>PG" :P
Date: 15 Jul 2009 00:00:01
Message: <web.4a5d537945e8e26c3964e90f0@news.povray.org>
There is some stuff that - fortunately - does not need to be pumped around for
each frame. Traditionally, textures are such stuff. I bet static meshes are
another one these days: Applying the same transformation matrix to a wagonload
of vertices is no big deal for a GPU, and sufficient to have the object hover
around and maybe rotate.
One more reason to not animate stuff which is just barely visible.
Date: 15 Jul 2009 00:52:01
Message: <4a5d6071@news.povray.org>
Exactly.
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 15 Jul 2009 03:49:06
Message: <4a5d89f2$1@news.povray.org>
> for
> are
> wagonload
> hover
Being able to store static meshes on the video card started with DirectX 7
and the GeForce 256, about a decade ago.
In most modern games even non-static meshes are held permanently on the GPU.
The CPU simply tells the GPU some angles (or other parameters) each frame,
and a vertex shader running on the GPU suitably deforms the mesh prior to
rendering.  This greatly reduces the data bandwidth between the CPU and GPU
and allows huge numbers of animated meshes to be drawn in realtime that
otherwise wouldn't be possible.
It also allows for clever things like real waves in water (not just normal
effects), whereby the GPU can distort the water mesh itself every frame and
not need to transfer the whole mesh from the CPU per frame.
Ditto for terrain, even if the terrain itself does not need to distort, you
can smoothly fade between different LOD levels using just the GPU to avoid
having to send interpolated meshes per frame.
Date: 15 Jul 2009 10:15:35
Message: <4a5de487@news.povray.org>
  Deciding what to render and what not (iow. hidden surface/object removal)
has to still be done with the CPU, though. Too complicated for a GPU to do,
as it requires rather extensive and complicated code using lots of complex
data structures.
  Also, I'm wondering that nowadays there are many games with ginormous
amounts of scenery (such as eg. Oblivion, Fallout 3 and Far Cry 2). I doubt
all that scenery would fit in RAM at once, much less in the graphics card.
The scenery is being loaded on-the-fly as the player advances in the terrain
(in the latter two example games mentioned, this is done transparently,
without any "loading" messages or delays). Naturally all this scenery needs
to be transferred to the GPU.
Date: 15 Jul 2009 11:01:27
Message: <4a5def47@news.povray.org>
> doubt
> terrain
> needs
Graphics cards can store quite a lot of mesh and texture data on-board, the
CPU algorithm just needs to carefully predict and spread out any big updates
to avoid noticeable frame rate drops.  For example some common meshes like
trees and grass might always be in the GPU memory, but some detailed
versions of buildings might only be loaded when you get near to them, and
the actual mesh load peformed over several frames.  The terrain is also
typically sectioned up, and the LOD for each section is dtermined by a CPU
algorithm and the GPU updated whenever necessary.  This way, *most* frames
you will hardly be sending any data from the CPU to the GPU, and the frames
where you do need to send mesh data you are only sending a very small amount
that won't impact the rendering performance.
Of course if it all doesn't fit in normal CPU RAM the CPU algorithm must
also manage reading from the disk in a similar way to be transparent.
It's certainly not trivial to implement a massive game environment.
Date: 15 Jul 2009 18:20:00
Message: <web.4a5e55e945e8e26ca95afc190@news.povray.org>
> data structures.
This is moving more and more towards "hidden object removal"; a decade ago, in
an FPS like Unreal Tournament there would be a single data structure per level
representing all the static stuff, from the general room layout to the smallest
ducts & decorations, with some smart geometry tree like BSP to handle hidden
surface stuff; only the moving actors would exist as "independent" meshes, out
of pure necessity.
When I looked again a few years ago, the classic level structure had been
reduced to the basic room layout, and all the details - ducts and stuff - were
modelled as independent objects.
I conjecture that developers have been shifting more and more of the hidden
stuff removal workload to the GPU, to free the CPU for other tasks. With the
added benefit of having less traffic between CPU and GPU. So the CPU just does
a comparatively rough pre-selection of which objects *may* be visible, and the
rest is left up to Z-buffering and brute force.
As the player normally can't move too fast, there's probably plenty of time to
"swap in" scenery data by and by.
Date: 15 Jul 2009 18:52:42
Message: <4a5e5db9@news.povray.org>
  I wouldn't say there's "plenty of time" because the CPU, the GPU the
I/O buses and the graphics bus have to do quite a lot of other things
at the same time, at 60 frames per second preferably.
